Home > Forums > OpenFOAM Programming & Development
Need Help w. Darcy Boussinesq Equ.
Like Tree2Likes
Old   October 12, 2011, 14:26
Cyp
Cyprien
Cyp is on a distinguished road
Try to impose a delta P (fixedValue for inlet and fixedValue = 0 for outlet).
If you want a immobile system, I think a zeroGradient for inlet and fixedValue = 0 for outlet should work...
Note that since we solve only the pressure and the temperature in the solver, the boundary condition for the velocity field are not accounted for.
Cyp is offline   Reply With Quote
Old   October 12, 2011, 15:33
Werner
nep101 is on a distinguished road
The problem we try to solve is this onset of thermal convection in a porous cylinder with conducting wall. So there is no inlet or outlet.
I also thougt that there is maybe a problem with the boundaries. In most cases when i got a floiting point exception, it was a problem with the bopundaries.
But the mainproblem is (i think), that the pressureequation is not properly solved or coded.
Cheers
nep101 is offline   Reply With Quote
Old   October 12, 2011, 23:22
Tom
TomB is on a distinguished road
Gday Cyp and Nep
Thanks so much for your input and collaboration, this has been a huge help to me.
I re-wrote my solver, based on the laplacianFoam. I wrote up some comments along the way.
I'd like to look into it to 'see' how pressure and velocity are linked. That is what I will do next, to make sure its working as expected at this stage.
I'm going to try to set up a pressure gradient with the boundary conditions as you two were discussing.
my method is
break the problem into a number of smaller steps on Cyps guidance
1. solve simple Darcy's Law, based on laplacianFoam (exclude the Temp term)
2. include a scalar transport equation
3. then look at adding temperature
4. then look at correcting T,U
5. add the (Ra*T*k) term to the U eqn
Cheers
Tom
TomB is offline   Reply With Quote
Old   October 13, 2011, 09:25
Werner
Hi Tom,
wich equation you want to solve?
Is it necessary to handle the equations in a dimensionless form.
What i try to say is, that MAYBE (im no Pro in Openfoam) it is not so easy to handle nondimensionless equations in Openfoam.
Btw how is it going on??
Cheers
Werner
Old   October 13, 2011, 09:52
Tom
Hi Werner
Im solving for convection in a box of porous media. Sounds very similar to your problem otherwise. I do want to do it in terms of the Rayleigh number and non-dimensional temperature.
I will fudge the units if i have to ! it seems to work ok with the dimensions switched off in the /opt location. I just dont like fiddling with those settings bcoz im an amatuer.
At the moment, i am trying to make the darcyLaplacian solver with some temperature terms added. I seem to be missing a curly bracket, but I'm not sure where.
Did you get a pressure gradient working?
Cheers
Tom
edit
I added my solver and the TEqn it needs. Im having issues now with boundaryConditions. It doesnt like taking the gradient of a calculated internalField.
File Type: h TEqn.H (181 Bytes, 11 views)
Old   October 13, 2011, 10:16
Werner
HI Tom,
no i dont got my continuity equation working correctly.
Send me your solver, maybe i find your problem.
Cheers
Werner
Old   October 13, 2011, 10:40
Tom
HI Werner
my solver is in the post above. I added another curly bracket and it works, but it doesnt make sense. i use bracket matching and indenting so i should be able to see where its missin..
I think my set up needs a setFields, so that the initial pressure is set before it starts to solve the fvm::laplacian(p)
Old   October 13, 2011, 10:43
Werner
Hi Tom,
which vers. of OF you use?
Old   October 13, 2011, 11:19
Tom
Hi Nep
Im using OpenFoam 2.0.1
Im having an issue with the boundary. I get the error message,
gradientInternalCoeffs cannot be called for a calculatedFvPatchField.
it suggests I migh be using a default boundary condition. I copied the boundary conditions from buoyantBoussinesqSimpleFoam
I'll work on this some more tmw ( about 8 hours from now zzzzzzzzzzzzzzzz)
Old   February 21, 2014, 13:11
Marcus Letzel
letzel is on a distinguished road
I am just wondering whether this old thread has ever been solved. I think my thread may need a similar solution.
Cheers,
Marcus
letzel is offline   Reply With Quote
Thread Tools
Trackbacks are On
Boussinesq Assumption tstorm FLUENT 3 October 26, 2009 06:11
Boussinesq lucifer FLUENT 0 September 26, 2009 09:31
Outflow boundary condition for a boussinesq fluid lin OpenFOAM Running, Solving & CFD 19 July 31, 2009 08:50
Natural Convection in a storage tank - boussinesq? Jervds CFX 5 November 19, 2008 07:01
Darcy + multiphase? George Bergantz CD-adapco 1 March 14, 2002 06:07
