problems with U & U computation
Old   September 5, 2011, 11:36
Default problems with U & U computation
David S
ds-gti is on a distinguished road
Dear Foamers,
I want to compute the L2-norm. It works fine for p as it is a volScalarField but not for U. I also do not know, why the output line starting with Info work fine but doesn't if it is copied outside the line.
The current code is:
Udiff = U-Uexact;
pLErr = sqrt(magSqr(pdiff)); //is computed
ULErr = sqrt(Udiff.internalField() & Udiff.internalField()); //causes trouble
Info << "UErr " << sqrt(Udiff.internalField() & Udiff.internalField()) << endl; //is printed into log file
The current error message is the following, which I do not understand exactly.
no match for âoperator=â in âULErr = Foam::sqrt(const Foam::tmp<Foam::GeometricField<double, PatchField, GeoMesh> >&)
                                    [with PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]()â
/home/e322st30/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:1032: note: candidates are:
        void Foam::GeometricField<Type, PatchField, GeoMesh>::operator=(const Foam::GeometricField<Type, PatchField, GeoMesh>&)
                                    [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/home/e322st30/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:1057: note:
void Foam::GeometricField<Type, PatchField, GeoMesh>::operator=(const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&)
/home/e322st30/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:1093: note:
void Foam::GeometricField<Type, PatchField, GeoMesh>::operator=(const Foam::dimensioned<Type>&)
Thanks for advise!
David
ds-gti is offline   Reply With Quote
Old   September 6, 2011, 04:33
Eugene de Villiers
eugene is on a distinguished road
Not 100% sure why you are getting the error, try putting "::" in front of the offending "sqrt". However, there is a simpler way to compute the vector magnitude that will definitely work:
ULErr = mag(U-Uexact);
eugene is offline   Reply With Quote
Old   September 6, 2011, 12:13
David S
Thanks a lot for your reply!
The :: added gives:
T.C:191: error: cannot convert âFoam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >â to âdoubleâ for argument â1â to âdouble sqrt(double)â
make: *** [Make/linux64GccDPOpt/T.o] Error 1
and ULErr = mag(U-Uexact); is not working too...
no match for âoperator=â in âUL2 = Foam::mag(const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]()â
/home/e322st30/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:1032: note: candidates are: void Foam::GeometricField<Type, PatchField, GeoMesh>::operator=(const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/home/e322st30/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:1057: note:                 void Foam::GeometricField<Type, PatchField, GeoMesh>::operator=(const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/home/e322st30/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:1093: note:                 void Foam::GeometricField<Type, PatchField, GeoMesh>::operator=(const Foam::dimensioned<Type>&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
make: *** [Make/linux64GccDPOpt/TTest.o] Error 1
What to try next?
Old   September 7, 2011, 06:12
David S
ULErr is a volScalarField. Now it works.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
problem in the CFX12.1 parallel computation BalanceChen ANSYS 2 July 7, 2011 10:26
Discussion on the computation of the multi-stage axial compressor BalanceChen CFX 5 January 5, 2011 02:23
Floworks computation problems drejki FloEFD, FloWorks & FloTHERM 1 March 3, 2010 20:49
unstructured grid sreekanth Main CFD Forum 1 August 6, 2001 15:09
