February 6, 2012, 01:35 |
FSI solver
aignn
hi
i work with openfoam 1.5 and i need to use fsi "Fluid Structure Interaction"solver and cant find it how can install it and use it? please tanks |
February 6, 2012, 09:40 |
aignn
anyone?
please help me |
February 6, 2012, 16:33 |
Philip Cardiff
Rep Power: 34 |
There is icoFsiFoam in OpenFOAM-1.6-ext found at $FOAM_SOLVERS/stressAnalysis/icoFsiFoam. You can find quite a bit on FSI if you search the forum. Philip |
February 7, 2012, 03:06 |
aignn
i havn't opneFoam 1.6 i just have 1.5,and 2.00
is there any way to insltall it? |
February 7, 2012, 04:56 |
Philip Cardiff
Rep Power: 34 |
If you search the forum, you will find a lot of information on FSI.
As far as I know you must use the Extend version of OpenFOAM i.e. OpenFOAM-1.6-ext Philip |
February 7, 2012, 10:42 |
the Slax Live Image was for the OpenFoam workshop (4th) in Montreal (2009) if I am not mistaken. the last Openfoam Workshop (6th) (2011)was in Penn State and the Image (Ubuntu LTS image) that was made for this workshop can still be downloaded http://rcc.its.psu.edu/ofw6/ofw6_v8.iso this Image contains Openfoam 1.6-extend => so you have FSI stuff is on that Live-Image. As you are interested in FSI have a look at http://www.openfoamworkshop.org/6th_...m/training.htm Multi-Zonal Multi-Physics Modeling: FSI and Congjugate Heat/Mass Transfer, R. Campbell and B. Craven, PSU http://www.openfoamworkshop.org/6th_...ven_slides.pdf http://www.openfoamworkshop.org/6th_...erTraining.tgz http://www.openfoamworkshop.org/6th_...ell_slides.pdf http://www.openfoamworkshop.org/6th_...mpbell_fsi.tgz http://www.openfoamworkshop.org/6th_...ord_slides.pdf and http://www.openfoamworkshop.org/6th_...rdi_slides.pdf http://www.openfoamworkshop.org/6th_...chi_slides.pdf Do you want to run a CFD (Openfoam) <=> FEM (Openfoam) FSI Simulation or a CFD (Openfoam) <=> FEM (not Openfoam(lets say Calculix or something else) FSI Simulation? Do you use GGI to calculate on non conforming meshes? |
different results between serial solver and parallel solver | wlt_1985 | FLUENT | 11 | October 12, 2018 08:23 |
error in two way fsi | kmgraju | CFX | 1 | May 2, 2011 02:32 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
FSI Negative Element Volume Fatal Error | Aaron | CFX | 2 | July 1, 2008 20:48 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
