expected primary-expression before .....
Like Tree4Likes
  • 4 Post By floquation
Old   November 3, 2014, 10:37
Default expected primary-expression before .....
Dongyue Li
sharonyue is on a distinguished road
Hi guys,
I added this piece of code into the original one:
Foam::tmp<Foam::volScalarField> Foam::twoPhaseSystem::dragCoeff() const
    return drag_->K();
Foam::tmp<Foam::volScalarField> Foam::twoPhaseSystem::dragCoeff(const volScalarField& M30, const volScalarField& M20) const
    return drag_->K(const volScalarField& M30, const volScalarField& M20);
the compiler said:
twoPhaseSystem.C: In member function ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::twoPhaseSystem::dragCoeff(const volScalarField&, const volScalarField&) const’:
twoPhaseSystem.C:291:21: error: expected primary-expression before ‘const’
twoPhaseSystem.C:291:48: error: expected primary-expression before ‘const’
twoPhaseSystem.C:292:1: warning: control reaches end of non-void function [-Wreturn-type]
make: *** [Make/linux64GccDPOpt/twoPhaseSystem.o] Error 1
Even I change it into:
    return drag_->K();
    return drag_->K(int A);
It crushed!!
But this is totally fine:
    return drag_->K();
    return drag_->K();
So it must be something wrong with this:
or
But I dont know where its wrong. Any comments is appreciated!
Thanks
sharonyue is offline   Reply With Quote
Old   November 4, 2014, 03:11
floquation's Avatar
Kevin van As
floquation will become famous soon enough
or
Indeed.
You need to distinguish parameter passing and receiving.
When you receive a parameter in a function (blue, below), you must specify its type. You are already doing this.
When you pass a variable to another function (purple, below), you must solely pass the variable, without including its type in front: the compiler already knows its type. If you do put its type in front, you are declaring a new variable, which you do not initialize. That will result in a compilation error.
So, you should do:
    return drag_->K(M30, M20);
floquation is offline   Reply With Quote
Old   November 4, 2014, 03:23
Dongyue Li
Exactly! Thank you very much!!!!!!!!!
bro!!
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
wmake compiling Problem with OF1.5 openTom OpenFOAM Installation 4 May 3, 2009 14:44
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
