How to calculate Cp (Heat Capacity at Constant Pressure) ?
Hi foamers,
I'm trying to improve a new solver in OpenFOAM, but I have some problems. I need to calculate Cp (Heat Capacity at Constant Pressure), and I must add it in the standard solver "rhoPorousSimpleFoam". I tried to add a line in "createFields.H", but it doesn't work. Quote:
Or can I load properties of air by an external file? |
What does the error say? Is it a compiler error or a runtime error? You will probably find the mistake is in the type you have given for the variable Cp. Check it against the return type of Cp in basicThermo.
Hi Laurence, thanks for your reply.
So, I will explain you what is my problem. I want to create a new solutor, and I need for my calculations some variables: - enthalpy - pressure - heat costant Cp - rho But whenever h, p and rho are already gived, I must find the way to calculate Cp. My "createFields.H" file start with these lines: Quote:
How can I move to correct it? PS: if I check in "basicPsiThermo" file, I find this Quote:
Thanks in advance! |
In short: Change 'volScalarField& Cp = thermo.Cp()' to 'volScalarField Cp = thermo.Cp();'
Hi foamers,
Why does cp(p,T) function return zero for ideal gas? How can I calculate it for other equation of states? Thanks |
Cp=Cp.Janaf+Cp.EOS
