Problem with using function object to compute Nu number in parallel. |
September 9, 2011, 19:17 |
Yuri Feldman
Hi ,
I use a function object tool to compute Nu number directly during the the simulation (not as a postprocessing utility that works with a saved data after the simulation is done). For this purpose I use a function object tool. Attached please see three files: Nu.H, Nu.C, and controlDict: Nu.H----------------------------------------------------------- #ifndef Nu_H #define Nu_H #include "pointFieldFwd.H" #include "volFields.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { // Forward declaration of classes class objectRegistry; class dictionary; class mapPolyMesh; /*---------------------------------------------------------------------------*\ Class Nu Declaration \*---------------------------------------------------------------------------*/ class Nu { //- on/off switch bool active_; //- Name of this set of Nu, // Also used as the name of the probes directory. word name_; const objectRegistry& obr_; //- Maximal temperature scalar Tmax_; //- Minimal temperature scalar Tmin_; //-Nusselt number scalar Nusselt_; // External radius Ro scalar Ro_; //Inyternal radius Ri scalar Ri_; //Gap width scalar L_; //Temperature difference scalar DT_; //name for the temperature field word TName_; //- Disallow default bitwise copy construct Nu(const Nu&); //- Disallow default bitwise assignment void operator=(const Nu&); const fvMesh& mesh(); public: //- Runtime type information TypeName("Nu"); // Constructors //- Construct for given objectRegistry and dictionary. // Allow the possibility to load fields from files Nu ( const word& name, const objectRegistry&, const dictionary&, const bool loadFromFiles = false ); //- Destructor virtual ~Nu(); // Member Functions //- Return name of the set of Nu virtual const word& name() const { return name_; } //- Read the Nu data virtual void read(const dictionary&); //- Execute, currently does nothing virtual void execute(); //- Execute at the final time-loop, currently does nothing virtual void end(); //- Write the Nu virtual void write(); //- Update for changes of mesh virtual void updateMesh(const mapPolyMesh&) {} //- Update for changes of mesh virtual void movePoints(const pointField&) {} }; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // } // End namespace Foam // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #endif // ************************************************** *********************** // Nu.C \*---------------------------------------------------------------------------*/ #include "Nu.H" #include "dictionary.H" #include "Time.H" #include "fvCFD.H" #include "wallFvPatch.H" // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // namespace Foam { defineTypeNameAndDebug(Nu, 0); } // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::Nu::Nu ( const word& name, const objectRegistry& obr, const dictionary& dict, const bool loadFromFiles ) : active_(true), name_(name), obr_(obr) { // Check if the available mesh is an fvMesh otherise deactivate if (!isA<fvMesh>(obr_)) { active_ = false; WarningIn ( "Foam::Nu::Nu" "(" "const word&, " "const objectRegistry&, " "const dictionary&, " "const bool" ")" ) << "No fvMesh available, deactivating." << endl; } read(dict); } // * * * * * * * * * * * * * * * * Destructor * * * * * * * * * * * * * * * // Foam::Nu::~Nu() {} // * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * // void Foam::Nu::read(const dictionary& dict) { if (active_) { dict.lookup("TName")>> TName_; dict.lookup("Tmax")>>Tmax_; dict.lookup("Tmin")>>Tmin_; dict.lookup("Rin") >>Ri_; dict.lookup("Rout")>>Ro_; DT_=Tmax_-Tmin_; L_=Ro_-Ri_; Info<<"Tmax="<<Tmax_<<endl; Info<<"Tmin="<<Tmin_<<endl; Info<<"Rin=" <<Ri_ <<endl; Info<<"Rout="<<Ro_ <<endl; } } void Foam::Nu::execute() { // Do nothing - only valid on write } void Foam::Nu::end() { // Do nothing - only valid on write } void Foam::Nu::write() { if (active_) { const volScalarField& T= obr_.lookupObject<volScalarField>(TName_); surfaceScalarField heatFlux = fvc::snGrad(T); const surfaceScalarField::GeometricBoundaryField& patchHeatFlux = heatFlux.boundaryField(); const fvMesh& mesh=refCast<const fvMesh>(obr_); forAll(patchHeatFlux, patchi) { if (isA<wallFvPatch>(mesh.boundary()[patchi])) { if (mesh.boundary()[patchi].name()=="internal") { Nusselt_ = sum ( mesh.magSf().boundaryField()[patchi] *patchHeatFlux[patchi]) *L_/4/3.141592653589793/DT_/Ri_/Ro_; Info<<Nusselt_; } } } } Info<< endl; } // ************************************************** *********************** // controlDict libs ("/home/yurifeld/OpenFOAM/yurifeld-1.7.1/lib/linux64GccDPOpt/libuserFunctionObjects.so"); functions ( Nusselt { type Nu; TName T; Tmin 293; Tmax 333; Rin 0.1; Rout 0.06667; outputControl timeStep; outputInterval 1; } ); // ************************************************** *********************** // The program works perfect when it is runnining in sequential mode, however when I try to run it in parallel it gives me the Nu number only for the zerro processor while I want to get total Nu number which should utilize the sum of all values computed on all the processors. My question is how to make it to do this. I tried to define IO scalar object so that each processor would write its Nu in for in the corresponding time step directory, however I did not suceed to define scalr IO object. If you have any idea please help me to resolve this problem. Many thanks. |
correction number and parallel computing | psosnows | OpenFOAM Bugs | 5 | June 17, 2013 20:56 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
"The high Reynolds number flow is not difficult to compute, the problem is we simply don't know how. | wowakai | Main CFD Forum | 1 | November 11, 1998 10:24 |
