multiphaseEulerFoam: solution procedure
Old   May 4, 2014, 18:51
Default multiphaseEulerFoam: solution procedure
maybee is on a distinguished road
hi,
I need to know the dicretisations of the equations and the solution procedures in "multiphaseeulerfoam" for...
1. ... the volumetric phase fractions (continuity equations).
2. ... the velocities (momentum equations).
3. ... the pressure (pressure equation).
Is it the same procedure as for twophaseEulerFOAM desribed in
http://powerlab.fsb.hr/ped/kturbo/Op...chePhD2002.pdf
greetings
maybee
maybee is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Asymmetrical solution using RANS Marli FLUENT 2 January 9, 2015 09:26
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
