-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Term for total Stresses (http://www.cfd-online.com/Forums/openfoam-programming-development/87009-term-total-stresses.html)
james.t April 8, 2011 14:16
in the k-epsilon turbulence model the total stress term is calculated as volSymmTensorField
tmp<volSymmTensorField> kEps::devRhoReff() const
    return tmp<volSymmTensorField>
        new volSymmTensorField
            IOobject
                "devRhoReff",
                runTime_.timeName(),
                mesh_,
                IOobject::NO_READ,
                IOobject::AUTO_WRITE
          -muEff()*dev(twoSymm(fvc::grad(U_)))
and the source term for the momentum equation as fvVectorMatrix
tmp<fvVectorMatrix> kEps::divDevRhoReff(volVectorField& U) const
    return
      - fvm::laplacian(muEff(), U)
      - fvc::div(muEff()*dev2(fvc::grad(U)().T()))
Now I'd like to modify the total stress tensor devRhoReff and use it for the calculation of the source term of the momentum equation divDevRhoReff like this:
fvVectorMatrix divDevRhoReff = fvc::div(devRhoReff);
However the following error occurs:
error: conversion from ‘Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >’ to non-scalar type ‘Foam::fvVectorMatrix’ requested
Is there another way to convert the total stress tensor devRhoReff to the source term divDevRhoReff?
Thanks alot!
James
