Home > Forums > OpenFOAM Programming & Development
Need help evaluating field by interpolation with a "lookup table"
Old   June 24, 2011, 13:39
Default Need help evaluating field by interpolation with a "lookup table"
John Hawk
JohnRHawk is on a distinguished road
I am attempting to create a solver which determines the internalField values of a certain scalar field (effectively a field of coefficients "C") based on interpolative evaluation of another scalar field's internal values.
Foe clarification, if I have a normally-generated (e.g. time-stepping, with boundary conditions, evaluated using .solve) scalar field "T," and a .csv file (or other format) of paired values "Cref" vs. "Tref" for the effective range of "T," I need to evaluate "C" at every cell where "T" is already available by interpolating the Cref/Tref data for every value of "T"s internal field, then storing the field "C" for the time step to later perform other calculations.
I have already explored using both Foam::interpolateXY and Foam:interpolationTable to attempt this task, but I've encountered a unique problem with each:
interpolateXY apparently operates only on "fields," whereas my data is in the form of "lists"; since the Cref/Tref data have no dependence (or information) regarding spatial position. As a result I believe I've failed to understand completely this function's intended use, and now suspect it has nothing to do with what I'm attempting.
Using interpolationTable instead yields me a new problem, in which I can't seem to manage accessing and writing to the internalField lists of either "T" or "C" directly.
For example, I would ideally have code similar to the following:
interpolationTable lookup(filename); //initialize my interpolationTable with data from file
(do other things)
for (Tnum = 0; Tnum <= T.internalfield.size(); Tnum++) //for each value in T
C.internalField[Tnum] = lookup(T.internalField[Tnum]); //evaluate C for this value of T
However, I can't seem to access internalField list elements by array subscript.
Even the following simple test:
info << T.internalField[1]
fails to compile, throwing the error
error: invalid types <unresolved overloaded function type>[int] for array subscript
I would appreciate it if anyone could either alert me to my error, or suggest a better method for evaluating "C" using the interpolation data.
(Thanks!)
JohnRHawk is offline   Reply With Quote
Old   June 28, 2011, 12:30
John Hawk
Additionally, I'm having some difficulty handling deconstruction of the "interpolationTable," but this is a secondary issue. Any help with the original problem would be greatly appreciated!
Old   June 28, 2011, 13:27
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
You need to put in brackets with no arguments to access the internal field function i.e.
info << T.internalField()[1]
Hope it helps,
Philip
bigphil is offline   Reply With Quote
Thread Tools
Trackbacks are On
problems after decomposing for running alessio.nz OpenFOAM 6 December 23, 2015 15:27
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Field interpolation AlmostSurelyRob OpenFOAM 0 February 2, 2011 10:48
Field interpolation in mesh points code jzlam OpenFOAM Post-Processing 2 December 14, 2010 17:48
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
