January 11, 2012, 10:16 |
ground area
Kathrin
Rep Power: 14 |
How can I get the horizontal area of a cell?
As far as I know does magSf() give you the vertical face area. Or is there any way to indicate the direction of the cell face vector? I need this value in order to get the ground area of the cells at a patch. Another option would be deviding the volume of the cells by the cell hight. But I couldn't find a way to get this value either. Thanks... |
January 12, 2012, 11:35 |
David Gaden
Rep Power: 21 |
magSf() gives you the magnitude of surface area... Sf() gives you the area vector, pointing away from the owner cell. Get a unit vector of your "ground" surface, pointing up, and dot product the Sf()... I think that should do it.
~~~ Follow me on twitter @DavidGaden |
January 19, 2012, 09:54 |
Kathrin
Rep Power: 14 |
Thanks David for your reply.
I finally went back to my case and tried your suggestion. The thing is just that the ground is perpendicular to the patch so the dot product becomes zero. I did it like this: Code:
scalar groundArea = gSum( normalVector & patch().Sf() ); cheers |
January 19, 2012, 10:17 |
David Gaden
Rep Power: 21 |
Oh, sorry, I thought you wanted to find the projected area of a single surface on to the ground. You want the projected area of the entire cell volume? Well, you could do what I suggested for all its bounding surfaces, sum the answers and divide by two. This would work assuming the surfaces overlap only once, which is the case for tetrahedral and hexahedral cell volumes.
Non overlap area fractions | saisanthoshm88 | CFX | 11 | September 17, 2015 18:42 |
Mesh of the ground of a certain area | samiam1000 | Main CFD Forum | 2 | August 5, 2011 01:46 |
Mesh of the ground of a certain area | samiam1000 | OpenFOAM | 0 | August 4, 2011 02:33 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
