March 8, 2012, 05:23 |
alphaEqn in multiphaseInterFOAM 2.1
Sina Saremi
Rep Power: 14 |
Hi all!
multiphaseInterFOAM didn't give physical results in previous versions, until it has been modified in version 2.1, and the results are now apparently acceptable. So I have decided to use this solver for my 3 phase case. I need to make some minor modifications in the phase transport equations (alpha equations). In previous versions, the alphaEqn could clearly be seen in the multiphaseMixture.C file (line 528), but the same file in version 2.1 has gone under changes and now I can not see any alphaEqn anywhere in the solver! I would be pleased if someone could tell me where and how the transport equations are solved in this solver? Sina |
March 8, 2012, 11:15 |
Anton Kidess
Rep Power: 29 |
The solution call is now in a separate class Foam::multiphaseMixture::solve(). See multiphaseInterFoam/multiphaseMixture/multiphaseMixture.C
- Anton
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
March 9, 2012, 04:30 |
Sina Saremi
Rep Power: 14 |
Thanks Anton! yes it seems that the alpha equations are taken care by MULES (in a similar way as in InterFoam).... and that probably makes it more difficult to make some personal changes in them
Sina |
alphaeqn, multiphaseinterfoam, version 2.1 |
No reactions in reactingFoam 2.1 | OMN | OpenFOAM Running, Solving & CFD | 16 | April 7, 2015 12:14 |
[Other] From Pointwise to OpenFoam 2.1 cyclicAMI... | lordvon | OpenFOAM Meshing & Mesh Conversion | 9 | February 9, 2015 15:08 |
VOF fraction in multiphaseInterFoam | mahaputra | OpenFOAM Running, Solving & CFD | 1 | August 27, 2009 08:15 |
Possible bug in multiphaseInterFoam | msrinath80 | OpenFOAM Bugs | 16 | March 25, 2008 20:09 |
FIDAP on glibc 2.1 | Ingo Meisel | FLUENT | 2 | February 1, 2002 05:15 |
