-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Diffusive flux in interMixingFoam (http://www.cfd-online.com/Forums/openfoam-programming-development/89200-diffusive-flux-intermixingfoam.html)
oswald June 7, 2011 11:12
Dear Foamers,
this is my first thread started, so here is a little introduction: I've been working with OF for almost one year now and my current version is 1.7.0. My main interests are multiphase flows and in the last time a little bit of mixing.
I've got a little question about the diffusive flux for alpha2->alpha3 in interMixingFoam. In alphaEqns.H there is the line
phiAlpha2 -= fvc::interpolate(Dc32)*mesh.magSf()*fvc::snGrad(alpha1)
Should it not be snGrad(alpha2) or snGrad(alpha3) at the end?
Sorry for bothering you if I'm wrong and thanks for your help in advance!
Best regards,
oswald
vonboett May 24, 2013 09:12
bug in interMixingFoam?
Any news? I wonder about the same thing. Simulating channel flow with the three phases, alpha3 seems to dissolve slowly into alpha1 while alpha2 stays niceley seperated from alpha1 as it should! If anyone please could have a look befor I do a bug report?
vonboett June 4, 2013 10:46
...and by the way, maybe someone could shed some light on:
// Add the diffusive flux for alpha3->alpha2
phiAlpha2 -= fvc::interpolate(Dc32)*mesh.magSf()*fvc::snGrad(al pha3);
were only Dc32 adds to diffusive flux but followed by:
// Solve for alpha2
fvScalarMatrix alpha2Eqn
fvm::ddt(alpha2)
+ fvc::div(phiAlpha2)
- fvm::laplacian(Dc23 + Dc32, alpha2)
Dc23 and Dc32 contribute. I am sorry if this is trivial, maybe I am a bit confused looking and comparing the different multiphase solvers. Inspired by twoLiquidMixingFoam I just
gave it a try to add the influence of turbulence via the turbulent schmidt number to the diffusion in interMixingFoam, and I noticed I have to account for it in the diffusive flux for alpha3->alpha 2 and in the alpha2 equation.
vonboett June 26, 2013 05:29
improved interMixingFoam in respect to mixing
2 Attachment(s)
So here is my adjusted alphaEqns.H and createFields.H with the following features:
-the two liquids are solved for and alpha1 is derived from 1 - alpha2 - alpha3
-the diffusive flux is added by *mesh.magSf()*fvc::snGrad(alpha2); and *mesh.magSf()*fvc::snGrad(alpha3); respectiveley, no alpha1 used here (still think this is a bug in interMixingFoam)
-eddy diffusion is included either by local turbulence viscosity and turbulent Schmidt number, or for laminar flow by local vorticity (grid dependent!) and mixing length derived in dependency to distance to boundary. So the reciprocal of the turbulent Schmidt number is introduced to transportProperties as well as a mixingLengthFactor which can be seen as an adjustable von Karman constant.
alphaEqns.H:
word alphaScheme("div(phi,alpha)");
word alpharScheme("div(phirb,alpha)");
surfaceScalarField phir
IOobject
"phir",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
interface.cAlpha()*mag(phi/mesh.magSf())*interface.nHatf() //phase fraction * flux/cellsurface * cell face unit interface normal flux
// calculate vorticity to increase diffusion at regions of high vorticity
volScalarField vorticityMag
IOobject
"vorticityMag",
runTime.timeName(),
mesh,
IOobject::NO_READ
mag(fvc::curl(U))
for (int gCorr=0; gCorr<nAlphaCorr; gCorr++)
// Create the limiter to be used for all phase-fractions
scalarField allLambda(mesh.nFaces(), 1.0);
// Split the limiter into a surfaceScalarField
slicedSurfaceScalarField lambda
IOobject
"lambda",
mesh.time().timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE,
false
mesh,
dimless,
allLambda,
false // Use slices for the couples
// Create the complete flux for alpha2
surfaceScalarField phiAlpha2
fvc::flux
phi,
alpha2,
alphaScheme
+ fvc::flux
-fvc::flux(phir, alpha1, alpharScheme),
alpha2,
alpharScheme
+ fvc::flux
-fvc::flux(-phir, alpha3, alpharScheme),
alpha2,
alpharScheme
// Create the bounded (upwind) flux for alpha2
surfaceScalarField phiAlpha2BD
upwind<scalar>(mesh, phi).flux(alpha2)
// Calculate the flux correction for alpha2
phiAlpha2 -= phiAlpha2BD;
// Calculate the limiter for alpha2
MULES::limiter
allLambda,
geometricOneField(),
alpha2,
phiAlpha2BD,
phiAlpha2,
zeroField(),
zeroField(),
1,
0,
3
// Construct the limited fluxes
phiAlpha2 = phiAlpha2BD + lambda*phiAlpha2;
// Create the complete flux for alpha3
surfaceScalarField phiAlpha3
fvc::flux
phi,
alpha3,
alphaScheme
+ fvc::flux
alpha3,
alpharScheme
// Create the bounded (upwind) flux for alpha3
surfaceScalarField phiAlpha3BD
upwind<scalar>(mesh, phi).flux(alpha3)
// Calculate the flux correction for alpha3
phiAlpha3 -= phiAlpha3BD;
// Further limit the limiter for alpha3
MULES::limiter
allLambda,
alpha3,
phiAlpha3BD,
phiAlpha3,
zeroField(),
zeroField(),
1,
0,
3
phiAlpha3 = phiAlpha3BD + lambda*phiAlpha3;
volScalarField Dc23(D23*max(alpha3, scalar(0))*pos(alpha2));
volScalarField Dc32(D23*max(alpha2, scalar(0))*pos(alpha3));
/* calculate the turbulent mixing, orienting by P. Nielsen et al.:
"Turbulent diffusion of momentum and suspended particles: A finite-mixing-length theory" (2004) Physics of Fluids Vol. 16 Issue 7
but take the vorticity at the cell times the average cell size as a replacement for the settling velocity used in the paper. For mixing length:
By assuming that the mixing length is proportional to the distance to the bottom,
lm=κz (κ is von Karman constant, z is height above bed),Prandtl obtained the logarithmic velocity profile.
Assume the same but replace the von Karman constant with a model parameter, analog to the turbulent Schmidt number. See also Debris Flow: Mechanics, Prediction and Countermeasures (2007) by
T. Takahashi, chapter Models for Mechanics of Flow, p.83*/
volScalarField Vc23(mixingLengthFactor*vorticityMag*cellDiameter* wallDistance*max(alpha3, scalar(0))*pos(alpha2));
volScalarField Vc32(mixingLengthFactor*vorticityMag*cellDiameter* wallDistance*max(alpha2, scalar(0))*pos(alpha3));
Info<< "Phase-diffusion due to vorticity = "
<< " Min(vorticityMag*cellsize*wallDistance*mixingLengt hFactor) = " << (min(Vc32)).value()
<< " Max(vorticityMag*cellsize*wallDistance*mixingLengt hFactor) = " << (max(Vc32)).value()
<< endl;
phiAlpha2 -= fvc::interpolate(Dc32 + Vc32 + alphatab*turbulence->nut() )*mesh.magSf()*fvc::snGrad(alpha2);
// Solve for alpha2
fvm::ddt(alpha2)
+ fvm::SuSp(-fvc::div(phi), alpha2)//chegdan on October 16, 2010: http://www.cfd-online.com/Forums/ope...culations.html
- fvm::laplacian(Dc32 + Dc23 + Vc23 + Vc32 + alphatab*turbulence->nut() , alpha2)
alpha2Eqn.solve();
// Add the diffusive flux for alpha2->alpha3
phiAlpha3 -= fvc::interpolate(Dc23 + Vc23 + alphatab*turbulence->nut())*mesh.magSf()*fvc::snGrad(alpha3);
// Solve for alpha3
//alphatab is the reciprocal of the turbulent Schmidt number, introduce turbulent mixing see book by Fox "computational models for turbulent reacting flows"
fvScalarMatrix alpha3Eqn
fvm::ddt(alpha3)
+ fvc::div(phiAlpha3)
+ fvm::SuSp(-fvc::div(phi), alpha3)//chegdan on October 16, 2010: http://www.cfd-online.com/Forums/ope...culations.html
- fvm::laplacian(Dc23 + Dc32 + Vc23 + Vc32 + alphatab*turbulence->nut() , alpha3)
alpha3Eqn.solve();
// Construct the complete mass flux */
rhoPhi =
(phiAlpha3 + alpha3Eqn.flux())*(rho3 - rho1)
+ (phiAlpha2 + alpha2Eqn.flux())*(rho2 - rho1)
+ phi*rho1;
alpha1 = 1.0 - alpha2 - alpha3;
Info<< "Mud phase volume fraction = "
<< alpha2.weightedAverage(mesh.V()).value()
<< " Min(alpha2) = " << min(alpha2).value()
<< " Max(alpha2) = " << max(alpha2).value()
<< endl;
Info<< "Granular phase volume fraction = "
<< alpha3.weightedAverage(mesh.V()).value()
<< " Min(alpha3) = " << min(alpha3).value()
<< " Max(alpha3) = " << max(alpha3).value()
<< endl;
Info<< "Phase-diffusion due to turbulence = "
<< " Min(alphatab*turb->nut()) = " << (min(turbulence->nut())*alphatab).value()
<< " Max(alphatab*turb->nut()) = " << (max(turbulence->nut())*alphatab).value()
<< endl;
createFields.H
Info<< "Reading field p_rgh\n" << endl;
volScalarField p_rgh
IOobject
"p_rgh",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
Info<< "Reading field alpha1\n" << endl;
volScalarField alpha1
IOobject
"alpha1",
runTime.timeName(),
mesh,
mesh
Info<< "Reading field alpha2\n" << endl;
volScalarField alpha2
IOobject
"alpha2",
runTime.timeName(),
mesh,
mesh
Info<< "Reading field alpha3\n" << endl;
volScalarField alpha3
IOobject
"alpha3",
runTime.timeName(),
mesh,
mesh
alpha3 == 1.0 - alpha1 - alpha2;
Info<< "Reading field U\n" << endl;
volVectorField U
IOobject
"U",
runTime.timeName(),
mesh,
mesh
#include "createPhi.H"
threePhaseMixture threePhaseProperties(U, phi);
const dimensionedScalar& rho1 = threePhaseProperties.rho1();
const dimensionedScalar& rho2 = threePhaseProperties.rho2();
const dimensionedScalar& rho3 = threePhaseProperties.rho3();
dimensionedScalar D23(threePhaseProperties.lookup("D23"));
// Read the reciprocal of the turbulent Schmidt number
dimensionedScalar alphatab(threePhaseProperties.lookup("alphatab"));
// Read a constant in analogy to the von Karman constant, to gain mixing length in dependency to cell-distance to wall
dimensionedScalar mixingLengthFactor(threePhaseProperties.lookup("mi xingLengthFactor"));
// calculate an average cell size used to gain a mixing velocity in each cell from cell-vorticity, applied for eddy diffsuion
volScalarField cellDiameter(pow(0.1666*fvc::surfaceSum(mesh.magSf ()), 0.5));
// get cell distances to walls
volScalarField wallDistance(cellDiameter);
const polyBoundaryMesh& patches = mesh.boundaryMesh();
forAll(wallDistance, cellI)
// get the position for the particle
const vector& position = mesh.C()[cellI];
scalar distance = GREAT;
// loop over all patches
forAll(patches, patchI)
//if (isA<wallPolyPatch>(patches[patchI])) // not working
const polyPatch& patch = patches[patchI];
const vectorField& n = patch.faceNormals();
const vectorField& C = patch.faceCentres();
forAll(C, i)
vector normal = n[i]/mag(n[i]);
//scalar di = mag(position - C[i]); // distance to face centre
scalar di = mag( normal & ( position - C[i] ) );
distance = min(distance, di);
wallDistance[cellI] = distance;
// Info << "distance to wall is " << distance << endl;
// Need to store rho for ddt(rho, U)
volScalarField rho
IOobject
"rho",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT
alpha1*rho1 + alpha2*rho2 + alpha3*rho3,
alpha1.boundaryField().types()
rho.oldTime();
// Mass flux
// Initialisation does not matter because rhoPhi is reset after the
// alpha solution before it is used in the U equation.
surfaceScalarField rhoPhi
IOobject
"rho*phi",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
rho1*phi
// Construct interface from alpha distribution
threePhaseInterfaceProperties interface(threePhaseProperties);
// Construct incompressible turbulence model
autoPtr<incompressible::turbulenceModel> turbulence
incompressible::turbulenceModel::New(U, phi, threePhaseProperties)
Info<< "Calculating field g.h\n" << endl;
volScalarField gh("gh", g & mesh.C());
surfaceScalarField ghf("ghf", g & mesh.Cf());
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
IOobject::NO_READ,
p_rgh + rho*gh
label pRefCell = 0;
scalar pRefValue = 0.0;
setRefCell
p,
p_rgh,
mesh.solutionDict().subDict("PIMPLE"),
pRefCell,
pRefValue
if (p_rgh.needReference())
p += dimensionedScalar
"p",
p.dimensions(),
pRefValue - getRefCellValue(p, pRefCell)
p_rgh = p - rho*gh;
IObasicSourceList sources(mesh);
Attatched a comparison of the dambreak tutorial at t= 0.75 without turbulence but with mixingLengthFactor 0.4 increasing the diffusion due to vorticity. Anyone knows a testCase to test the solver, or maybe someone could check the code?
vonboett July 2, 2013 03:26
Ok, in larger scale and longer runs, alpha2 and alpha3 diffuse into alpha1 when applying diffudive terms, and the massbalance (due to bounding?) is not quite right yet in the suggestion above because the liquid volume phase goes down continuously. But guess what, the regular interMixingFoam faces the same problem...
Any hints? I will try out what happends without bounding of alpha2 or alpha3.
vonboett September 26, 2013 05:11
Well, it works by now conserving the mass of the two liquids and keeping their concentrations bound between 0 and 1. But I had to introduce a solving step for the air phase. Will post the code here when tests are finished.
Mahyar Javidi February 5, 2014 12:18
Showing both of the mixing fluids
Hi
I was wondering if anybody knows how to show both of the phases that are mixing with each other (in the interMixingFoam solver) in the paraview simultaneously.
Regards
Mahyar
vonboett February 6, 2014 08:44
Well I make a threshold for alpha1 (non-mixing phase) from 0 (or maybe -0.0001) to 0.5 and color it by alpha2, then I take a threshold of this threshold for alpha3 (full range from min to max) and set the representation to Wireframe and color it by alpha3
Mahyar Javidi February 9, 2014 15:00
Thanks for your reply. I appreciate it.
Mahyar
skykzhang June 17, 2014 05:13
about the solve of interMixingFoam
these days i am working in this solver. openFoam 1.6-ext. the solver interMixingFoam have no UEqn.H, so i try to look for it in the .dep file,
interMixingFoam.dep: $(WM_PROJECT_DIR)/applications/solvers/multiphase/interFoam/UEqn.H
interMixingFoam.dep: $(WM_PROJECT_DIR)/applications/solvers/multiphase/interFoam/pEqn.H
$(OBJECTS_DIR)/interMixingFoam.o: $(EXE_DEP)
@SOURCE_DIR=.
SOURCE=interMixingFoam.C ; $(Ctoo)
does it call to the UEqn.H from interFoam? interFoam is a two phase solver and interMixingFoam is three phase solver, the alpha in interFoam just one and in interMixing that are alpha1, alpha2 and alpha3. So can you tell me why the UEqn.H can call from interFoam??
vonboett June 17, 2014 05:38
1 Attachment(s)
Hi Zhang,
yes it calls UEqn.H from interFoam, thats OK since one solves only one phase-averaged Navier-Stokes equation neglecting drag between phases. I would like to know who maintains this solver. To my experience, it is not performing well in mass conservation or in respect to negative phase concentrations. Let me attatch my version of alphaEqns.H that gives higher priority to correct handling of the mixing fluid, shifting the weak parts to the air phase. This is for OF 2.2.x but a version for the newes OF exists. In my case, diffusion is not so important so I don't really care about the diffusive flux. (Sorry for not yet removing old comments from the code)
skykzhang June 17, 2014 07:27
Originally Posted by vonboett (Post 497348)
Hi Zhang,
thank u for your reply, vBoetticher. i have known the reason why it can call the UEqn.H from the interFoam.
and from your replies above, we can see you have done a lot of job about the solver.
the same to u , i have not know the guy who write the solver. from the origin of OF, i guess you can ask Hrvoje Jasak, maybe you can get the answer you need. good luck!
skykzhang
dzordz July 19, 2016 05:43
Originally Posted by oswald (Post 310887)
Dear Foamers,
Best regards,
oswald
I think I'm a little late to this party, but I hope it is still relevant. I have been playing around with interMixingFoam for a while now and since I had problems with spontaneous creation of a third phase plus not a sharp interface between third - diffusive and first-non diffusive phase (just like tutorial) I went digging into the source code.
So to answer your question. The way it is written with alpha1 is ok.
It is because you have a 3 phase system with condition alpha1+alpha2+alpha3=1.
So if you rewrite your code line you would get Dc32*grad(alpha1)=Dc32*grad(1-alpha2-alpha3)=-Dc32*grad(alpha2)-Dc32*grad(alpha3). Now the trick is in the way the laplacian part of differential equation is defined: laplacian(Dc23+Dc32, alpha2). this can be written in terms of divergence: div((Dc23+Dc32)*grad(alpha2)). When you combine this with the divergence term in diff. eq. and subtract the equal parts you get (here written only the diffusion part): div(Dc23*grad(alpha3) - Dc32*grad(alpha2). Exactly what you wanted - two diffusion fluxes.
Now if you would write down equations for alpha3 you would be left with div(Dc32*grad(alpha2) - Dc23*grad(alpha3)). Exactly the opposite fluxes. And now if you add the fluxes, the would sum to zero. Exactly as they should in the closed system.
Sorry for the long response. Hope it helps. :)
