short question: zeroGradient equal fixedGradient=(0 0 0) ?!
Like Tree2Likes
  • 2 Post By Bernhard
Old   July 16, 2013, 07:54
Default short question: zeroGradient equal fixedGradient=(0 0 0) ?!
Andreas Ruopp
andyru is on a distinguished road
I looked at fixedGradientFvPatchField.C and
zeroGradientFvPatchField.C and for me
type fixedGradient;
value uniform (0 0 0);
behaves like using:
type zeroGradient;
So why do we have zeroGradient? fixedGradient type would be enough?!
Or do I draw the wrong conclusion?
Best regards,
Andy
andyru is offline   Reply With Quote
Old   July 16, 2013, 08:34
Bernhard
Bernhard is on a distinguished road
They are not the same. zeroGradient only garantuees the wall-normal derivative to be zero, not the complete gradient.
fportela and SHUBHAM9595 like this.
Bernhard is offline   Reply With Quote
Old   July 16, 2013, 12:52
Andreas Ruopp
Thank you for the fast answer. I got it.
Next little question:
A given fixedGradient value (a b c) will specify the gradient of for example U in the standard Coordinate-System(x,y,z) on a patch
HTML Code:
http://foam.sourceforge.net/docs/cpp/a00671.html#details
This boundary condition supplies a fixed gradient condition, such that the patch values are calculated using:
where
= patch values
= internal field values
= gradient (user-specified)
= inverse distance from patch face centre to cell centre
Hence, x_p is independent from the normal patch face vector?
Thanks for the answer in advance,
Andy
boundary, condition, fixedgradient, zerogradient
second order schemes marine OpenFOAM 67 April 11, 2022 18:19
A newbie's question -- NaN in icoFoam BigMatilda OpenFOAM Running, Solving & CFD 1 July 13, 2012 06:22
Short course: Modeling of Water Resources and Environmental Problems using OpenFOAM liu OpenFOAM Announcements from Other Sources 0 March 14, 2012 16:32
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
Short question on command in user fortran Franz Thomsen CFX 2 June 20, 2000 06:35
