Problems with running a custom solver: "Unknown psiCombustionModel" |
August 7, 2015, 03:47 |
A. Kamitsis
Rep Power: 10 |
Hi there,
I'm quite new to CFD and OpenFOAM and have been given a thesis with uni on the simulation of Firewhirls - thankfully the work is a continuation on a previous thesis so I won't need to start from scratch - however I am having troubles running the code I have been given. In order to create a realistic model, the previous student had to create a custom solver to allow the reference frame to rotate. I have compiled the solver using wmake, however when I go to run a case I am getting the following error with the combustion model: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-5be49240882f Exec : rotatingCDFireFoam Date : Aug 07 2015 Time : 17:17:00 Host : "alexei-OptiPlex-9010" PID : 4394 Case : /home/alexei/OpenFOAM/alexei-2.2.0/run/changing_diff/whirl_0.05r_0.01in_3.0w nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libcylindricalVelocityInlet.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable::open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libcylindricalVelocityInlet.so" Create mesh for time = 0 Reading g Creating combustion model Selecting combustion model infinitelyFastChemistry<rhoThermoCombustion,gasThermoPhysics> --> FOAM FATAL ERROR: Unknown psiCombustionModel type infinitelyFastChemistry<rhoThermoCombustion,gasThermoPhysics> Valid combustionModels are : 8 ( noCombustion<psiThermoCombustion> diffusion<psiThermoCombustion,constGasThermoPhysics> PaSR<psiChemistryCombustion> infinitelyFastChemistry<psiThermoCombustion,gasThermoPhysics> FSD<psiThermoCombustion,gasThermoPhysics> infinitelyFastChemistry<psiThermoCombustion,constGasThermoPhysics> diffusion<psiThermoCombustion,gasThermoPhysics> FSD<psiThermoCombustion,constGasThermoPhysics> ) From function psiCombustionModel::New in file psiCombustionModel/psiCombustionModel/psiCombustionModelNew.C at line 62. FOAM exiting Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 2011 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. \*---------------------------------------------------------------------------*/ #include "psiCombustionModel.H" // * * * * * * * * * * * * * * * * Selectors * * * * * * * * * * * * * * * * // Foam::autoPtr<Foam::combustionModels::psiCombustionModel> Foam::combustionModels::psiCombustionModel::New ( const fvMesh& mesh ) { const word combModelName ( IOdictionary ( IOobject ( "combustionProperties", mesh.time().constant(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE, false ) ).lookup("combustionModel") ); Info<< "Selecting combustion model " << combModelName << endl; dictionaryConstructorTable::iterator cstrIter = dictionaryConstructorTablePtr_->find(combModelName); if (cstrIter == dictionaryConstructorTablePtr_->end()) { FatalErrorIn ( "psiCombustionModel::New" ) << "Unknown psiCombustionModel type " << combModelName << endl << endl << "Valid combustionModels are : " << endl << dictionaryConstructorTablePtr_->toc() << exit(FatalError); } const label tempOpen = combModelName.find('<'); const word className = combModelName(0, tempOpen); return autoPtr<psiCombustionModel>(cstrIter()(className, mesh)); } // ************************************************************************* // I am using OpenFOAM 2.2.0 on ubuntu 12.04 Cheers, Alex Last edited by wyldckat; August 10, 2015 at 10:03. Reason: Added [CODE][/CODE] markers |
August 10, 2015, 10:07 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question: What was the OpenFOAM version that was used in the other thesis?
Because there were some substantial changes over the years and knowing the starting point would make it a lot easier to diagnose. For example: http://www.openfoam.org/version2.2.0/thermophysical.php - section "Dictionary-based Thermodynamics Selection" |
August 11, 2015, 03:53 |
A. Kamitsis
Rep Power: 10 |
He was also using version 2.2.0!
Cheers, |
August 12, 2015, 17:03 |
Bruno Santos
Rep Power: 128 |
Quick answer: Then there are only a few possible reasons for this error message. Some of which I can deduce right now:
--> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libcylindricalVelocityInlet.so: cannot open shared object file: No such file or directory |
August 18, 2015, 10:39 |
A. Kamitsis
Rep Power: 10 |
Thanks for your help Bruno - I have found a folder of his where he has the Make files for the cylindricalVelocityInlet and custom combustion models - however when I try wmake in either I get an error. Would you have an idea of what is going wrong here? (this is when attempting wmake for cylindricalVelocityInlet):
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -IlnInclude -I. -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/cylindricalVelocityInletFvPatchVectorField.o -L/home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -lOpenFOAM -ldl -lm -o OpenFOAM.out /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' Make/linux64GccDPOpt/cylindricalVelocityInletFvPatchVectorField.o: In function `Foam::cylindricalVelocityInletFvPatchVectorField::updateCoeffs()': cylindricalVelocityInletFvPatchVectorField.C:(.text+0xa70): undefined reference to `Foam::fvPatch::Cf() const' Make/linux64GccDPOpt/cylindricalVelocityInletFvPatchVectorField.o: In function `Foam::fvPatchField<Foam::Vector<double> >::type() const': cylindricalVelocityInletFvPatchVectorField.C:(.text._ZNK4Foam12fvPatchFieldINS_6VectorIdEEE4typeEv[Foam::fvPatchField<Foam::Vector<double> >::type() const]+0x3): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::typeName' Make/linux64GccDPOpt/cylindricalVelocityInletFvPatchVectorField.o: In function `Foam::fixedValueFvPatchField<Foam::Vector<double> >::type() const': cylindricalVelocityInletFvPatchVectorField.C:(.text._ZNK4Foam22fixedValueFvPatchFieldINS_6VectorIdEEE4typeEv[Foam::fixedValueFvPatchField<Foam::Vector<double> >::type() const]+0x3): undefined reference to `Foam::fixedValueFvPatchField<Foam::Vector<double> >::typeName' Make/linux64GccDPOpt/cylindricalVelocityInletFvPatchVectorField.o: In function `Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::cylindricalVelocityInletFvPatchVectorField>::~adddictionaryConstructorToTable()': cylindricalVelocityInletFvPatchVectorField.C:(.text._ZN4Foam12fvPatchFieldINS_6VectorIdEEE31adddictionaryConstructorToTableINS_42cylindricalVelocityInletFvPatchVectorFieldEED2Ev[_ZN4Foam12fvPatchFieldINS_6VectorIdEEE31adddictionaryConstructorToTableINS_42cylindricalVelocityInletFvPatchVectorFieldEED5Ev]+0x1): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::destroydictionaryConstructorTables()' Make/linux64GccDPOpt/cylindricalVelocityInletFvPatchVectorField.o: In function `Foam::fvPatchField<Foam::Vector<double> >::addpatchMapperConstructorToTable<Foam::cylindricalVelocityInletFvPatchVectorField>::~addpatchMapperConstructorToTable()': cylindricalVelocityInletFvPatchVectorField.C:(.text._ZN4Foam12fvPatchFieldINS_6VectorIdEEE32addpatchMapperConstructorToTableINS_42cylindricalVelocityInletFvPatchVectorFieldEED2Ev[_ZN4Foam12fvPatchFieldINS_6VectorIdEEE32addpatchMapperConstructorToTableINS_42cylindricalVelocityInletFvPatchVectorFieldEED5Ev]+0x1): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::destroypatchMapperConstructorTables()' Make/linux64GccDPOpt/cylindricalVelocityInletFvPatchVectorField.o: In function `Foam::fvPatchField<Foam::Vector<double> >::addpatchConstructorToTable<Foam::cylindricalVelocityInletFvPatchVectorField>::~addpatchConstructorToTable()': cylindricalVelocityInletFvPatchVectorField.C:(.text._ZN4Foam12fvPatchFieldINS_6VectorIdEEE26addpatchConstructorToTableINS_42cylindricalVelocityInletFvPatchVectorFieldEED2Ev[_ZN4Foam12fvPatchFieldINS_6VectorIdEEE26addpatchConstructorToTableINS_42cylindricalVelocityInletFvPatchVectorFieldEED5Ev]+0x1): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::destroypatchConstructorTables()' Make/linux64GccDPOpt/cylindricalVelocityInletFvPatchVectorField.o: In function `Foam::fvPatchField<Foam::Vector<double> >::snGrad() const': cylindricalVelocityInletFvPatchVectorField.C:(.text._ZNK4Foam12fvPatchFieldINS_6VectorIdEEE6snGradEv[Foam::fvPatchField<Foam::Vector<double> >::snGrad() const]+0x15): undefined reference to `Foam::fvPatch::deltaCoeffs() const' Make/linux64GccDPOpt/cylindricalVelocityInletFvPatchVectorField.o: In function `Foam::fixedValueFvPatchField<Foam::Vector<double> >::gradientInternalCoeffs() const': cylindricalVelocityInletFvPatchVectorField.C:(.text._ZNK4Foam22fixedValueFvPatchFieldINS_6VectorIdEEE22gradientInternalCoeffsEv[Foam::fixedValueFvPatchField<Foam::Vector<double> >::gradientInternalCoeffs() const]+0xd): undefined reference to `Foam::fvPatch::deltaCoeffs() const' Make/linux64GccDPOpt/cylindricalVelocityInletFvPatchVectorField.o: In function `Foam::fixedValueFvPatchField<Foam::Vector<double> >::gradientBoundaryCoeffs() const': cylindricalVelocityInletFvPatchVectorField.C:(.text._ZNK4Foam22fixedValueFvPatchFieldINS_6VectorIdEEE22gradientBoundaryCoeffsEv[Foam::fixedValueFvPatchField<Foam::Vector<double> >::gradientBoundaryCoeffs() const]+0x19): undefined reference to `Foam::fvPatch::deltaCoeffs() const' Make/linux64GccDPOpt/cylindricalVelocityInletFvPatchVectorField.o: In function `_GLOBAL__sub_I_cylindricalVelocityInletFvPatchVectorField.C': cylindricalVelocityInletFvPatchVectorField.C:(.text.startup+0xf7): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::constructpatchConstructorTables()' cylindricalVelocityInletFvPatchVectorField.C:(.text.startup+0x10f): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::patchConstructorTablePtr_' cylindricalVelocityInletFvPatchVectorField.C:(.text.startup+0x13a): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::constructpatchMapperConstructorTables()' cylindricalVelocityInletFvPatchVectorField.C:(.text.startup+0x155): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::patchMapperConstructorTablePtr_' cylindricalVelocityInletFvPatchVectorField.C:(.text.startup+0x180): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::constructdictionaryConstructorTables()' cylindricalVelocityInletFvPatchVectorField.C:(.text.startup+0x19b): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::dictionaryConstructorTablePtr_' collect2: ld returned 1 exit status make: *** [OpenFOAM.out] Error 1 Last edited by wyldckat; August 18, 2015 at 10:53. Reason: Added [CODE][/CODE] markers |
August 18, 2015, 10:54 |
Bruno Santos
Rep Power: 128 |
Quick answer: Run:
wmake libso Didn't the original author provide instructions on how to build the provided source code? |
August 19, 2015, 09:03 |
A. Kamitsis
Rep Power: 10 |
Ahhh thank you again - unfortunately I've been given no instructions whatsoever - just 300GB of case files and old results to sift through. Apologies for another question, but I just tried "wmake libso" and now get this:
alexei@alexei-OptiPlex-9010:~/OpenFOAM/cameron-2.2.0/applications/customcombustionModels$ wmake libso SOURCE=diffusion/diffusions.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/specie/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/chemistryModel/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/turbulenceModel -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/ -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/LES/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/diffusions.o In file included from lnInclude/singleStepCombustion.H:119:0, from diffusion/diffusion.H:39, from diffusion/diffusions.C:30: lnInclude/singleStepCombustion.C: In member function ‘virtual Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::combustionModels::singleStepCombustion<CombThermoType, ThermoType>::Sh() const’: lnInclude/singleStepCombustion.C:140:42: error: ‘wSpecie’ was not declared in this scope lnInclude/singleStepCombustion.C:140:73: error: ‘Y’ was not declared in this scope lnInclude/singleStepCombustion.C: In member function ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::combustionModels::singleStepCombustion<CombThermoType, ThermoType>::Sh() const [with CombThermoType = Foam::combustionModels::psiThermoCombustion, ThermoType = Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> >]’: lnInclude/singleStepCombustion.C:141:1: warning: control reaches end of non-void function [-Wreturn-type] lnInclude/singleStepCombustion.C: In member function ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::combustionModels::singleStepCombustion<CombThermoType, ThermoType>::Sh() const [with CombThermoType = Foam::combustionModels::psiThermoCombustion, ThermoType = Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> >]’: lnInclude/singleStepCombustion.C:141:1: warning: control reaches end of non-void function [-Wreturn-type] make: *** [Make/linux64GccDPOpt/diffusions.o] Error 1 alexei@alexei-OptiPlex-9010:~/OpenFOAM/cameron-2.2.0/applications/customcombustionModels$ wmake libso \SOURCE=diffusion/diffusions.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/specie/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/chemistryModel/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/turbulenceModel -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/ -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/LES/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/diffusions.o In file included from diffusion/diffusions.C:30:0: diffusion/diffusion.H:39:34: fatal error: singleStepCombustion.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/diffusions.o] Error 1 Last edited by wyldckat; August 19, 2015 at 15:53. Reason: Added [CODE][/CODE] markers |
August 19, 2015, 16:06 |
Bruno Santos
Rep Power: 128 |
Hi Alex,
That is strange... did you do something between the two executions of "wmake libso"? Because the second time you run the command it should give you the exact same error message!? Try running: Code:
wclean wmake libso Code:
./Allwmake Best regards, Bruno PS: Please use follow the instructions for Posting code and output with [CODE] (i.e. when writing the output in one of your posts )
August 19, 2015, 23:30 |
#9 |
A. Kamitsis
Rep Power: 10 |
Hi Bruno,
I didn't do anything between the executions of "wmake libso" - there is no Allwmake in the source code unfortunately, but I’ve tried it again with 'wclean' and get the following: Code:
alexei@alexei-OptiPlex-9010:~/OpenFOAM/cameron-2.2.0/applications/customcombustionModels$ wclean alexei@alexei-OptiPlex-9010:~/OpenFOAM/cameron-2.2.0/applications/customcombustionModels$ wmake libso wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file combustionModel/combustionModel.C Making dependency list for source file psiCombustionModel/psiCombustionModel/psiCombustionModel.C Making dependency list for source file psiCombustionModel/psiCombustionModel/psiCombustionModelNew.C Making dependency list for source file psiCombustionModel/psiThermoCombustion/psiThermoCombustion.C Making dependency list for source file diffusion/diffusions.C SOURCE=combustionModel/combustionModel.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/specie/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/chemistryModel/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/turbulenceModel -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/ -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/LES/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/combustionModel.o SOURCE=psiCombustionModel/psiCombustionModel/psiCombustionModel.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/specie/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/chemistryModel/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/turbulenceModel -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/ -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/LES/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/psiCombustionModel.o SOURCE=psiCombustionModel/psiCombustionModel/psiCombustionModelNew.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/specie/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/chemistryModel/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/turbulenceModel -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/ -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/LES/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/psiCombustionModelNew.o SOURCE=psiCombustionModel/psiThermoCombustion/psiThermoCombustion.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/specie/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/chemistryModel/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/turbulenceModel -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/ -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/LES/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/psiThermoCombustion.o SOURCE=diffusion/diffusions.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/specie/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/chemistryModel/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/turbulenceModel -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/ -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/compressible/LES/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/diffusions.o In file included from lnInclude/singleStepCombustion.H:119:0, from diffusion/diffusion.H:39, from diffusion/diffusions.C:30: lnInclude/singleStepCombustion.C: In member function ‘virtual Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::combustionModels::singleStepCombustion<CombThermoType, ThermoType>::Sh() const’: lnInclude/singleStepCombustion.C:140:42: error: ‘wSpecie’ was not declared in this scope lnInclude/singleStepCombustion.C:140:73: error: ‘Y’ was not declared in this scope lnInclude/singleStepCombustion.C: In member function ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::combustionModels::singleStepCombustion<CombThermoType, ThermoType>::Sh() const [with CombThermoType = Foam::combustionModels::psiThermoCombustion, ThermoType = Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> >]’: lnInclude/singleStepCombustion.C:141:1: warning: control reaches end of non-void function [-Wreturn-type] lnInclude/singleStepCombustion.C: In member function ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::combustionModels::singleStepCombustion<CombThermoType, ThermoType>::Sh() const [with CombThermoType = Foam::combustionModels::psiThermoCombustion, ThermoType = Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> >]’: lnInclude/singleStepCombustion.C:141:1: warning: control reaches end of non-void function [-Wreturn-type] make: *** [Make/linux64GccDPOpt/diffusions.o] Error 1 customcombustionModels is where the issues are - I've had a look and the singleStepCombustion and infinitelyFastChemistry files don't seem to be mentioned within the Make files? If this is the problem I'm not entirely sure how to fix it if you need anything else please let me know Thank you so much for your help/time https://www.dropbox.com/sh/0tldmchii...OttANOlma?dl=0 Last edited by wyldckat; August 20, 2015 at 13:18. Reason: merged posts that were a few minutes apart |
August 20, 2015, 13:43 |
#10 |
Bruno Santos
Rep Power: 128 |
Hi Alex,
Well, this was interesting... I had to do some probabilistic reverse engineering to the way of thinking of the author of the thesis you inherited... this to say that I had to guess (based on the information and files you provided) that this version of the source code you have is at a point where the author was apparently experimenting the implementation of a diffusion model... but had to stop for whatever reason and didn't revert the source code to the previous point where it was previously working. The solution is as follows:
wclean wmake libso Best regards, Bruno
August 22, 2015, 01:23 |
#11 |
A. Kamitsis
Rep Power: 10 |
Thank you so much Bruno, it built successfully!
August 23, 2015, 02:11 |
#12 |
A. Kamitsis
Rep Power: 10 |
Bruno,
Apologies for all the questions - I've had another issue with this custom solver that you may understand Now that the libraries have been built I've run a case using the stock fireFoam solver with no problem - however trying to use the custom solver gave me the following error: Code:
alexei@alexei-OptiPlex-9010:~/OpenFOAM/alexei-2.2.0/changing_diff/whirl_0.05r_0.01in_3.0w$ rotatingCDFireFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0 Exec : rotatingCDFireFoam Date : Aug 23 2015 Time : 15:32:20 Host : "alexei-OptiPlex-9010" PID : 4317 Case : /home/alexei/OpenFOAM/alexei-2.2.0/changing_diff/whirl_0.05r_0.01in_3.0w nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Creating combustion model Selecting combustion model infinitelyFastChemistry<psiThermoCombustion,gasThermoPhysics> Selecting thermodynamics package { type heRhoThermo; mixture singleStepReactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } --> FOAM FATAL ERROR: Unknown psiReactionThermo type thermoType { type heRhoThermo; mixture singleStepReactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Valid psiReactionThermo types are: type mixture transport thermo equationOfState specie energy hePsiThermo homogeneousMixture const hConst perfectGas specie sensibleEnthalpy hePsiThermo homogeneousMixture sutherland hConst perfectGas specie sensibleEnthalpy hePsiThermo homogeneousMixture sutherland janaf perfectGas specie sensibleEnthalpy hePsiThermo inhomogeneousMixture const hConst perfectGas specie sensibleEnthalpy hePsiThermo inhomogeneousMixture sutherland hConst perfectGas specie sensibleEnthalpy hePsiThermo inhomogeneousMixture sutherland janaf perfectGas specie sensibleEnthalpy hePsiThermo multiComponentMixture const hConst perfectGas specie sensibleEnthalpy hePsiThermo multiComponentMixture sutherland janaf perfectGas specie sensibleEnthalpy hePsiThermo reactingMixture const hConst perfectGas specie sensibleEnthalpy hePsiThermo reactingMixture sutherland janaf perfectGas specie sensibleEnthalpy hePsiThermo singleStepReactingMixture sutherland janaf perfectGas specie sensibleEnthalpy hePsiThermo veryInhomogeneousMixture const hConst perfectGas specie sensibleEnthalpy hePsiThermo veryInhomogeneousMixture sutherland hConst perfectGas specie sensibleEnthalpy hePsiThermo veryInhomogeneousMixture sutherland janaf perfectGas specie sensibleEnthalpy From function psiReactionThermo::New in file /home/alexei/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/basic/lnInclude/basicThermoTemplates.C at line 73. FOAM exiting Code:
alexei@alexei-OptiPlex-9010:~/OpenFOAM/alexei-2.2.0/changing_diff/whirl_0.05r_0.01in_3.0w$ rotatingCDFireFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0 Exec : rotatingCDFireFoam Date : Aug 23 2015 Time : 15:34:59 Host : "alexei-OptiPlex-9010" PID : 4323 Case : /home/alexei/OpenFOAM/alexei-2.2.0/changing_diff/whirl_0.05r_0.01in_3.0w nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Creating combustion model Selecting combustion model infinitelyFastChemistry<psiThermoCombustion,gasThermoPhysics> Selecting thermodynamics package { type hePsiThermo; mixture singleStepReactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Selecting chemistryReader foamChemistryReader Fuel heat of combustion :5.00312e+07 stoichiometric air-fuel ratio :17.0854 stoichiometric oxygen-fuel ratio :3.98918 Maximum products mass concentrations: H2O: 0.124183 CO2: 0.151685 N2: 0.724132 Combustion mode: explicit Reading thermophysical properties Creating component thermo properties: multi-component carrier - 5 species no liquid components no solid components Creating field rho Reading coriolis Omega Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type LESModel Selecting LES turbulence model homogeneousDynOneEqEddy Selecting LES delta type cubeRootVol homogeneousDynOneEqEddyCoeffs { cubeRootVolCoeffs { deltaCoeff 1; } filter simple; ce 1.048; Prt 1; } Creating field alphaEff Creating field dpdt Creating field kinetic energy K Calculating field g.h Creating finite volume options No finite volume options present Constructing reacting cloud Constructing particle injection models Selecting injection model none Constructing surface film model Selecting surfaceFilmModel none Selecting region model functions none Creating pyrolysis model Selecting pyrolysisModel none Selecting radiationModel none Courant Number mean: 1.99734e-07 max: 0.000333333 PIMPLE: Operating solver in PISO mode Starting time loop Courant Number mean: 1.95817e-07 max: 0.000326797 deltaT = 0.00138889 Time = 0.00138889 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.24715e-12, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 2.25169e-12, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 3.58386e-10, No Iterations 2 DILUPBiCG: Solving for O2, Initial residual = 0.999997, Final residual = 4.23966e-05, No Iterations 1 DILUPBiCG: Solving for H2O, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for CH4, Initial residual = 1, Final residual = 4.25376e-05, No Iterations 1 DILUPBiCG: Solving for CO2, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for h, Initial residual = 0.999998, Final residual = 7.89022e-09, No Iterations 2 min/max(T) = 292.995, 293 --> FOAM FATAL IO ERROR: keyword p is undefined in dictionary "/home/alexei/OpenFOAM/alexei-2.2.0/changing_diff/whirl_0.05r_0.01in_3.0w/system/fvSolution.solvers" file: /home/alexei/OpenFOAM/alexei-2.2.0/changing_diff/whirl_0.05r_0.01in_3.0w/system/fvSolution.solvers from line 22 to line 82. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 608. FOAM exiting https://www.dropbox.com/sh/0tldmchii...OttANOlma?dl=0 Kind Regards, Alexei |
August 23, 2015, 12:13 |
#13 |
Bruno Santos
Rep Power: 128 |
Quick answer:
The case does not have a mesh, therefore I can't test things myself. Either way, my guess is that you also need to add the other library to the "libs" list in "system/controlDict": Code:
libs ( "libcylindricalVelocityInlet.so" "libcustomcombustionModels.so" ); |
August 26, 2015, 20:52 |
#14 |
A. Kamitsis
Rep Power: 10 |
Bruno,
Thanks for your advice, I tried doing that and hit run on the code and it has been running for the past 3 days (over 60hrs). This morning I woke up and saw the following error - I've only posted some of it because it was quite long: Code:
7fa415096000-7fa415099000 rw-p 004a9000 08:01 41960084 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so 7fa415099000-7fa41509a000 rw-p 00000000 00:00 0 7fa41509a000-7fa4150bc000 r-xp 00000000 08:01 41960078 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libthermophysicalFunctions.so 7fa4150bc000-7fa4152bc000 ---p 00022000 08:01 41960078 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libthermophysicalFunctions.so 7fa4152bc000-7fa4152bd000 r--p 00022000 08:01 41960078 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libthermophysicalFunctions.so 7fa4152bd000-7fa4152be000 rw-p 00023000 08:01 41960078 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libthermophysicalFunctions.so 7fa4152be000-7fa4152c2000 r-xp 00000000 08:01 41960082 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libsolidMixtureProperties.so 7fa4152c2000-7fa4154c1000 ---p 00004000 08:01 41960082 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libsolidMixtureProperties.so 7fa4154c1000-7fa4154c2000 r--p 00003000 08:01 41960082 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libsolidMixtureProperties.so 7fa4154c2000-7fa4154c3000 rw-p 00004000 08:01 41960082 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libsolidMixtureProperties.so 7fa4154c3000-7fa4154d3000 r-xp 00000000 08:01 41960081 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libsolidProperties.so 7fa4154d3000-7fa4156d3000 ---p 00010000 08:01 41960081 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libsolidProperties.so 7fa4156d3000-7fa4156d4000 r--p 00010000 08:01 41960081 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libsolidProperties.so 7fa4156d4000-7fa4156d5000 rw-p 00011000 08:01 41960081 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libsolidProperties.so 7fa4156d5000-7fa415890000 r-xp 00000000 08:01 41960083 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so 7fa415890000-7fa415a8f000 ---p 001bb000 08:01 41960083 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so 7fa415a8f000-7fa415a9c000 r--p 001ba000 08:01 41960083 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so 7fa415a9c000-7fa415a9e000 rw-p 001c7000 08:01 41960083 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so 7fa415a9e000-7fa415c3d000 r-xp 00000000 08:01 41960076 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libspecie.so 7fa415c3d000-7fa415e3d000 ---p 0019f000 08:01 41960076 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libspecie.so 7fa415e3d000-7fa415e46000 r--p 0019f000 08:01 41960076 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libspecie.so 7fa415e46000-7fa415e47000 rw-p 001a8000 08:01 41960076 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libspecie.so 7fa415e47000-7fa415e48000 rw-p 00000000 00:00 0 7fa415e48000-7fa415f99000 r-xp 00000000 08:01 41960102 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libcompressibleLESModels.so 7fa415f99000-7fa416198000 ---p 00151000 08:01 41960102 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libcompressibleLESModels.so 7fa416198000-7fa41619f000 r--p 00150000 08:01 41960102 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libcompressibleLESModels.so 7fa41619f000-7fa4161a2000 rw-p 00157000 08:01 41960102 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libcompressibleLESModels.so 7fa4161a2000-7fa4163f2000 r-xp 00000000 08:01 41960101 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so 7fa4163f2000-7fa4165f1000 ---p 00250000 08:01 41960101 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so 7fa4165f1000-7fa4165fa000 r--p 0024f000 08:01 41960101 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so 7fa4165fa000-7fa4165fd000 rw-p 00258000 08:01 41960101 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so 7fa4165fd000-7fa4165fe000 rw-p 00000000 00:00 0 7fa4165fe000-7fa416916000 r-xp 00000000 08:01 41959587 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libsampling.so 7fa416916000-7fa416b16000 ---p 00318000 08:01 41959587 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libsampling.so 7fa416b16000-7fa416b21000 r--p 00318000 08:01 41959587 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libsampling.so 7fa416b21000-7fa416b26000 rw-p 00323000 08:01 41959587 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libsampling.so 7fa416b26000-7fa416b27000 rw-p 00000000 00:00 0 7fa416b27000-7fa416e25000 r-xp 00000000 08:01 41957627 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libmeshTools.so 7fa416e25000-7fa417024000 ---p 002fe000 08:01 41957627 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libmeshTools.so 7fa417024000-7fa417032000 r--p 002fd000 08:01 41957627 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libmeshTools.so 7fa417032000-7fa417036000 rw-p 0030b000 08:01 41957627 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libmeshTools.so 7fa417036000-7fa417042000 rw-p 00000000 00:00 0 7fa417042000-7fa417161000 r-xp 00000000 08:01 41960123 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfvOptions.so 7fa417161000-7fa417360000 ---p 0011f000 08:01 41960123 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfvOptions.so 7fa417360000-7fa417367000 r--p 0011e000 08:01 41960123 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfvOptions.so 7fa417367000-7fa417369000 rw-p 00125000 08:01 41960123 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfvOptions.so 7fa417369000-7fa41736a000 rw-p 00000000 00:00 0 7fa41736a000-7fa418464000 r-xp 00000000 08:01 41959073 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so 7fa418464000-7fa418664000 ---p 010fa000 08:01 41959073 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so 7fa418664000-7fa4186bf000 r--p 010fa000 08:01 41959073 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so 7fa4186bf000-7fa4186c9000 rw-p 01155000 08:01 41959073 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so 7fa4186c9000-7fa4186d0000 rw-p 00000000 00:00 0 7fa4186d0000-7fa4186f2000 r-xp 00000000 08:01 25956145 /lib/x86_64-linux-gnu/ld-2.15.so 7fa4188b9000-7fa4188d3000 rw-p 00000000 00:00 0 7fa4188e5000-7fa4188f2000 rw-p 00000000 00:00 0 7fa4188f2000-7fa4188f3000 r--p 00022000 08:01 25956145 /lib/x86_64-linux-gnu/ld-2.15.so 7fa4188f3000-7fa4188f5000 rw-p 00023000 08:01 25956145 /lib/x86_64-linux-gnu/ld-2.15.so 7fffbd7c9000-7fffbd7eb000 rw-p 00000000 00:00 0 [stack] 7fffbd7fe000-7fffbd800000 r-xp 00000000 00:00 0 [vdso] ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall] Aborted (core dumped) alexei@alexei-OptiPlex-9010:~/OpenFOAM/alexei-2.2.0/changing_diff/whirl_0.05r_0.01in_3.0w$ paraFoam created temporary 'whirl_0.05r_0.01in_3.0w.OpenFOAM' --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : /home/alexei/OpenFOAM/alexei-2.2.0/platforms/linux64GccDPOpt/lib/libcustomcombustionModels.so: undefined symbol: _ZNK4Foam16combustionModels19rhoThermoCombustion3rhoEv --> FOAM Warning : From function dlLibraryTable::open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libcustomcombustionModels.so" (i also uploaded those mesh files if you were interested) |
August 26, 2015, 21:51 |
#15 |
A. Kamitsis
Rep Power: 10 |
Sorry for all the questions again - but does it make sense to you that I still get an error such as this even though I've successfully compiled the library with your help earlier?
alexei@alexei-OptiPlex-9010:~/OpenFOAM/alexei-2.2.0/fixedDiff/small/whirl_0.05r_0.01in_1.125w_7e-4Diff$ rotatingCDFireFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0 Exec : rotatingCDFireFoam Date : Aug 27 2015 Time : 11:48:44 Host : "alexei-OptiPlex-9010" PID : 9995 Case : /home/alexei/OpenFOAM/alexei-2.2.0/fixedDiff/small/whirl_0.05r_0.01in_1.125w_7e-4Diff nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Creating combustion model Selecting combustion model infinitelyFastChemistry<rhoThermoCombustion,gasThermoPhysics> --> FOAM FATAL ERROR: Unknown psiCombustionModel type infinitelyFastChemistry<rhoThermoCombustion,gasThermoPhysics> Valid combustionModels are : 8 ( noCombustion<psiThermoCombustion> diffusion<psiThermoCombustion,constGasThermoPhysics> PaSR<psiChemistryCombustion> infinitelyFastChemistry<psiThermoCombustion,gasThermoPhysics> FSD<psiThermoCombustion,gasThermoPhysics> infinitelyFastChemistry<psiThermoCombustion,constGasThermoPhysics> diffusion<psiThermoCombustion,gasThermoPhysics> FSD<psiThermoCombustion,constGasThermoPhysics> ) From function psiCombustionModel::New in file psiCombustionModel/psiCombustionModel/psiCombustionModelNew.C at line 62. FOAM exiting |
August 30, 2015, 17:07 |
#16 |
Bruno Santos
Rep Power: 128 |
Hi Alex,
The error log for the crash is incomplete. The real reason should be disclaimed before the long list of memory addresses you posted. Try running with the following command: Code:
rotatingCDFireFoam > log.rotatingCDFireFoam 2>&1 The issue with paraFoam is because the library that ParaView loads for opening OpenFOAM cases will only load the minimum libraries it needs. If you have your own libraries in "libs", the custom libraries will depend on other libraries that aren't loaded by default. The easiest workaround is to comment the "libs" entry. Or use the following command for listing the libraries that your solver depends on: Code:
ldd $(which rotatingCDFireFoam) Going back to the first crash: without the complete error log, it's hard to deduce why it crashed. My fear is that the case files they provided you are either incorrect, or you're working with the last development snapshot. In other words: given the issue I diagnosed for a previous post, the source code was left in a point where new developments were being tested but were not completed. It's possible the thesis author provided two types of folders:
Bruno
September 7, 2015, 09:21 |
#17 |
A. Kamitsis
Rep Power: 10 |
Bruno thanks again,
I believe you're right in that the folders i've been given were still under development - unfortunately the lecturer he was working under was not following the coding side of the project and only helping analyse results so he hasn't been much help. I've tried running another solver of a smaller case as an example for you and get the following error: Code:
*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0 Exec : constantdensityfireFoam Date : Sep 07 2015 Time : 22:00:43 Host : "alexei-OptiPlex-9010" PID : 6399 Case : /home/alexei/OpenFOAM/alexei-2.2.0/changing_diff/nowhirl_0.05r_0.01in nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Duplicate entry infinitelyFastChemistry<psiThermoCombustion,gasThermoPhysics> in runtime selection table psiCombustionModel #0 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+0x25) [0x7f5aace18cd5] #1 /home/alexei/OpenFOAM/alexei-2.2.0/platforms/linux64GccDPOpt/lib/libcustomcombustionModels.so(+0x1af66) [0x7f5aa6a74f66] #2 /lib64/ld-linux-x86-64.so.2(+0xf306) [0x7f5ab2d8a306] #3 /lib64/ld-linux-x86-64.so.2(+0xf3df) [0x7f5ab2d8a3df] #4 /lib64/ld-linux-x86-64.so.2(+0x13ada) [0x7f5ab2d8eada] #5 /lib64/ld-linux-x86-64.so.2(+0xf176) [0x7f5ab2d8a176] #6 /lib64/ld-linux-x86-64.so.2(+0x1331a) [0x7f5ab2d8e31a] #7 /lib/x86_64-linux-gnu/libdl.so.2(+0xf26) [0x7f5aac6b6f26] #8 /lib64/ld-linux-x86-64.so.2(+0xf176) [0x7f5ab2d8a176] #9 /lib/x86_64-linux-gnu/libdl.so.2(+0x152f) [0x7f5aac6b752f] #10 /lib/x86_64-linux-gnu/libdl.so.2(dlopen+0x31) [0x7f5aac6b6fc1] #11 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6dlOpenERKNS_8fileNameEb+0x45) [0x7f5aace11d25] #12 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_8fileNameEb+0x63) [0x7f5aacb7e7d3] #13 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_10dictionaryERKNS_4wordE+0x9d) [0x7f5aacb7fa9d] #14 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam4TimeC1ERKNS_4wordERKNS_7argListES3_S3_+0x63a) [0x7f5aacb9caea] #15 constantdensityfireFoam() [0x42a058] #16 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f5aabb0578d] #17 constantdensityfireFoam() [0x432181] Duplicate entry infinitelyFastChemistry<psiThermoCombustion,constGasThermoPhysics> in runtime selection table psiCombustionModel #0 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+0x25) [0x7f5aace18cd5] #1 /home/alexei/OpenFOAM/alexei-2.2.0/platforms/linux64GccDPOpt/lib/libcustomcombustionModels.so(+0x1b062) [0x7f5aa6a75062] #2 /lib64/ld-linux-x86-64.so.2(+0xf306) [0x7f5ab2d8a306] #3 /lib64/ld-linux-x86-64.so.2(+0xf3df) [0x7f5ab2d8a3df] #4 /lib64/ld-linux-x86-64.so.2(+0x13ada) [0x7f5ab2d8eada] #5 /lib64/ld-linux-x86-64.so.2(+0xf176) [0x7f5ab2d8a176] #6 /lib64/ld-linux-x86-64.so.2(+0x1331a) [0x7f5ab2d8e31a] #7 /lib/x86_64-linux-gnu/libdl.so.2(+0xf26) [0x7f5aac6b6f26] #8 /lib64/ld-linux-x86-64.so.2(+0xf176) [0x7f5ab2d8a176] #9 /lib/x86_64-linux-gnu/libdl.so.2(+0x152f) [0x7f5aac6b752f] #10 /lib/x86_64-linux-gnu/libdl.so.2(dlopen+0x31) [0x7f5aac6b6fc1] #11 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6dlOpenERKNS_8fileNameEb+0x45) [0x7f5aace11d25] #12 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_8fileNameEb+0x63) [0x7f5aacb7e7d3] #13 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_10dictionaryERKNS_4wordE+0x9d) [0x7f5aacb7fa9d] #14 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam4TimeC1ERKNS_4wordERKNS_7argListES3_S3_+0x63a) [0x7f5aacb9caea] #15 constantdensityfireFoam() [0x42a058] #16 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f5aabb0578d] #17 constantdensityfireFoam() [0x432181] Duplicate entry infinitelyFastChemistry<rhoThermoCombustion,gasThermoPhysics> in runtime selection table rhoCombustionModel #0 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+0x25) [0x7f5aace18cd5] #1 /home/alexei/OpenFOAM/alexei-2.2.0/platforms/linux64GccDPOpt/lib/libcustomcombustionModels.so(+0x1b00e) [0x7f5aa6a7500e] #2 /lib64/ld-linux-x86-64.so.2(+0xf306) [0x7f5ab2d8a306] #3 /lib64/ld-linux-x86-64.so.2(+0xf3df) [0x7f5ab2d8a3df] #4 /lib64/ld-linux-x86-64.so.2(+0x13ada) [0x7f5ab2d8eada] #5 /lib64/ld-linux-x86-64.so.2(+0xf176) [0x7f5ab2d8a176] #6 /lib64/ld-linux-x86-64.so.2(+0x1331a) [0x7f5ab2d8e31a] #7 /lib/x86_64-linux-gnu/libdl.so.2(+0xf26) [0x7f5aac6b6f26] #8 /lib64/ld-linux-x86-64.so.2(+0xf176) [0x7f5ab2d8a176] #9 /lib/x86_64-linux-gnu/libdl.so.2(+0x152f) [0x7f5aac6b752f] #10 /lib/x86_64-linux-gnu/libdl.so.2(dlopen+0x31) [0x7f5aac6b6fc1] #11 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6dlOpenERKNS_8fileNameEb+0x45) [0x7f5aace11d25] #12 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_8fileNameEb+0x63) [0x7f5aacb7e7d3] #13 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_10dictionaryERKNS_4wordE+0x9d) [0x7f5aacb7fa9d] #14 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam4TimeC1ERKNS_4wordERKNS_7argListES3_S3_+0x63a) [0x7f5aacb9caea] #15 constantdensityfireFoam() [0x42a058] #16 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f5aabb0578d] #17 constantdensityfireFoam() [0x432181] Duplicate entry infinitelyFastChemistry<rhoThermoCombustion,constGasThermoPhysics> in runtime selection table rhoCombustionModel #0 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+0x25) [0x7f5aace18cd5] #1 /home/alexei/OpenFOAM/alexei-2.2.0/platforms/linux64GccDPOpt/lib/libcustomcombustionModels.so(+0x1afba) [0x7f5aa6a74fba] #2 /lib64/ld-linux-x86-64.so.2(+0xf306) [0x7f5ab2d8a306] #3 /lib64/ld-linux-x86-64.so.2(+0xf3df) [0x7f5ab2d8a3df] #4 /lib64/ld-linux-x86-64.so.2(+0x13ada) [0x7f5ab2d8eada] #5 /lib64/ld-linux-x86-64.so.2(+0xf176) [0x7f5ab2d8a176] #6 /lib64/ld-linux-x86-64.so.2(+0x1331a) [0x7f5ab2d8e31a] #7 /lib/x86_64-linux-gnu/libdl.so.2(+0xf26) [0x7f5aac6b6f26] #8 /lib64/ld-linux-x86-64.so.2(+0xf176) [0x7f5ab2d8a176] #9 /lib/x86_64-linux-gnu/libdl.so.2(+0x152f) [0x7f5aac6b752f] #10 /lib/x86_64-linux-gnu/libdl.so.2(dlopen+0x31) [0x7f5aac6b6fc1] #11 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6dlOpenERKNS_8fileNameEb+0x45) [0x7f5aace11d25] #12 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_8fileNameEb+0x63) [0x7f5aacb7e7d3] #13 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_10dictionaryERKNS_4wordE+0x9d) [0x7f5aacb7fa9d] #14 /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam4TimeC1ERKNS_4wordERKNS_7argListES3_S3_+0x63a) [0x7f5aacb9caea] #15 constantdensityfireFoam() [0x42a058] #16 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f5aabb0578d] #17 constantdensityfireFoam() [0x432181] Create mesh for time = 0 Reading g Creating combustion model Selecting combustion model diffusion<rhoThermoCombustion,gasThermoPhysics> --> FOAM FATAL ERROR: Unknown psiCombustionModel type diffusion<rhoThermoCombustion,gasThermoPhysics> Valid combustionModels are : 8 ( noCombustion<psiThermoCombustion> diffusion<psiThermoCombustion,constGasThermoPhysics> PaSR<psiChemistryCombustion> infinitelyFastChemistry<psiThermoCombustion,gasThermoPhysics> FSD<psiThermoCombustion,gasThermoPhysics> infinitelyFastChemistry<psiThermoCombustion,constGasThermoPhysics> diffusion<psiThermoCombustion,gasThermoPhysics> FSD<psiThermoCombustion,constGasThermoPhysics> ) From function psiCombustionModel::New in file psiCombustionModel/psiCombustionModel/psiCombustionModelNew.C at line 62. FOAM exiting The case is attempting to simulate a non-whirling fire under constant density conditions if this helps. Kind regards, Alexei |
September 7, 2015, 18:30 |
#18 |
Bruno Santos
Rep Power: 128 |
Hi Alexei,
I won't be able to look into the case before the weekend, but from your description and the output error message, it feels like you didn't mention some important detail: did you compile/build any other library? I ask this because the two error messages are implying that something is amiss with one or two libraries:
Bruno
September 19, 2015, 22:17 |
#19 |
A. Kamitsis
Rep Power: 10 |
Hi Bruno,
I've decided to just re-write the re-build the custom solver's and they seem to be working much better now, however I've tried running a case in parallel and received the following output (it was going ok for a little while before this), would you be able to offer any advice on this? I've run: Code:
mpirun -np 8 dynamicDensity -parallel Code:
Courant Number mean: 7.06846e-07 max: 0.551005 deltaT = 1.29191e-22 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 1029 Increased the timePrecision from 152 to 153 to distinguish between timeNames at time 0.204108 Time = 0.2041082395427052109670995605483767576515674591064453125 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 9.05426e-11, Final residual = 9.05426e-11, No Iterations 0 DILUPBiCG: Solving for Uy, Initial residual = 9.05425e-11, Final residual = 9.05425e-11, No Iterations 0 DILUPBiCG: Solving for Uz, Initial residual = 9.05423e-11, Final residual = 9.05423e-11, No Iterations 0 DILUPBiCG: Solving for O2, Initial residual = 5.91346e-08, Final residual = 5.91346e-08, No Iterations 0 DILUPBiCG: Solving for H2O, Initial residual = 6.47461e-08, Final residual = 6.47461e-08, No Iterations 0 DILUPBiCG: Solving for CH4, Initial residual = 9.28681e-08, Final residual = 9.28681e-08, No Iterations 0 DILUPBiCG: Solving for CO2, Initial residual = 6.47461e-08, Final residual = 6.47461e-08, No Iterations 0 DILUPBiCG: Solving for h, Initial residual = 8.66642e-09, Final residual = 8.66642e-09, No Iterations 0 min/max(T) = 200, 5000 GAMG: Solving for p_rgh, Initial residual = 1.65213e-12, Final residual = 1.65213e-12, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.9777e-15, global = 2.49275e-18, cumulative = -0.000943226 GAMG: Solving for p_rgh, Initial residual = 1.85273e-12, Final residual = 1.85273e-12, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 3.34043e-15, global = 2.50425e-18, cumulative = -0.000943226 DILUPBiCG: Solving for k, Initial residual = 3.01901e-06, Final residual = 1.54484e-18, No Iterations 1 bounding k, min: 1e-15 max: 1.03582e+07 average: 282.151 ExecutionTime = 542.76 s ClockTime = 557 s Courant Number mean: 7.06846e-07 max: 0.551005 deltaT = 1.17232e-22 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 1029 Increased the timePrecision from 153 to 154 to distinguish between timeNames at time 0.204108 Time = 0.2041082395427052109670995605483767576515674591064453125 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 9.05426e-11, Final residual = 9.05426e-11, No Iterations 0 DILUPBiCG: Solving for Uy, Initial residual = 9.05426e-11, Final residual = 9.05426e-11, No Iterations 0 DILUPBiCG: Solving for Uz, Initial residual = 9.05424e-11, Final residual = 9.05424e-11, No Iterations 0 DILUPBiCG: Solving for O2, Initial residual = 5.91346e-08, Final residual = 5.91346e-08, No Iterations 0 DILUPBiCG: Solving for H2O, Initial residual = 6.47461e-08, Final residual = 6.47461e-08, No Iterations 0 DILUPBiCG: Solving for CH4, Initial residual = 9.28681e-08, Final residual = 9.28681e-08, No Iterations 0 DILUPBiCG: Solving for CO2, Initial residual = 6.47461e-08, Final residual = 6.47461e-08, No Iterations 0 DILUPBiCG: Solving for h, Initial residual = 1.0519e-08, Final residual = 3.68864e-21, No Iterations 1 min/max(T) = 200, 5000 GAMG: Solving for p_rgh, Initial residual = 3.07879e-06, Final residual = 3.24144e-15, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 5.95489e-15, global = -5.85787e-15, cumulative = -0.000943226 GAMG: Solving for p_rgh, Initial residual = 3.46474e-12, Final residual = 3.46474e-12, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 4.59862e-16, global = 6.04504e-19, cumulative = -0.000943226 DILUPBiCG: Solving for k, Initial residual = 3.35215e-06, Final residual = 1.71052e-18, No Iterations 1 bounding k, min: 1e-15 max: 1.03582e+07 average: 282.163 ExecutionTime = 543.29 s ClockTime = 558 s Courant Number mean: 8.53153e-07 max: 0.665054 deltaT = 8.81371e-23 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 1029 Increased the timePrecision from 154 to 155 to distinguish between timeNames at time 0.204108 Time = 0.2041082395427052109670995605483767576515674591064453125 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 7.50155e-11, Final residual = 7.50155e-11, No Iterations 0 DILUPBiCG: Solving for Uy, Initial residual = 7.50155e-11, Final residual = 7.50155e-11, No Iterations 0 DILUPBiCG: Solving for Uz, Initial residual = 7.50153e-11, Final residual = 7.50153e-11, No Iterations 0 DILUPBiCG: Solving for O2, Initial residual = 5.91346e-08, Final residual = 5.91346e-08, No Iterations 0 DILUPBiCG: Solving for H2O, Initial residual = 6.47461e-08, Final residual = 6.47461e-08, No Iterations 0 DILUPBiCG: Solving for CH4, Initial residual = 9.28681e-08, Final residual = 9.28681e-08, No Iterations 0 DILUPBiCG: Solving for CO2, Initial residual = 6.47461e-08, Final residual = 6.47461e-08, No Iterations 0 DILUPBiCG: Solving for h, Initial residual = 1.29364e-09, Final residual = 1.29364e-09, No Iterations 0 min/max(T) = 200, 5000 GAMG: Solving for p_rgh, Initial residual = 6.24552e-12, Final residual = 6.24552e-12, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.12917e-14, global = -8.80768e-15, cumulative = -0.000943226 GAMG: Solving for p_rgh, Initial residual = 6.41168e-12, Final residual = 6.41168e-12, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.15923e-14, global = -8.80767e-15, cumulative = -0.000943226 DILUPBiCG: Solving for k, Initial residual = 3.08592e-06, Final residual = 1.30013e-18, No Iterations 1 bounding k, min: 1e-15 max: 1.03582e+07 average: 282.175 ExecutionTime = 543.82 s ClockTime = 558 s Courant Number mean: 7.06846e-07 max: 0.551005 deltaT = 7.99785e-23 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 1029 Increased the timePrecision from 155 to 156 to distinguish between timeNames at time 0.204108 Time = 0.2041082395427052109670995605483767576515674591064453125 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 7.50155e-11, Final residual = 7.50155e-11, No Iterations 0 DILUPBiCG: Solving for Uy, Initial residual = 7.50155e-11, Final residual = 7.50155e-11, No Iterations 0 DILUPBiCG: Solving for Uz, Initial residual = 7.50153e-11, Final residual = 7.50153e-11, No Iterations 0 DILUPBiCG: Solving for O2, Initial residual = 5.91346e-08, Final residual = 5.91346e-08, No Iterations 0 DILUPBiCG: Solving for H2O, Initial residual = 6.47461e-08, Final residual = 6.47461e-08, No Iterations 0 DILUPBiCG: Solving for CH4, Initial residual = 9.28681e-08, Final residual = 9.28681e-08, No Iterations 0 DILUPBiCG: Solving for CO2, Initial residual = 6.47461e-08, Final residual = 6.47461e-08, No Iterations 0 DILUPBiCG: Solving for h, Initial residual = 1.56629e-09, Final residual = 1.56629e-09, No Iterations 0 min/max(T) = 200, 5000 GAMG: Solving for p_rgh, Initial residual = 1.37483e-12, Final residual = 1.37483e-12, No Iterations 0 [1] #0 Foam::error::printStack(Foam::Ostream&) in "/home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigHandler(int) in "/home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #4 void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/alexei/OpenFOAM/alexei-2.2.0/platforms/linux64GccDPOpt/bin/dynamicDensity" [1] #5 [1] in "/home/alexei/OpenFOAM/alexei-2.2.0/platforms/linux64GccDPOpt/bin/dynamicDensity" [1] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [1] #7 [1] in "/home/alexei/OpenFOAM/alexei-2.2.0/platforms/linux64GccDPOpt/bin/dynamicDensity" [alexei-OptiPlex-9010:05924] *** Process received signal *** [alexei-OptiPlex-9010:05924] Signal: Floating point exception (8) [alexei-OptiPlex-9010:05924] Signal code: (-6) [alexei-OptiPlex-9010:05924] Failing at address: 0x3e800001724 [alexei-OptiPlex-9010:05924] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36570) [0x7ff8b48dc570] [alexei-OptiPlex-9010:05924] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7ff8b48dc4f5] [alexei-OptiPlex-9010:05924] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36570) [0x7ff8b48dc570] [alexei-OptiPlex-9010:05924] [ 3] /home/alexei/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0xe6) [0x7ff8b5b0bfe6] [alexei-OptiPlex-9010:05924] [ 4] dynamicDensity(_ZN4Foam6divideINS_13fvsPatchFieldENS_11surfaceMeshEEEvRNS_14GeometricFieldIdT_T0_EERKS6_S9_+0x3e) [0x45316e] [alexei-OptiPlex-9010:05924] [ 5] dynamicDensity() [0x428b26] [alexei-OptiPlex-9010:05924] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7ff8b48c778d] [alexei-OptiPlex-9010:05924] [ 7] dynamicDensity() [0x42cfad] [alexei-OptiPlex-9010:05924] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 1 with PID 5924 on node alexei-OptiPlex-9010 exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- Alexei |
September 20, 2015, 06:36 |
#20 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Alexei,
My advice: baby steps. Don't try to isolate 100 problems all at once, create small test cases and isolate one problem at a time. Best regards, Bruno
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Segmentation fault running waveDyMFoam solver (mod. interDyMFoam solver - waves2Foam) | Ed R | OpenFOAM Running, Solving & CFD | 5 | July 2, 2013 11:36 |
Problems running customized solver for diffusion | mmkr825 | OpenFOAM Running, Solving & CFD | 1 | August 30, 2012 14:01 |
problem in running a modified solver | adambarfi | OpenFOAM | 5 | August 10, 2012 15:52 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
