-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Remove particle in solidParticleFoam (http://www.cfd-online.com/Forums/openfoam-programming-development/91441-remove-particle-solidparticlefoam.html)
shchepan August 11, 2011 02:07
I am working with solidParticle library within OpenFOAM-1.6. I coded additional function, which change particle diameter due to the diffusion process. This function is implemented in solidParticleFoam before move function.
Now I need to remove from the cloud particles with diameters close to zero. Is there any function to remove (delete) particle from the cloud?
steffi_geier August 11, 2011 09:25
Hi Mihails,
I think you can delete particles if you change
td.keepParticle = true;
to
td.keepParticle = false;
for the particles which are too small for you.
You will find the line
within the function "move".
Hope this will help you
Steffi
shchepan August 11, 2011 10:41
Dear Steffi,
thank you for answer.
Line td.keepParticle = true; is situated in the begin of move function. If I'll code somewhere in this function
HTML Code:
if (d_<=0.0)
it will remove this particle only ones for move function. Every next step move function will check this if again. But I want totally delete this particle.
I created new function sizeEvolution(), which has no argument of td. This function is implemented in the solver before move function. So I want to delete particles with zero size within sizeEvolution function. How can I do it?
AMahrla August 12, 2011 04:50
Possibly you could try to use the "deleteParticle" function of basic cloud (find the definition in Cloud.C or here in the doxygen) ?
shchepan August 12, 2011 07:29
Perfectly! Thank you, Astrid!
mayank.dce2k7 September 8, 2013 18:33
Can any of you tell me how to calculate/count particle escaping from a patch in solidParticleFoam?
Regards,
Mayank
houwy March 28, 2014 08:25
Hello! I want change particle diameter due to the diffusion process. How can I do it! What function did you add.
houwy April 14, 2014 09:56
Originally Posted by mayank.dce2k7 (Post 450545)
Regards,
Mayank
Have you solved your problem?
mayank.dce2k7 April 16, 2014 17:29
Yaa, I did. But I am using icoUncoupledKinematicPartcelFoam. It has in-built functionality of counting particles. I was unable incorporate that functionality in solidParticleFoam though.
