-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Pasing Pointers to functions solve and linearInterpolate (http://www.cfd-online.com/Forums/openfoam-programming-development/90341-pasing-pointers-functions-solve-linearinterpolate.html)
arkangel July 7, 2011 09:05
Dear All,
I don't think this was asked before. I am using another pakage to link against the OpenFOAM lib , I decided that the best way would be to use a pointer to the fields as global variables. so far all seems to be working well but I think (i hope I am wrong) I reach a deadlock
volScalarField *pT;
Time *pRT ;
//Function 1
void Init(){
    pT=new Foam::volScalarField
        IOobject
            "T",
            pRT->timeName(),
            *pMesh
        *pMesh
// This woks so far perfectly  i e: pT->internalField, pMesh->C(), etc
// Function 2
void solveEQ(){
  while (pRT->loop())
      solve(
                fvm::laplacian(1.0, *pT)  //DOES NOT WORK
      pRT->write();
I tried with the LaplacianFoam and I got this:
finiteVolume/lnInclude/fvmLaplacian.C:185: error: in passing argument 2 of ‘Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::dimensioned<Type2>&, Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = double, GType = double]
So the Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>& thinks that *pT is other type. In fact is volScalarField (or VolVectorField if i have to use vec field)
The same is
    linearInterpolate((*pT)) & pMesh->Sf()
error: no matching function for call to ‘linearInterpolate(Foam::tmp<Foam::Field<Foam::Ten sor<double> > >)’
Is there A way to force laplacian (or other operator) to accept my syntax
Thanks for you Help
