December 7, 2015, 16:40 |
Electric Potential Method for MHD Duct Flow
Jun
Rep Power: 10 |
Hello.
I'm currently working on electric potential method to solve MHD Duct Flow Because it uses electric potential method, I have to compile new solver. I tried to modified simplefoam to solve MHD and I made it. However, it does not converge at high Hartman lminar flow. Thas is why I decided to find some code on the internet and I found one. I copied and modified but it did not work. There was errors. The code is as below Code:
#include "fvCFD.H" #include "pisoControl.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" pisoControl piso(mesh); pisoControl bpiso(mesh, "BPISO"); #include "createFields.H" #include "initContinuityErrs.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< nl << "Starting time loop" << endl; while (runTime.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; #include "CourantNo.H" { volVectorField UcrosB= U ^ B; volVectorField j=-sigma*fvc::grad(PotE) + sigma*UcrosB; volVectorField jcrosB = j ^ B; fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - (jcrosB/rho) - fvm::laplacian(nu,U) ); if (piso.momentumPredictor()) { solve(UEqn == -fvc::grad(p)); } // --- PISO loop while (piso.correct()) { volScalarField rAU(1.0/UEqn.A()); surfaceScalarField rAUf("rAUf", fvc::interpolate(rAU)); volVectorField HbyA("HbyA", U); HbyA = rAU*UEqn.H(); surfaceScalarField phiHbyA ( "phiHbyA", (fvc::interpolate(HbyA) & mesh.Sf()) + rAUf*fvc::ddtCorr(U, phi) ); while (piso.correctNonOrthogonal()) { fvScalarMatrix pEqn ( fvm::laplacian(rAUf, p) == fvc::div(phiHbyA) ); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(mesh.solver(p.select(piso.finalInnerIter()))); if (piso.finalNonOrthogonalIter()) { phi = phiHbyA - pEqn.flux(); } } #include "continuityErrs.H" U = HbyA - rAU*fvc::grad(p); U.correctBoundaryConditions(); } } // --- B-PISO loop while (bpiso.correct()) { volVectorField UcrosB= U ^ B; fvVectorMatrix BEqn ( fvm::laplacian(PotE) == fvc::div(UcrosB) ); BEqn.solve(); #include "magneticFieldErr.H" } runTime.write(); } Info<< "End\n" << endl; return 0; } // ************************************************************************* // Code:
Making dependency list for source file EpisoFoam.C g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c EpisoFoam.C -o Make/linux64GccDPInt32Opt/EpisoFoam.o EpisoFoam.C: In function ‘int main(int, char**)’: EpisoFoam.C:148:13: error: no matching function for call to ‘Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::tmp<Foam::fvMatrix<double> >)’ ); ^ EpisoFoam.C:148:13: note: candidates are: In file included from /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.H:1058:0, from /opt/openfoam30/src/finiteVolume/lnInclude/ddtScheme.C:29, from /opt/openfoam30/src/finiteVolume/lnInclude/ddtScheme.H:337, from /opt/openfoam30/src/finiteVolume/lnInclude/fvcDdt.C:28, from /opt/openfoam30/src/finiteVolume/lnInclude/fvcDdt.H:199, from /opt/openfoam30/src/finiteVolume/lnInclude/fvc.H:44, from /opt/openfoam30/src/finiteVolume/lnInclude/fvCFD.H:8, from EpisoFoam.C:51: /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, Foam::Istream&) [with Type = Foam::Vector<double>] Foam::fvMatrix<Type>::fvMatrix ^ /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note: candidate expects 2 arguments, 1 provided /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:361:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = Foam::Vector<double>] Foam::fvMatrix<Type>::fvMatrix(const tmp<fvMatrix<Type> >& tfvm) ^ /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:361:1: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<double> >’ to ‘const Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >&’ /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:330:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::fvMatrix<Type>&) [with Type = Foam::Vector<double>] Foam::fvMatrix<Type>::fvMatrix(const fvMatrix<Type>& fvm) ^ /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:330:1: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<double> >’ to ‘const Foam::fvMatrix<Foam::Vector<double> >&’ /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::dimensionSet&) [with Type = Foam::Vector<double>] Foam::fvMatrix<Type>::fvMatrix ^ /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note: candidate expects 2 arguments, 1 provided make: *** [Make/linux64GccDPInt32Opt/EpisoFoam.o] 오류 1 root@ubuntu:~/OpenFOAM/mykkujinu2201-3.0.0/solver/EpisoFoam# wmake Making dependency list for source file EpisoFoam.C g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c EpisoFoam.C -o Make/linux64GccDPInt32Opt/EpisoFoam.o EpisoFoam.C: In function ‘int main(int, char**)’: EpisoFoam.C:148:13: error: no matching function for call to ‘Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::tmp<Foam::fvMatrix<double> >)’ ); ^ EpisoFoam.C:148:13: note: candidates are: In file included from /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.H:1058:0, from /opt/openfoam30/src/finiteVolume/lnInclude/ddtScheme.C:29, from /opt/openfoam30/src/finiteVolume/lnInclude/ddtScheme.H:337, from /opt/openfoam30/src/finiteVolume/lnInclude/fvcDdt.C:28, from /opt/openfoam30/src/finiteVolume/lnInclude/fvcDdt.H:199, from /opt/openfoam30/src/finiteVolume/lnInclude/fvc.H:44, from /opt/openfoam30/src/finiteVolume/lnInclude/fvCFD.H:8, from EpisoFoam.C:51: /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, Foam::Istream&) [with Type = Foam::Vector<double>] Foam::fvMatrix<Type>::fvMatrix ^ /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note: candidate expects 2 arguments, 1 provided /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:361:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = Foam::Vector<double>] Foam::fvMatrix<Type>::fvMatrix(const tmp<fvMatrix<Type> >& tfvm) ^ /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:361:1: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<double> >’ to ‘const Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >&’ /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:330:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::fvMatrix<Type>&) [with Type = Foam::Vector<double>] Foam::fvMatrix<Type>::fvMatrix(const fvMatrix<Type>& fvm) ^ /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:330:1: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<double> >’ to ‘const Foam::fvMatrix<Foam::Vector<double> >&’ /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::dimensionSet&) [with Type = Foam::Vector<double>] Foam::fvMatrix<Type>::fvMatrix ^ /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note: candidate expects 2 arguments, 1 provided And also, I'm curious about OpenFoam syntax. I'm quite sure that the syntax has changed at this version. So, even though I got codes from the internet, it does not work. What has changed in this version? Where can I find it? |
compile, electric potential, mhd |
Ansys 11.0 CFX - solving electric potentials and multiphase flow | cfd_multiphyiscs | CFX | 2 | March 10, 2010 13:43 |
Variable name for electric potential | Vignamitra | Main CFD Forum | 0 | July 10, 2009 04:34 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 05:18 |
3D Galerkin BEM for Potential Flow | Adrin Gharakhani | Main CFD Forum | 1 | May 27, 1999 10:08 |
