Conditional solving of transport equations
Old   June 18, 2018, 06:02
Default Conditional solving of transport equations
Upuli
upuli is on a distinguished road
Hi
I have seen some posts on conditional solving of transport equation.Many posts mentioned the use of interfoam solver. But I am not clear how this can be done. I have the following transport equation
fvScalarMatrix TsEqn
       fvm::ddt(Ts)
    + fvm::div(phibed,Ts)
          - fvc::laplacian(DTs,Ts)
TsEqn.solve();
I want to solve only in a region where solid is present(in the same mesh). I have another volume scalar field solid which has the value of 1 within the solid region and which has the value of 0 when there are no solids. I used icoFoam solver to develop the equation. How can I solve the above TsEqn within the solid region(solid=1).
Thanking You
Upuli
upuli is offline   Reply With Quote
Old   June 18, 2018, 16:33
Vince
hyFoam is on a distinguished road
Hi Upuli,
Isn't the solution identical to the one in this post:
Fix velocity value
i.e., removing elements from the fvMatrix based on the value taken by the scalarField that is marking fluid and solid regions.
Thanks,
Vince
hyFoam is offline   Reply With Quote
Old   June 18, 2018, 23:06
Upuli
Hi
Thank you verymuch. It is same as the thread you mentioned. I will try it. But I am also curious on how this is done in InterFoam solver. There is a thread on that conditional solving of transport equation. But it is not clear to me.
Old   July 10, 2018, 02:06
Upuli
Hi
My solids field is moving along x direction at a constant velocity. I used the below code to solve the TsEqn within the solid field and it doesnot seem to be move when the solid field move in the x direction.
DynamicList<label> removedCellsFromMatrix;
DynamicList<scalar> valuesToImpose;
forAll(solid, celli)
        if(solid[celli] < 1)
            removedCellsFromMatrix.append(celli);
forAll(removedCellsFromMatrix, i)
        valuesToImposemass.append(300.0);
       fvm::ddt(Ts)
TsEqn.solve();
TsEqn.setValues(removedCellsFromMatrix, valuesToImpose);
pre.cjk { font-family: "Nimbus Mono L", monospace; }p { margin-bottom: 0.1in; line-height: 120%; }a:link { }
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
