Explanation of "solve"-function
Hello out there in the big OpenFOAM-world.
Is there anybody who can really explain to me the solve-function? If I look at Code:
->solve(psiCmpt, sourceCmpt, cmpt); - But where is that solver really defined? - Where can i find the actual definition of the function "solve()"? And if there is somebody really knowing about that solve-function: - Is there a way to call that solve() for a specific cell only? I am kind of lost with the C++ stuff or at least inside the structure of OpenFOAM, so any help is welcome! |
Hi Bernhard, did you find any information regarding the functionality of the solve() function? Thanks.
The solve function you are looking at is a virtual function ( http://foam.sourceforge.net/docs/cpp/a02380.html ) which is redefined for each solver (diagonalSolver, GAMGSolver, ...).
If you want to solve a linear system directly in a cell or a limited number of cells, you probably want to follow a simpler way. You can, for example, use a scalarSquareMatrix and use LU decomposition on it (OF can do it). |
