starting off with OpenFOAM
Old   February 7, 2011, 06:31
Default starting off with OpenFOAM
Sibusiso Mavuso
semaviso is on a distinguished road
HI GUYS
I am a new user of OpenFOAM and would like to solve an unsteady energy equation for a compressible gas through a porous media.
I have basic knowledge of C++ prograqming, please help.
thanx in advance
semaviso is offline   Reply With Quote
Old   February 8, 2011, 02:24
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hi semaviso,
have a look into the rhoReactingFoam application to see how its done there.
This is the general way to go. Look whether theres something you need.
Best
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   February 16, 2011, 08:21
Sibusiso Mavuso
thanx Kathrin
I checked it out and now I want to understand the meaning of:
00008 volScalarField rUA = 1.0/UEqn.A();
00009 U = rUA*UEqn.H();
from rhoReactingFoam/pEqn.H
How can I write Darcy's formula (U_gas = (-permK/mu)*grad(p) )
U_gas being the gas flux or velocity in m/s
in OpenFOAM to use with the mass transport equation.
thanx again for your help.
Old   February 16, 2011, 09:48
Kathrin Kissling
1. Question
This is part of the pressure velocity coupling see:
http://powerlab.fsb.hr/ped/kturbo/Op...jeJasakPhD.pdf
for details.
What is done:
UEqn.A() gives you the central coefficient of the the fvMatrix (fv=finiteVolume) UEqn.
UEqn.H() gives you the H operator which is basically
H(UEqn)=source(UEqn)-diagonal(UEqn)U
in that way the velocity is evaluated by U = rUA*UEqn.H();
ok?
2. Question
I'm not really sure what your trying to do. Can you specify a little?
Do you want to use your U_gas in the continuity equation?
Why?
Best
Kathrin
Old   February 16, 2011, 16:37
Cyp
Cyprien
Cyp is on a distinguished road
Hi semaviso!
There are several way to solve your problem:
- either your add a source term in an existing momentum equation (for example rhoReactingFoam as suggested by Kathrin, or may be rhoPisoFoam will be easier to begin) :
    fvVectorMatrix UEqn
        fvm::ddt(rho, U)
      + fvm::div(phi, U)
      + turbulence->divDevRhoReff(U)
        rho*g
      - fvm::Sp(mu/K,U)
or you code your own porous media solver. For a incompressible flow, you have to solve the following diffusion equation on P variable :
solve
    fvm::laplacian(-K/mu,P)
It is not very difficult to adapt this porous solver to compressible flow (Darcy's law replaced within continuity equation).
Regards,
Cyp
Cyp is offline   Reply With Quote
Old   February 17, 2011, 02:40
Kathrin Kissling
Maybe you want to have a look into rhoPorousFoam. I never worked with it. But it sounds promising.
Best
Kathrin
Old   February 22, 2011, 08:21
Sibusiso Mavuso
thanx guys it worked.
another question is, how do I add a source term to an energy balance equation if the source term is as follows: [deltaH - T(Cp_ss - Cp_s)]
deltaH : Heart of reaction
Cp_ss : saturated solid (porous media) heat capacity
Cp_s : solid (porous media) heat capacity
Old   February 23, 2011, 02:10
Kathrin Kissling
Which variable are you solving for in your energy equation T or h?
Best Kathrin
Old   February 24, 2011, 03:09
Sibusiso Mavuso
Hi Kathrin
I want "T" but I had used the energy equation with "h".
since h = Cp*T.
thanx in advance
Old   February 25, 2011, 04:07
Kathrin Kissling
could you post the equation you have?
Do you reconstruct the Temperature from the energy?
Best
Kathrin
Old   February 25, 2011, 04:38
Sibusiso Mavuso
the equation is from http://onlinelibrary.wiley.com/doi/10.1002/er.919/pdf
equation 1 of this publication.
I have decided to use h becouse i found a lot of hEqn.H file that I think have something almost similar to this equation.
Old   February 25, 2011, 04:47
Cyp
Cyprien
Hi semaviso!
You should try something like that:
fvm::ddt(rho*Cpg,T)
+fvm::div(phi,T)
-fvm::laplacian(lambda,T)
fvm::Sp(m_dot*(Cpg-Cps),T)
-m_dot*dH0
where the flux phi is defined as:
surfaceScalarField phi = rho*Cpg*linearInterpolate(U)&mesh.Sf();
(if rho or Cpg are volScalarField, you must use:
surfaceScalarField phi = fvc::interpolate(rho)*fvc::interpolate(Cpg)*linearInterpolate(U)&mesh.Sf();
Best Regards,
Cyp
Old   August 2, 2011, 07:50
Sibusiso Mavuso
thank you a lot,
I have been tryin to modify the porousExplicitSourceReactingParcelFoam to solve for a compressible gas inside a porous reactor.
Regards,
SBU
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 09:33
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
