-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   porousZone.C writeDict() (http://www.cfd-online.com/Forums/openfoam-programming-development/94422-porouszone-c-writedict.html)
Hisham November 15, 2011 09:21
Dear Foamers,
Can you help me understand which purpose this function serves?
http://foam.sourceforge.net/docs/cpp...ce.html#l00394
00394 void Foam::porousZone::writeDict(Ostream& os, bool subDict) const
00395 {
00396    if (subDict)
00397    {
00398        os  << indent << token::BEGIN_BLOCK << incrIndent << nl;
00399        os.writeKeyword("name")
00400            << zoneName() << token::END_STATEMENT << nl;
00401    }
00402    else
00403    {
00404        os  << indent << zoneName() << nl
00405            << indent << token::BEGIN_BLOCK << incrIndent << nl;
00406    }
00407
00408    if (dict_.found("note"))
00409    {
00410        os.writeKeyword("note")
00411            << string(dict_.lookup("note")) << token::END_STATEMENT << nl;
00412    }
00413
00414    coordSys_.writeDict(os, true);
00415
00416    if (dict_.found("porosity"))
00417    {
00418        os.writeKeyword("porosity")
00419            << porosity() << token::END_STATEMENT << nl;
00420    }
00421
00422    if (dict_.found("intensity"))
00423    {
00424        os.writeKeyword("intensity")
00425            << intensity() << token::END_STATEMENT << nl;
00426    }
00427
00428    if (dict_.found("mixingLength"))
00429    {
00430        os.writeKeyword("mixingLength")
00431            << mixingLength() << token::END_STATEMENT << nl;
00432    }
00433
00434    // powerLaw coefficients
00435    if (const dictionary* dictPtr = dict_.subDictPtr("powerLaw"))
00436    {
00437        os  << indent << "powerLaw";
00438        dictPtr->write(os);
00439    }
00440
00441    // Darcy-Forchheimer coefficients
00442    if (const dictionary* dictPtr = dict_.subDictPtr("Darcy"))
00443    {
00444        os  << indent << "Darcy";
00445        dictPtr->write(os);
00446    }
00447
00448    // thermalModel
00449    if (const dictionary* dictPtr = dict_.subDictPtr("thermalModel"))
00450    {
00451        os  << indent << "thermalModel";
00452        dictPtr->write(os);
00453    }
00454
00455    os  << decrIndent << indent << token::END_BLOCK << endl;
00456 }
00457
Best regards,
Hisham
olesen November 16, 2011 05:33
Originally Posted by Hisham (Post 332193)
Dear Foamers,
Quite simply actually. You can use it to output the dictionary settings associated with the porous zone.
Hisham November 16, 2011 05:42
Just that ...... Is it not then needed by any other class?????
I mean it is not called by OF for any reason than if the developer (i.e. I) calls it ??
olesen November 16, 2011 05:46
AFAIK it is just part of the IO for the class. The only place it might be used indirectly is if you need a SHA1 of the input dictionary.
Hisham November 16, 2011 05:59
Thanks a lot Olesen. The issue is that I'm developing a class based on the porousZone class and was wondering if I should invest time modifying this function .....
I guess I will save my time for now and leave it as is, until I have more concrete info or a related error!
Best regards,
Hisham
