alternateChemistry and additional models/solvers
I was looking at the thread discussing alternate chemistry models and Cantera Implementation:
http://www.cfd-online.com/Forums/ope...1-cantera.html There was a message dated October last year about making alternateChemistryModel work with OF >= 1.6. I was wondering two things: 1) Has there been any further work with having alternateChemistryModel interface with later versions of OpenFOAM? 2) I currently have a solver where I call an external utility to calculate reaction rate arrays for use in YEqn.H where the transport equation of select species are solved. I was thinking of doing something more general, but it seems with all the difficulty it may be easier to simply create a second member function like chemistry::calculate2 that takes the names of the select species and calls the external program. Its a pain to have multiple copies of reaction rates and species, so this would simplify and make things consistent. 3) On a more general note, I'm looking for more documentation on the way chemistryModel is templatized. The biggest question I have is why there are both an ODEChemistryModel and an ode solver. In particular, if I wanted to implement something similar to what is described in 2, should I do this in ODEChemistryModel or ode? Thanks in advance Foam Friends! |
I'll tackle 3)
ode should really be named conventionalOdeChemistrySolver. There are several chemistry models, only one of which uses ODE: ODEChemistryModel. I'm sure you figured that out. But, the ODEChemistryModel can be solved in several ways: even though it has an ODE set of equations, it doesn't mean it has to use a conventional ODE solver (e.g. RK, SIBS, etc..). So there are several solvers for ODEChemistryModel. These are templated on chemistrySolver: EulerImplicit, sequential, and ode. ode is the one that uses the conventional (and well established) ode solver algorithms. |
Clears up some confusion
What you say now makes total sense, it would be nice to implement those changes.
This is going to be a long entry due to the code. Sorry in advance I'm currently using ODEChemistry as a base (as I still need some of the functionality provided by ODEChemistry) by adding some private members and public access function. The public access is for both external access without changes and to write the fields in the time directories. For example, I usually need rho written out for post-processing, so in createFields I use: Code:
volScalarField rho Code:
//ODEChemistryModel.H Code:
volScalarField dummy |
"Any hints on what I;m doing wrong or if there is a better way of implementing this?"
I'm not sure what you are trying to do in the big picture, so I can't say if there's a better way of implementing it. I look at changing the core code as a last resort, but I have had to do it from time to time. Before I do, I look to see if I can pull the objects out of OpenFOAM and reimplement them in my own library with my custom features. Sometimes it's too big an endeavour. What are you trying to do? These dummy fields look a little awkward - why do you think you need them instead of a reference? You realize the dummy fields are copies, and will not track any changes to the original fields. If you are committed to modifying the core by adding these dummy fields and the cascade of virtual access functions, I think it is failing because in psiChemistry you need to define a default implementation so the other objects to inherit it don't fail. Use the notImplemented idiom. |
I was trying to follow what is done in other classes. For example, in hsCombustionThermo, there is a protected member called hs_ that is created in much the same way as dummy_, and two access functions (one constant, one non-constant) that just return references to hs_. In createFields.H, there is a Code:
volScalarField& hs = thermo.hs(); Code:
dummy = chemistry.dummy(); The extra fields I need are related to my external chemistry utility. I actually only really need the chemical source terms for select species to be taken from my external utility, but the way ODEChemistry works as-is doesn't allow that (I don't think). Thanks for the pointers, I'll keep working on this and post a solution in case anyone needs to do something like this. |
One step closer
Alright, I'm still getting the hang of the inheritance (I think I need to have pure virtual versions of the access functions in basicChemistryModel.H), but I have a more pressing question about constructors. In ODEChemistryModel.H, the source term fields are created by the following:
RR_(nSpecie_) Code:
RR_(nSpecie_) Code:
error: expected constructor, destructor, or type conversion before ‘(’ token |
You are taking the constructor out of context. The constructor you are using is for the ODEChemistryModel class, not for RR_.
RR_(nSpecie_) // Constructor initialization list for ODEChemistryModel |
Its amazing how much you forget
Not having done intense class implementation since second year undergrad I am truly sorry for my ignorance. Lots of Google and review later, I have been able add the members and have been making loads of modifications on top of a copy of ODEChemistryModel. I haven't changed the souce file names yet or the arguments of the Makefile.
Now I want to make a separate chemistryModel (lets call it myChemistryModel) such that I can call it through the constant/chemistryProperties file: Code:
psiChemistryModel myChemistryModel<gasThermoPhysics> Code:
rhoChemistryModel myChemistryModel<gasThermoPhysics> |
