Home > Forums > OpenFOAM Programming & Development
undefined reference when adding new member function
Old   May 17, 2011, 11:08
Unhappy undefined reference when adding new member function
Florian Ettner
dohnie is on a distinguished road
this has cost me six hours so far:
I want to add a new member function to the hCombustionThermo class. I've boiled it down to the simplest possbile problem. In hCombustionThermo.H I write:
  void hello();
It compiles fine.
In my solver (based on reactingFoam) I write:
Info<< nl << "Reading thermophysicalProperties" << endl;
autoPtr<hPsiChemistryModel> pChemistry
    hPsiChemistryModel::New(mesh)
hPsiChemistryModel& chemistry = pChemistry();
hCombustionThermo& thermo = chemistry.thermo();
thermo.hello();     // the only change
It seems that compiling works, but during the linking process an error occurs:
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-40 -I/nfs/opt/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude     -I/nfs/opt/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/compressible/turbulenceModel     -I/nfs/opt/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/compressible/RAS/derivedFvPatchFields/wallFunctions/mutWallFunctions     -I/nfs/opt/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/compressible/RAS/lnInclude     -I/nfs/home/ettner/OpenFOAM/ettner-1.7.1/src/thermophysicalModels/reactionThermo/lnInclude     -I/nfs/home/ettner/OpenFOAM/ettner-1.7.1/src/thermophysicalModels/basic/lnInclude     -I/nfs/home/ettner/OpenFOAM/ettner-1.7.1/src/thermophysicalModels/specie/lnInclude     -I/nfs/home/ettner/OpenFOAM/ettner-1.7.1/src/thermophysicalModels/chemistryModel/lnInclude     -I/nfs/opt/OpenFOAM/OpenFOAM-1.7.1/src/engine/lnInclude     -I/nfs/opt/OpenFOAM/OpenFOAM-1.7.1/src/ODE/lnInclude     -I/nfs/home/ettner/OpenFOAM/ettner-1.7.1/applications/solvers/flameTracing     -I/nfs/home/ettner/OpenFOAM/ettner-1.7.1/src/interpolationLookUpTable -IlnInclude -I. -I/nfs/opt/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/nfs/opt/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude   -fPIC Make/linux64Gcc43DPOpt/ddtLookup.o -L/nfs/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64Gcc43DPOpt \
             -L/nfs/home/ettner/OpenFOAM/ettner-1.7.1/lib/linux64Gcc43DPOpt     -lmyreactionThermophysicalModels     -lmybasicThermophysicalModels     -lmychemistryModel     -lmyspecie     -lfiniteVolume     -lcompressibleRASModels     -lcompressibleLESModels     -lengine     -lODE -lOpenFOAM -liberty -ldl   -lm -o /nfs/home/ettner/OpenFOAM/ettner-1.7.1/applications/bin/linux64Gcc43DPOpt/ddtLookup
Make/linux64Gcc43DPOpt/ddtLookup.o: In function `main':
ddtLookup.C:(.text+0x1bbd): undefined reference to `Foam::hCombustionThermo::hello()'
collect2: ld returned 1 exit status
make: *** [/nfs/home/ettner/OpenFOAM/ettner-1.7.1/applications/bin/linux64Gcc43DPOpt/ddtLookup] Error 1
Can anybody explain me what I'm doing wrong?
dohnie is offline   Reply With Quote
Old   May 17, 2011, 12:00
Robertas N.
r08n is on a distinguished road
[QUOTE=dohnie;307983]
  void hello();
You declare a function, but not define it. Try this:
void hello (){}
In general, you better not modify the existing OF classes like this.
If you need to extend some class, declare your own class inherited from the existing class, like this:
class my_hCombustionThermo : public hCombustionThermo
  void hello () {}
r08n is offline   Reply With Quote
Old   May 17, 2011, 12:06
David Gaden
marupio is on a distinguished road
You have a prototype for the hello() function, but no implementation of it. That is causing the problem you posted. I think you may have boiled it down too far?
marupio is offline   Reply With Quote
Old   May 19, 2011, 04:31
Florian Ettner
Thanks to both of you, I'll give it another try!
Thread Tools
Trackbacks are On
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Could you please help me about the VTKFoam liugx212 OpenFOAM Pre-Processing 5 February 13, 2008 12:31
Parallel processing problem with mpich nzy102 OpenFOAM Running, Solving & CFD 14 October 18, 2007 00:05
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
