-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Adding Thermo to basicKinematicCollidingCloud (http://www.cfd-online.com/Forums/openfoam-programming-development/92928-adding-thermo-basickinematiccollidingcloud.html)
bruce September 29, 2011 09:14
hello all,
now i add Thermo to basicKinematicCollidingCloud and basicKinematicCollidingParcel in order to simulate heat transfer for KinematicCollidingCloud.
first i copy and renamed basicKinematicCollidingCloud to basicThermoKinematicCollidingCloud and done neccesary changes.
basicThermoKinematicCollidingCloud.H as
HTML Code:
namespace Foam
    typedef ThermoCloud
        CollidingCloud
            KinematicCloud
                Cloud
                    basicThermoKinematicCollidingParcel
    > basicThermoKinematicCollidingCloud;
and basicThermoKinematicCollidingParcel.H as
HTML Code:
namespace Foam
    typedef ThermoParcel<CollidingParcel<KinematicParcel<particle> > > basicThermoKinematicCollidingParcel;
    template<>
    inline bool contiguous<basicThermoKinematicCollidingParcel>()
        return true;
defineBasicThermoKinematicCollidingParcel.C as
HTML Code:
namespace Foam
  defineTemplateTypeNameAndDebug(basicThermoKinematicCollidingParcel, 0);
  defineTemplateTypeNameAndDebug(Cloud<basicThermoKinematicCollidingParcel>, 0);
finnally makeBasicThermoKinematicCollidingParcelSubmodels.C as
HTML Code:
namespace Foam
    makeParcelCloudFunctionObjects(basicThermoKinematicCollidingCloud);
    // Kinematic sub-models
    makeThermoParcelForces(basicThermoKinematicCollidingCloud);
    makeParcelDispersionModels(basicThermoKinematicCollidingCloud);
    makeParcelCollisionModels(basicThermoKinematicCollidingCloud);
    makeParcelInjectionModels(basicThermoKinematicCollidingCloud);
    makeParcelPatchInteractionModels(basicThermoKinematicCollidingCloud);
    // Thermo sub-models
    makeParcelHeatTransferModels(basicThermoKinematicCollidingCloud);
    makeParcelSurfaceFilmModels(basicThermoKinematicCollidingCloud);
and i compile this new library as libbasicThermoKinematicCollidingParcel.so
and now i link this new type library to icoUncoupledKinematicParcelFoam solver.
and Constructing new type as
HTML Code:
basicThermoKinematicCollidingCloud kinematicParcels
    "kinematicCloud1",
    rho,
    U,
    g,
    slgThermo
now i get this link error.
HTML Code:
/lib//libbasicThermoKinematicCollidingParcel.so: undefined reference to `Foam::WallModel<Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::ThermoParcel<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > > > >::dictionaryConstructorTablePtr_'
/lib//libbasicThermoKinematicCollidingParcel.so: undefined reference to `Foam::PairModel<Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::ThermoParcel<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > > > >::dictionaryConstructorTablePtr_'
collect2: ld returned 1 exit status
Could any body help to figure out this error?
Thanks
MPJ April 28, 2012 09:41
Hi bruce,
have you solved your problem?
I have the same problem with you.
although the same process have been taken as what you have done.
the same problem occur to me :(
it will be highly appreciated if you can give me some suggestion.
Best Regards
oliver
bruce April 28, 2012 12:55
1 Attachment(s)
hi,
the above posted problem was minimized version actually to post on this forum. but what i actually wanted work is coalCombustion library with parcel collision. so i solved this problem directly over there. take a look at the attached code. for details compare it with actual coalCombustion library.
have fun
MPJ April 29, 2012 05:57
Hi bruce,
Many thanks!:)
The codes were compiled successfuly with the same modification as in your attachment.
That's really helpful, thanks for sharing your modification detail.
Have a nice day~
oliver
alquimista May 8, 2013 10:43
Thank you very much. The trick is in :
collidingCoalCombustion/coalParcel/makeCoalParcelSubmodelsAdded.C
with:
        typedef coalCloud::collidingCloudType collidingParcelType;
    makeParcelCollisionModels(collidingParcelType);
cmigueis August 18, 2015 10:47
How to use collidingCoalCloud
Hi everyone! First of all, I'd like to thank Bruce for sharing your code with us. I'm having some problems when I try to use your code. Can someone please explain how can I use the collidingCoalCloud into the coalChemistryFoam? If it's possible a step-by-step guide, I'm kind a new to OpenFOAM and I don't have an advanced level of C++ knowledge.
Thanks to all of you! Regards from Brazil!
Shuai_W January 2, 2016 22:54
drag model
Dear all,
I encountered a problem when I use the solver coalCollidingChemistryFoam, in coalCloud1Properties, I choose particle force ErgunWenYuDrag, as below:
particleForces
ErgunWenYuDrag
alphac alpha;
gravity;
In addition, for collsionModel, parCollision (soft-sphere colliding model) is adopted, as:
collisionModel pairCollision;
When I run the solver coalCollidingChemistryFoam, errors appear:
--> FOAM FATAL ERROR:
Unknown particle force type ErgunWenYuDrag, constructor not in hash table
Valid particle force types are:
11
BrownianMotion
SRF
SaffmanMeiLiftForce
TomiyamaLift
gravity
nonInertialFrame
nonSphereDrag
paramagnetic
pressureGradient
sphereDrag
virtualMass
From function ParticleForce<CloudType>::New(CloudType&, const fvMesh&, const dictionary&)
in file /home/wangshuai/OpenFOAM/OpenFOAM-2.3.1/src/lagrangian/intermediate/lnInclude/ParticleForceNew.C at line 55.
It seems that the makeThermalParcelForces.H is called in the runtimeSelection rather than makeParcelForces.H (These two files locate in lagrangian/intermediate/parcels/include).
Thus I change the code in makeCoalParcelSubmodelsAdded.C, change #include "makeThermoParcelForces.H" to #include "makeParcelForces.H", and makeThermoParcelForces(coalCloud) to makeParcelForces(coalCloud). However, errors appear again, same with the former. I don’t know how to deal it, please someone help me.
