Fransje |
February 2, 2012 06:10 |
Originally Posted by tomislav_maric
(Post 342168)
From
OpenFOAM-1.6-ext/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity
comes:
void parabolicVelocityFvPatchVectorField::updateCoeffs()
if (updated())
return;
// Get range and orientation
boundBox bb(patch().patch().localPoints(), true);
vector ctr = 0.5*(bb.max() + bb.min());
const vectorField& c = patch().Cf();
// Calculate local 1-D coordinate for the parabolic profile
scalarField coord = 2*((c - ctr) & y_)/((bb.max() - bb.min()) & y_);
vectorField::operator=(n_*maxValue_*(1.0 - sqr(coord)));
This is called upcasting in C++: stripping the inherited object to the base class. All bcs are hidden *fields. No need for *_cast magic.
Just so you don't miss it , the key line is
vectorField::operator= blah blah
, this converts "this" (the class, in this case parabolicBlah...) to a vectorField.
T.
Dear Tomislav,
Thank you for your contribution, but this is missing the point slightly.
The const_cast< > here is used to be able to change an object / variable in the database, which is of type const, so theoretically not modifiable.
Kind regards,
Francois.
