-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   interFoam : post processing (http://www.cfd-online.com/Forums/openfoam-programming-development/97545-interfoam-post-processing.html)
udiitm February 20, 2012 07:16
I want to collect the cell information on the basis of alpha value ( 0.5 i.e. at interface) and the pressure at nearby cells with their x and y co-ordinates.
The information i have to get is interface.sigmaK())*fvc::snGrad(alpha1)
in the part
fvc::interpolate(interface.sigmaK())*fvc::snGrad(a lpha1)
- ghf*fvc::snGrad(rho)
Please tell me how to extract these information?
I need the information in the following format:
for each value of alpha=0.5 i.e at interface
Co- ordinates.... value of sigmaK* grad(alpha)....... Value of pressure at near by cells
X Y................... (as mentioned above).................. p1 p2 p3 p4
regards,
Yudhast
Bernhard February 20, 2012 09:22
What is your question?
udiitm February 21, 2012 02:10
Dear Bernhard,
Sorry for the incomplete thread...My question is how to get the information of Cell at interface and the corresponding value of sigmaK*grad(alpha) and pressure value at near by cell as i have edited in original thread?
Thanks
Yudhast
Bernhard February 21, 2012 04:11
The easiest would be to do this during runtime.
Create a volVectorField (name X here), like for U in createFields.H (only replace MUST_READ by NO_READ)
Then you can easily write
X=interface.sigmaK()*fvc::grad(alpha1)
or
X=fvc::reconstruct( fvc::interpolate(interface.sigmaK() ) * fvc::snGrad(alpha1) )
This should be enough to recompile. During runtime you will now create a field X.
You can combine this with sampling during runtime put this in your controlDict
functions
    interface
        type            surfaces;
        functionObjectLibs
            "libsampling.so"
        outputControl  outputTime;
        outputInterval  1;
        surfaceFormat  vtk;
        fields
            alpha1
            X
        surfaces
            freeSurface
                type        isoSurfaceCell;
                isoField    alpha1;
                isoValue    0.5;
                interpolate false;
                regularise  false;
        interpolationScheme cell;
Which basically creates an iso-surface at alpha1=0.5, and interpolates X to it. The resulting vtk files can easily be read in ParaView,
Good luck!
udiitm February 23, 2012 05:58
Dear Bernhard,
Thanks for your reply. I have tried to compile the changes in createField.H but got an error:
error: ‘interface’ was not declared in this scope
when i used the expression for "X" i.e.
X=fvc::interpolate(interface.sigmaK())*fvc::snGrad (alpha1) 'OR'
X=fvc::reconstruct(fvc::interpolate(interface.sigm aK())*fvc::snGrad(alpha1))
Regards,
Yudhast
Bernhard February 23, 2012 06:32
My excuses for being incomplete in my previous post.
In createFields.H you only create the field X as you create U (just to have it somewhere available)
You want to update and store the value for X each timestep, so your expression should be inside the timeloop. createFields is of course only executed once, before the simulation really starts. I would put it in the main file (interFoam.C), just in front of runTime.write(). (Also give it a name different from X, to make it more or less self-explanatory for future users)
Finally, it is always a good idea to carefully read the errormessages of the compiler, since they give a good explanation on where to find the error. As interface was not declared, I suppose you put the line with X higher than line 87 of createFields.H.
udiitm March 2, 2012 01:30
Dear Bernhard,
your suggestion was very helpful for solving my problem
Regards,
yuhdast
udiitm March 21, 2012 06:47
Dear Bernhard,
Thanks for your suggestion.
Now I want to get the information of cells ( elements) which contains some value for the variable "X" calculated by above steps.
I am actually looking for the neighbour cells for the cells containing non-zero value of variable "X" to manipulate pressure and other values. i.e.
suppose for cell(i,j) with X = non-zero value
I need pressure (P) for cells ( i+1,j ; i-1,j ; i,j-1 ; i,j+1 ; i,j-1)
Thanks and Regards,
Yudhast
angelmonsalve August 11, 2015 18:10
Thanks for this explanation!! couple of years later but works pretty well
