adding IAPWS thermophysical model undefined reference error
Old   October 23, 2011, 09:28
Default adding IAPWS thermophysical model undefined reference error
abcdef123
abcdef123 is on a distinguished road
Hi, I am attempting to add a IAPWS thermophysicalModel, similarly as described in
http://www.cfd-online.com/Forums/ope...roperties.html
I've added IAPWSgas, IAPWSThermo, and IAPWSTransport and then finally added
makeBasicRhoThermo
hRhoThermo,
pureMixture,
IAPWSTransport,
IAPWSThermo,
IAPWSgas
to hRhoThermos.C, and then I rebuild libbasicThermophysicalModels.so with no problems. The issue is now when I try to build any heatTransfer solver (not just custom solvers) I get
libbasicThermophysicalModels.so: undefined reference to `Foam:ureMixture<Foam::IAPWSTransport<Foam::spec ieThermo<Foam::IAPWSThermo<Foam::IAPWSgas> > > >::typeName'
If I remove the makeBasicRhoThermo addition to hRhoThermos.C everything works fine but I can't use the new thermophysical model (since it's not defined).
Any advice?
Thanks.
abcdef123 is offline   Reply With Quote
Old   October 23, 2011, 10:07
Default problem solved
abcdef123
I figured this one out.. I had to add
makeBasicMixture
pureMixture,
IAPWSTransport,
IAPWSThermo,
IAPWSgas
to baseMixtures.C also.
Sorry for jumping the gun on the post. But maybe this will help someone else with a similar issue.
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
Building OF 1.6 - CentOS 4.x Pytthon OpenFOAM 1 February 2, 2010 11:05
