October 12, 2011, 14:26 |
#21 |
Cyprien
Rep Power: 18 |
Try to impose a delta P (fixedValue for inlet and fixedValue = 0 for outlet).
If you want a immobile system, I think a zeroGradient for inlet and fixedValue = 0 for outlet should work... Note that since we solve only the pressure and the temperature in the solver, the boundary condition for the velocity field are not accounted for. |
October 12, 2011, 15:33 |
#22 |
Werner
The problem we try to solve is this onset of thermal convection in a porous cylinder with conducting wall. So there is no inlet or outlet.
I also thougt that there is maybe a problem with the boundaries. In most cases when i got a floiting point exception, it was a problem with the bopundaries. But the mainproblem is (i think), that the pressureequation is not properly solved or coded. Cheers |
October 12, 2011, 23:22 |
#23 |
Tom
Gday Cyp and Nep
Thanks so much for your input and collaboration, this has been a huge help to me. I re-wrote my solver, based on the laplacianFoam. I wrote up some comments along the way. I'd like to look into it to 'see' how pressure and velocity are linked. That is what I will do next, to make sure its working as expected at this stage. I'm going to try to set up a pressure gradient with the boundary conditions as you two were discussing. my method is break the problem into a number of smaller steps on Cyps guidance 1. solve simple Darcy's Law, based on laplacianFoam (exclude the Temp term) 2. include a scalar transport equation 3. then look at adding temperature 4. then look at correcting T,U 5. add the (Ra*T*k) term to the U eqn Cheers Tom |
October 13, 2011, 09:25 |
#24 |
Werner
Hi Tom,
wich equation you want to solve? Is it necessary to handle the equations in a dimensionless form. What i try to say is, that MAYBE (im no Pro in Openfoam) it is not so easy to handle nondimensionless equations in Openfoam. Btw how is it going on?? Cheers Werner |
October 13, 2011, 09:52 |
#25 |
Tom
Hi Werner
Im solving for convection in a box of porous media. Sounds very similar to your problem otherwise. I do want to do it in terms of the Rayleigh number and non-dimensional temperature. I will fudge the units if i have to ! it seems to work ok with the dimensions switched off in the /opt location. I just dont like fiddling with those settings bcoz im an amatuer. At the moment, i am trying to make the darcyLaplacian solver with some temperature terms added. I seem to be missing a curly bracket, but I'm not sure where. Did you get a pressure gradient working? Cheers Tom edit I added my solver and the TEqn it needs. Im having issues now with boundaryConditions. It doesnt like taking the gradient of a calculated internalField. Last edited by TomB; October 13, 2011 at 10:29. Reason: added some files |
October 13, 2011, 10:16 |
#26 |
Werner
HI Tom,
no i dont got my continuity equation working correctly. Send me your solver, maybe i find your problem. Cheers Werner |
October 13, 2011, 10:40 |
#27 |
Tom
HI Werner
my solver is in the post above. I added another curly bracket and it works, but it doesnt make sense. i use bracket matching and indenting so i should be able to see where its missin.. I think my set up needs a setFields, so that the initial pressure is set before it starts to solve the fvm::laplacian(p) |
October 13, 2011, 10:43 |
#28 |
Werner
Hi Tom,
which vers. of OF you use? |
October 13, 2011, 11:19 |
#29 |
Tom
Hi Nep
Im using OpenFoam 2.0.1 Im having an issue with the boundary. I get the error message, gradientInternalCoeffs cannot be called for a calculatedFvPatchField. it suggests I migh be using a default boundary condition. I copied the boundary conditions from buoyantBoussinesqSimpleFoam I'll work on this some more tmw ( about 8 hours from now zzzzzzzzzzzzzzzz) |
June 18, 2019, 09:43 |
DarcyFoam with Boussinesq assumption pressure diverges.
#31 |
Manu Chakkingal
Rep Power: 10 |
Hello All
I am trying to include heat transfer in DarcyFoam solver available in porousMultiphaseFoam (https://github.com/phorgue/porousMul...ties/darcyFoam. The solver is intended to simulate Natural convective flow in porous media filled cavity. So I would have zero velocity at all walls. Two of the walls would have a temperature (different from each other) with remaining being adiabatic. In the presence of gravitational force a flow is expected to be induced. Intended equation to be solved: Code:
u= K/mu (-grad(p)+ rho*g)= -K/mu(grad(p-rho_0*g*z)) -(K/mu)*(rho_0*beta*(T-Tref))*g
In order to have such a solver, I modified the Main .C file as: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | foam-extend: Open Source CFD \\ / O peration | Version: 4.0 \\ / A nd | Web: http://www.foam-extend.org \\/ M anipulation | For copyright notice see file Copyright ------------------------------------------------------------------------------- License This file is part of foam-extend. foam-extend is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. foam-extend is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with foam-extend. If not, see <http://www.gnu.org/licenses/>. Application laplacianFoam Description Solves a simple Laplace equation, e.g. for thermal diffusion in a solid. \*---------------------------------------------------------------------------*/ #include "fvCFD.H" #include "singlePhaseTransportModel.H" #include "simpleControl.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { # include "setRootCase.H" # include "createTime.H" # include "createMesh.H" simpleControl simple(mesh); # include "readGravitationalAcceleration.H" # include "createFields.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nCalculating flow and temperature distribution\n" << endl; while (simple.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; while (simple.correctNonOrthogonal()) { fvScalarMatrix TEqn ( (eps*rhoCpf+(1.-eps)*rhoCps)*fvm::ddt(T) + rhoCpf*fvm::div(phi,T) == fvm::laplacian(DT, T) ); TEqn.solve(); TEqn.relax(); rhok = rhof*(1.0- beta*(T - TRef)); fvScalarMatrix pEqn ( fvm::laplacian(-Mf,p)+ fvc::div(phiG) ); pEqn.solve(); phi = pEqn.flux() + phiG; pEqn.relax(); U = fvc::reconstruct(phi); U.correctBoundaryConditions(); Info<< "Vel done" << endl; Info<< "Temp done" << endl; } # include "write.H" Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } // ************************************************************************* // Code:
Info<< "Reading thermophysical properties\n" << endl; Info<< "Reading field T\n" << endl; volScalarField T ( IOobject ( "T", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Calculating field g.h\n" << endl; volScalarField gh("gh", g & mesh.C()); surfaceScalarField ghf("ghf", g & mesh.Cf()); Info<< "Reading field p\n" << endl; volScalarField p ( IOobject ( "p", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field U\n" << endl; volVectorField U ( IOobject ( "U", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), mesh, dimensionedVector("zero", dimensionSet(0,1,-1,0,0,0,0), vector::zero) ); // mesh, dimensionedVector("U", dimensionSet(0,1,-1,0,0,0,0), vector::zero) //permeability Info << "Reading field K\n" << endl; volScalarField K ( IOobject ( "K", runTime.constant(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); //# include "createPhi.H" surfaceScalarField phi("phi", fvc::interpolate(U) & mesh.Sf()); mesh.schemesDict().setFluxRequired(p.name()); Info<< "Reading transportProperties\n" << endl; IOdictionary transportProperties ( IOobject ( "transportProperties", runTime.constant(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ) ); Info<< "Reading diffusivity DT\n" << endl; dimensionedScalar DT ( transportProperties.lookup("DT") ); // Thermal expansion coefficient [1/K] dimensionedScalar beta(transportProperties.lookup("beta")); // Reference temperature [K] dimensionedScalar TRef(transportProperties.lookup("TRef")); // Reference density of fluid [kg/m^3] dimensionedScalar rhof ( transportProperties.lookup("rhof") ); //poroisity dimensionedScalar eps ( transportProperties.lookup("eps") ); //heat capacity solid dimensionedScalar rhoCps ( transportProperties.lookup("rhoCps") ); //heat capacity fluid dimensionedScalar rhoCpf ( transportProperties.lookup("rhoCpf") ); //viscosity fluid dimensionedScalar mu ( transportProperties.lookup("mu") ); // Kinematic density for buoyancy force volScalarField rhok ( IOobject ( "rhok", runTime.timeName(), mesh ), rhof*(1.0 - (beta*(T - TRef))) ); surfaceScalarField buoyancyPhi(ghf*fvc::snGrad(rhok)*mesh.magSf()); Info<< "Calculating field beta*(g.h)\n" << endl; surfaceScalarField betaghf("betagh", beta*(g & mesh.Cf())); surfaceScalarField Kf=fvc::interpolate(K,"K"); surfaceScalarField Mf ("Mf",Kf/mu); surfaceScalarField rhokf=fvc::interpolate(rhok); surfaceScalarField phiG("phiG",(rhokf * Mf)* (g & mesh.Sf())); When I run the solver on a test case (attached herewith), the pressure diverges. Test conditions tried and outcome
Important parameters to be changed for testing
Please note: to calculate rhok I tried rhof*(1.0 - (beta*(T - TRef))) and rhof*(0.0 - (beta*(T - TRef))) depending on whether p is treated as pressure or pressure-rho*g*h. But both of them gave similar error. Can someone please suggest what could be the issue and how I should approach the same. please find the solver and testcase attached.
Regards Manu |
Natural Convection in a storage tank - boussinesq? | Jervds | CFX | 6 | October 2, 2016 02:53 |
Boussinesq Assumption | tstorm | FLUENT | 3 | October 26, 2009 05:11 |
Boussinesq | lucifer | FLUENT | 0 | September 26, 2009 09:31 |
Outflow boundary condition for a boussinesq fluid | lin | OpenFOAM Running, Solving & CFD | 19 | July 31, 2009 08:50 |
Darcy + multiphase? | George Bergantz | Siemens | 1 | March 14, 2002 05:07 |
