-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   magSf() on boundaries (http://www.cfd-online.com/Forums/openfoam-programming-development/98590-magsf-boundaries.html)
lichmaster March 14, 2012 10:53
Hi FOAMers,
how do I get magSf() on bounday faces?
I noticed that mesh.magSf()[faceI] gives correct results on internal faces, but when faceI is on a face, it gives ~1e-320...
label startFace = mesh.boundaryMesh()[ib].start();
label nFaces    = mesh.boundaryMesh()[ib].size();
for (label faceI = startFace; faceI < startFace + nFaces; faceI++)
vector normal = mesh.Sf()[faceI]/mesh.magSf()[faceI]; \\floating point error
What's wrong ?
lichmaster March 15, 2012 05:22
I've solved this problem, simply taking
mag(mesh.Sf()[faceI]);
However, I really can't understand why there isn't a mesh.magSf() method for boundary faces when there is a mesh.Sf() method defined on them...
ngj March 15, 2012 05:30
Hi
You should be able to access the data in any of the following manners:
const scalarField magnitude0 = Foam::mag( mesh.Sf().boundaryField()[patchi] );
const scalarField & magnitude1 = mesh.magSf().boundaryField()[patchi];
This gives you the magnitude of the normal vectors on a given patch through its index patchi.
Best regards,
Niels
