matching variable data with grid point data
Old   May 6, 2011, 15:28
Default matching variable data with grid point data
anfho is on a distinguished road
I want to extract data point values and grid/mesh point information/location from OF, specifically fireFoam, but the solver should not matter here. Moreover, I do not only want to extract them, I also want to match that information, meaning I want to be sure which value belongs to which mesh point.
So far, I have been able to extract that data (see below), but I am not 100% sure, if the label for the value corresponds to the label of the mesh point.
So the QUESTION here is: can anyone verify that the label associated with a data point is the same label that is associated with a mesh point that corresponds to that very same data point?
Thanks!
Andreas
P.S.:
Extracting and outputting the data into a external file has been accomplished by:
#include "OFstream.H"
OFstream testout ("densitydata");
//start time loop
forAll(rho,rholbl)
  scalar rhoi = rho[rholbl];
  Vector<double> rhopos = mesh.points()[rholbl];
  testout << "rho:" << rhoi << ":" << rholbl << ":" << rhopos << endl;
  rho[rholbl] = rhoi;
//end time loop
which will result in the following output:
rhoi: data point value
rholbl: rho-label associated with that datapoint
rhopos: grid point location (coordinates) associated with that label
"rho":rhoi:rholbl:rhopos
rho:1.17195:0:(-0.5 0 -0.01)
rho:1.17195:1:(-0.493333 0 -0.01)
rho:1.17195:2:(-0.486667 0 -0.01)
rho:1.17195:3:(-0.48 0 -0.01)
rho:1.17195:4:(-0.473333 0 -0.01)
rho:1.17195:5:(-0.466667 0 -0.01)
rho:1.17195:6:(-0.46 0 -0.01)
rho:1.17195:7:(-0.453333 0 -0.01)
rho:1.17195:8:(-0.446667 0 -0.01)
rho:1.17195:9:(-0.44 0 -0.01)
rho:1.17195:10:(-0.433333 0 -0.01)
rho:1.17195:11:(-0.426667 0 -0.01)
etc.
etc.
myfireFoam.C attached.
anfho is offline   Reply With Quote
Plot data for a fixed point aut_iut OpenFOAM 0 December 23, 2010 05:16
grid data white heart Main CFD Forum 4 May 4, 2010 09:05
Time history of a variable at a point for calculating correlations? eoin OpenFOAM 1 August 25, 2009 16:07
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
Grid refinement with wall functions Mark Render Main CFD Forum 8 May 2, 2000 07:09
