Need Confirmation - Eulerian solver for tiny particules |
August 29, 2012, 11:26 |
HECKMANN Frédéric
Rep Power: 16 |
Hi everyone, it would be nice if somebody can give me some confirmations on the general aspect of my algorithm and the "code" that follows (especially the translation of the equations). I want to setup an unsteady Eulerian solver to compute the behavior of tiny particles in a fluid (only the fluid impact the particules motion through the drag).
Nomenclature : - volume fraction of the particles - velocity of the particles - function of the relative Reynolds number - time respond of the particle - velocity of the fluid Continuity equation : Momentum equation The algorithm I have in mind : 1) setup a "phi_alpha" flux equal to 2) initialize this flux in the createfield with: Code:
"linearInterpolate(alpha)*linearInterpolate(u) & mesh.Sf()" Code:
fvScalarMatrix cEqn ( fvm::ddt(alpha) + fvc::div(alpha_phi) ); cEqn.solve() Code:
alpha_phi -= cEqn.flux(); 6) solve the momentum equation using: Code:
fvVectorMatrix uEqn ( fvm::ddt(alpha, u) + fvm::div(alpha_phi, u) == fRe / Tau * alpa * (V – u) ); uEqn.solve() i) I'm not sure of the step 4... I kind of reproduce the simpleFoam code. Is there any documentation somewhere about the command ".flux" ? ii) I'm not sure of the translation of the momentum equation step 6. Do I need to use a specific formulation for the source term ? Does the solver identify the last "u" by itself ? Thank you in advance for reading this. Last edited by fredo490; August 29, 2012 at 11:28. Reason: Tiny corrections |
September 13, 2012, 03:24 |
Gerhard Holzinger
Rep Power: 28 |
have a look into twoPhaseEulerFoam or bubbleFoam and the thesis of H. Rusche. They all deal with a Eulerian formulation of two-phase fluid flows.
I would recommend to get into bubbleFoam or twoPhaseEulerFoam and remove everything you don't need. Particles with constant diameter and only drag as momentum exchange should not be a big problem. Last edited by GerhardHolzinger; September 13, 2012 at 03:27. Reason: added clarifiaction |
equations, euler, particles |
Display Modes | |
interfacing a fluid solver with abaqus | Tuhin Rakshit | Main CFD Forum | 0 | June 16, 2005 11:03 |
Could you comare StarCD with CFX 5?Help, please... | Suteh | CFX | 54 | November 7, 2001 21:12 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 17:49 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 17:25 |
Error during Solver | cfd guy | CFX | 4 | May 8, 2001 07:04 |
