-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Two-Layer k-Epsilon Turbulence Model (http://www.cfd-online.com/Forums/openfoam-programming-development/86888-two-layer-k-epsilon-turbulence-model.html)
james.t April 5, 2011 07:12
Hello everybody,
I'm modifying the standard k-epsilon model included in OpenFOAM to include a two-layer boundary treatment according to [1, 2]. My goal is to achieve a grid independent solution. My reference case is the simulation of a turbulent boundary layer and comparison to the results of Whtie and Wieghardt.
I directly changed the code in the kEpsilon.C to solve the transport equation for k and epsilon for the whole field (no modification so far). For lower Reynolds numbers Re_y < 200, one equation for epsilon and one for mut are calculated to overwrite the results of the previous epsilon transport equation (see source code).
However, directly at the wall Re_y goes to zero, so mut would be zero and epsilon infinity. How should I treat these values directly at the wall? Has someone experience with the two-layer near-wall treatment in openfoam?
Thanks a lot!
James
void Ketl::correct()
        if (!turbulence_)
                // Re-calculate viscosity
                mut_ = rho_*Cmu_*sqr(k_)/(epsilon_ + epsilonSmall_);
                mut_.correctBoundaryConditions();
                // Re-calculate thermal diffusivity
                alphat_ = mut_/Prt_;
                alphat_.correctBoundaryConditions();
                return;
        RASModel::correct();
        volScalarField divU = fvc::div(phi_/fvc::interpolate(rho_));
        if (mesh_.moving())
                divU += fvc::div(mesh_.phi());
        tmp<volTensorField> tgradU = fvc::grad(U_);
        volScalarField G("RASModel::G", mut_*(tgradU() && dev(twoSymm(tgradU()))));
        tgradU.clear();
        // Update espsilon and G at the wall
        epsilon_.boundaryField().updateCoeffs();
        // Dissipation equation
        tmp<fvScalarMatrix> epsEqn
                fvm::ddt(rho_, epsilon_)
            + fvm::div(phi_, epsilon_)
            - fvm::laplacian(DepsilonEff(), epsilon_)
                C1_*G*epsilon_/k_
            - fvm::SuSp(((2.0/3.0)*C1_ + C3_)*rho_*divU, epsilon_)
            - fvm::Sp(C2_*rho_*epsilon_/k_, epsilon_)
        epsEqn().relax();
        epsEqn().boundaryManipulate(epsilon_.boundaryField());
        solve(epsEqn);
        bound(epsilon_, epsilon0_);
        // * * * N E W * * *
        // wall distance
        volScalarField y_ = wallDist(mesh_).y();
        // reynolds number based on wall distance
        Rey_ = rho_ * y_ * sqrt(k_) / mu();
        // constants
        scalar Cmu75 = pow(Cmu_.value(), 0.75);
        scalar kappa_ = 0.42;
        scalar Aeps_ = 2 * kappa_ / Cmu75;
        // loop over all cells
        forAll(Rey_, cellI)
                if(Rey_[cellI] < 200)
                        // length scale
                        scalar Leps = y_[cellI] * kappa_ / Cmu75 * (1 - exp( -Rey_[cellI] / Aeps_ ));
                        // dissipation
                        epsilon_[cellI] = pow(k_[cellI], 1.5) / Leps;
        // Turbulent kinetic energy equation
        tmp<fvScalarMatrix> kEqn
                fvm::ddt(rho_, k_)
            + fvm::div(phi_, k_)
            - fvm::laplacian(DkEff(), k_)
                G
            - fvm::SuSp((2.0/3.0)*rho_*divU, k_)
            - fvm::Sp(rho_*epsilon_/k_, k_)
        kEqn().relax();
        solve(kEqn);
        bound(k_, k0_);
        mut_ = rho_*Cmu_*sqr(k_)/epsilon_;
        // constants
        scalar Amu_ = 70;
        scalar A_ = 10 / tanh(0.98);
        forAll(Rey_, cellI)
                        // length scale
                        scalar Lmu = y_[cellI] * kappa_ / Cmu75 * (1 - exp( -Rey_[cellI] / Amu_ ) );
                        // viscosity according to the standard k-epsilon model
                        scalar mutKE = rho_[cellI] * Cmu_.value() * sqr(k_[cellI]) / (epsilon_[cellI] + epsilonSmall_.value());
                        // viscosity according to wolfstein
                        scalar mutTL = rho_[cellI] * Cmu_.value() * Lmu * sqrt(k_[cellI]);
                        // blending function
                        scalar lambda_ = 0.5* ( 1 + tanh( (Rey_[cellI] - 200) / A_ ) );
                        // blended viscosity
                        mut_[cellI] = lambda_ * mutKE + (1 - lambda_) * mutTL;
[1] http://my.fit.edu/itresources/manual...ug/node514.htm
[2] http://www.kxcad.net/STAR-CCM/online...ulence-32.html
cosimobianchini April 6, 2011 05:06
Hi James,
simply updating epsilon field after solving the transport equation would not be enough to obtain solution with smooth epsilon and mut field. You should consider exploit the setValues member function of fvMatrix to ensure that you satisfy at the same time the extended wall function in the near wall zone as well as the transport equation in the free jet.
Concerning the limiting behavior at the wall for the turbulent quantities your are right that y and so mut tend towards 0, however k is going to zero as well and the value of epsilon should be finite. This behavior is common to all Low-Reynolds turbulence models. For the test case indicated you find a review of the near wall behaviour of several Low-Reynolds turbulence model in:
V. C. Patel, W. Rodi, and G. Sheuerer. Turbulence models
for near wall and low reynolds number flows: a review.
AIAA Journal, 26:13081319, 1993
Here:http://www.opensourcecfd.com/conference2008/2007/index.php
you can find this article:
Heat Transfer Applications in Turbomachinery - L. Mangani, C. Bianchini
dealing partially with the test case you are referring to.
More results could be find in: http://powerlab.fsb.hr/ped/kturbo/Op...aniPhD2008.pdfhttp://powerlab.fsb.hr/ped/kturbo/Op...aniPhD2008.pdf
Hope you find this interesting,
Cosimo
james.t April 7, 2011 05:11
Hi cosimo,
thank you very much for your help!
I just found out, that I forgot to implement the blending function for epsilon! One of the reaons, my results weren't that good. Also thanks for the setValues command, I already included it and it seems to work perfectly :-)
Thanks again for the papers! I hadn't good reference so far, so that's invaluable for me!
Regards
James
james.t April 7, 2011 10:56
I modified my two-layer model according to the paper of Volkov [1]. Now a blending function lambda is directly included in the dissipation transport equation to distinguish between the free-stream region and the near-wall region. (Limit: Re_y = 200)
The transport equation for epsilon is as follows:
            + lambda_ * fvm::div(phi_, epsilon_)
            - lambda_ * fvm::laplacian(DepsilonEff(), epsilon_)
              lambda_            * C1_*G*epsilon_/k_
            - lambda_            * fvm::SuSp(((2.0/3.0)*C1_ + C3_)*rho_*divU, epsilon_)
            - lambda_            * fvm::Sp(C2_*rho_*epsilon_/k_, epsilon_)
            + (1 - lambda_)  * alpha * rho_ * ( pow(k_, 1.5)/Leps_ - epsilon_ )
        epsEqn().relax();
        solve(epsEqn);
where lambda_ is the blending function defined as
        // wall distance
        volScalarField lambda_ = 0.5* ( 1 + tanh( (Rey_ - 200) / A_ ) );
lambda is zero at the wall, so that just
+ alpha * rho_ * ( pow(k_, 1.5)/Leps_ - epsilon_ )
is solved.
The viscosity is calculated as follows:
        scalar Amu_ = 70;
        volScalarField Lmu = y_ * kappa_ / Cmu75 * (1 - exp( -Rey_ / Amu_ ) );
        volScalarField mut_ke = rho_*Cmu_*sqr(k_)/epsilon_;
        volScalarField mut_tl = rho_*Cmu_*Lmu*sqrt(k_);
        mut_ = lambda_ * mut_ke + (1 - lambda_) * mut_tl;
However, the simulations always show some regions with very high turbulent viscosity outside the boundary layer (Re_y > 200) with values of mut = 10 mio and more.
Can someone give me an advise, where the mistake might be?
Thanks a lot!
Regards
James
[1]
K.N. Volkov,
"Application of a two-layer model of turbulence in calculation of a boundary layer with a pressure gradient", Journal of Engineering Physics and Thermodynamics, Volume 80
lakeat January 25, 2012 13:12
Hi James,
Did you make it?
neeraj February 11, 2013 02:00
Hi all,
Did anyone try and succeed in implementing 2 layer model.... i am trying to do the same into realizableKE model.
neeraj May 4, 2013 12:26
I Did It..!
Finally i did it...!! thanks for help of all forum members..!!
sam1364 February 21, 2014 13:43
Hey Neeraj,
can you please post your code here. I wanna do the same thing and I would like to check on that with you.
Thanks,
Tehseen March 25, 2016 02:34
Dear Neeraj, will you please like to share the code as it will be much valuable for me in my thesis writing. You can contact me at mktehseen@gmail.com too.
Thanks in advance
