Home > Forums > OpenFOAM Programming & Development
Robin BC for T
Old   September 28, 2011, 07:57
Default Robin BC for T
moritzhoefert is on a distinguished road
Dear all,
one equation in my case is
            (   fvm::ddt(T)
                + fvm::div(phi,T)
                - fvm::laplacian(lambda,T)
with lambda being a function of space and time. In the BC I would like to specify a heat flux q_dot = alpha(T_inf - T_bc).
T_inf ...const. Far field temperature
alpha ...const. Heat transfer coefficient
T_bc ...Temperature at boundary
Energy conservation yields
q_dot = -lambda (del T)/(del n) = alpha(T_inf - T_bc)
which is my BC.
* Does such a BC exist?
* How should I proceed if I want to implement it?
* I know that it is similar to the BC "mixed" but I think mixed cannot account for non-constant lambda. Are there other BCs that might be useful templates?
Thank you for any comments!
moritzhoefert is offline   Reply With Quote
Old   September 29, 2011, 04:19
cosimo bianchini
cosimobianchini is on a distinguished road
Send a message via Skype™ to cosimobianchini
I wrote such a BC few time ago (you find the code here) and it actually is a mixed boundary condition.
The idea is simple, just rewriting the equation you wrote (I also add a general thermal power to handle radiation Q) you end up with:
h/(h+k*deltaCoeff) * T_w + k*deltaCoeff/(h+k*deltaCoeff) * gradT_w = h/(h+k*deltaCoeff) * T_ref + Q*deltaCoeff/(h+k*deltaCoeff)
satisfying both the physical constraint and the form of the mixed boundary condition i.e. VF * T_w + (1-VF) * gradT_w =VF*T_ref + (1-VF) * gradT_ref.
So it just set:
VF = h/(h+k*deltaCoeff)
T_ref = T_ref
gradT_ref = Q*deltaCoeff*VF/(1-VF)/h
in order to make it work you just have to define in your solver a volScalarField kond to store values for the thermal conductivity (optionally you can define it inside the BC if you like).
It was compiled on 1.6.x but I guess you will not have troubles importing it in 1.6-ext or 1.7. Not sure about 2.0, drop me an email if you need a help.
Hope you find this useful.
Cosimo Bianchini
Ergon Research s.r.l.
Via Panciatichi, 92
50127 Florence - ITALY
Tel: +39 055 0763716
Mob: +39 320 9460153
cosimobianchini is offline   Reply With Quote
Old   October 10, 2011, 08:47
Hi Cosimo,
thanks so much for writing down your thoughts! You helped me a lot!
Thread Tools
Trackbacks are On
Robin B.C. Yu FLUENT 3 May 27, 2012 04:19
Robin boundary condition for the velocity fumiya OpenFOAM 4 June 17, 2011 02:58
directionMixed robin Martin80 OpenFOAM Programming & Development 0 June 10, 2011 04:02
what's wrong with my Robin boundary conditions? hadesmajesty Main CFD Forum 0 September 23, 2009 04:57
to LANGTRY ROBIN :help, hypersonic transition SST ben akih CFX 0 September 21, 2006 04:59
