August 9, 2011, 05:35 |
Assigning objects to cells
Hisham Elsafti
Rep Power: 17 |
Hi
I want to develop a class that defines material behaviour for a stress analysis solver. I need to assign an object to each finite volume. Also, I need to extract numerical values from tensor/vector/scalar field (for each cell), use them inside the object functions then return these values to a variable field (a tensor field) (during the time step loop). How is it possible to loop the control volumes? I would appreciate it if I get help on how to do that or where to look for answers. Thanks |
August 9, 2011, 14:30 |
#2 | |
Rep Power: 14 |
Hello Hisham,
I am not sure if I understand your question. This should work: Quote:
Gunnar |
objects to cells |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
