-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   modify fvMatrix / coupled equations / higher order diffusion (http://www.cfd-online.com/Forums/openfoam-programming-development/88062-modify-fvmatrix-coupled-equations-higher-order-diffusion.html)
Jinming May 7, 2011 06:20
Dear OpenFOAM community,
I've just started using OpenFOAM, trying to solve an equation of the type
df/dt = laplacian(laplacian(f))
for higher order diffusion
To my limited knowledge (please correct if I am wrong), simple diffusion
df/dt = laplacian(f) is already implemented and
fvScalarMatrix fEqn
    fvm::ddt(f) - fvm::laplacian(f)
creates an equation of the type (for the implicit case)
(F - F0)*V/deltaT - A*F
where F is a vector/list containing the cell values of f to be calculated, F0 those of the previous time step, V is the volume, deltaT is the time step, and A denotes the "discretized laplacian" (coefficient matrix).
A naive solution of
would be creating an equation of the type
(F - F0)*V/deltaT - A*A*F,
i.e. multiplying the fvMatrix A obtained from fvm::laplacian(f) by itself.
I would be grateful if someone could give me a hint on the implementation or how to solve the coupled problem
df/dt == laplacian(g)
laplacian(f) == g
Thanks in advance.
Best regards,
Jinming
