-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   reading nu for multiphase flows (http://www.cfd-online.com/Forums/openfoam-programming-development/92592-reading-nu-multiphase-flows.html)
lindstroem September 19, 2011 11:00
Hi everybody,
I want to extend a solver from single to multiphase flows. At one point I am stuck because of the reading of the transportPropterties.
The "old" code says:
dimensionedScalar nu(transportProperties.lookup("nu"));
If I get it right, I will have a nu1 and nu2 for multiphase flows. Can I only access them via createFields or can it be read by transportProperties...?
Thanks for your help!
Lindstroem
marupio September 19, 2011 15:50
createFields reads from transportProperties. If you want nu1 and nu2 defined, you need to modify your solver - and why not change createFields?
lindstroem September 20, 2011 03:51
Hi David,
thanks for your suggestion. Actually I need them in a function where I calculate some forces (outside the solver). Up to now, I did not use createFields for this function, only for the solver. I hoped there was an easy way to read them just like for a single phase flow.
Thanks..
Bernhard September 20, 2011 04:17
You can have a peek in the createFields.H file of interFoam to see how it is done.
lindstroem September 20, 2011 04:35
So in a similar manner like
twoPhaseMixture twoPhaseProperties(U, phi, "alpha1");
    const dimensionedScalar& rho1 = twoPhaseProperties.rho1();
    const dimensionedScalar& rho2 = twoPhaseProperties.rho2();
Ok, then I need to extend the functions as expected. I hoped to have sth like
dimensionedScalar nu1(transportProperties.lookup("nu1"));
Thanks!
Bernhard September 20, 2011 04:43
That second option is of course also possible. Did you try it already?
lindstroem September 20, 2011 04:48
Yes, but... it compiles, but I get the error
keyword nu1 is undefined in dictionary "[..]/constant/transportProperties"
file: [..]constant/transportProperties from line 19 to line 32.
lindstroem September 20, 2011 05:06
twoPhaseMixture.H provides a volScalarField nu so thats the way i will get access to it:
const volScalarField& nu = twoPhaseProperties.nu();
Bernhard September 20, 2011 05:16
Which means that you have to provide a nu1 in the transportProperties file, but you already found your solution.
lindstroem September 20, 2011 05:20
When I provided a nu1 it was complaining that it did not find a nu (which i did not call any longer from my force-calculation-function). Yes, I'll try it with the scalarField.
Thanks!
