WM_COMPILE=Debug, gdb reverse-step breaks
Has anyone had success with the reverse-* commands from the gdb 7?
This is what happens to me: Code:
(gdb) reverse-step Code:
[Thread debugging using libthread_db enabled] |
i maybe completely wrong, but I read at http://openfoamwiki.net/index.php/Ho...M_with_Eclipse =>GNU Debugger (gdb) version: 6.8 Please be careful choosing the right gdb version! In gdb 7.x a bug seems to occur while debugging and monitoring the variables. So this might be case for you as well. Can you try the older gdb 6 version? |
however : I'm not using Eclipse, I'm running on Vim + gdb in the console. I'm just keeping things simple, because I'm stupid (KISS). :D There's no bug, it's just that the reverse-* commands in gdb do not work well with multithreading. I need to see how to exclude libthread from being linked during compilation. I have tried setting the path to libthread in gdb t to the wrong value, but then it got reverted to the system lib. I'll probably dig into this eventually, it would just be nice if I don't have to do so, if someone has already found a way to use reverse-* without libthread. Older version: only gdb 7.* support reverse-* commands. |
