Home > Forums > OpenFOAM Programming & Development
Writing IOdictionary to user-defined folder
Old   March 19, 2012, 04:11
Default Writing IOdictionary to user-defined folder
Arne Stahlmann
Arnoldinho is on a distinguished road
Hi foamers,
I would like to create a specific (new) IOdictionary to store some values and save it in a used-defined folder. Generating the IOdictionary itself works, saving it to the folder does not fully work. I so far did
fileName writeDirectory = "constant/boundaryField";
mkDir(writeDirectory);
IOdictionary vectorDict
IOobject
"a",
writeDirectory,
runTime,
IOobject::NO_READ,
IOobject::AUTO_WRITE
vectorDict.Foam::regIOobject::write();
This does not write anything to folder "constant/boundaryField" (which itself is created). When I replace "writeDirectory" in IOobject with runTime.constant(), the dict is written in the constant folder. Taking runTime.constant()/"boundaryField" again does not work.
So I guess I have to register this boundaryField folder somehow?
Btw: This is done in a post-processing tool, so not during runtime of a solver.
Arne
Arnoldinho is offline   Reply With Quote
Old   March 20, 2012, 03:14
Mark Olesen
olesen will become famous soon enough
Originally Posted by Arnoldinho View Post
Hi foamers,
Arne
From your description, it sounds like you want to have "constant" as the _instance_ and "boundaryField" as the _local_. From your example, it sounds like you've tried to pack everything into _instance_. Take a look at the IOobject.H for more information about the different types of constructors.
If you *really* know what you are doing, and want to bypass the usual mechanisms, you can also experiment with the following constructor form ... but you are really on your own here (there is a large potential of creating something stupid if you are not careful):
        //- Construct from path, registry, io options
        //  Uses fileNameComponents() to split path into components.
        IOobject
            const fileName& path,
            const objectRegistry& registry,
            readOption r=NO_READ,
            writeOption w=NO_WRITE,
            bool registerObject=true
olesen is offline   Reply With Quote
Old   March 20, 2012, 03:31
Arne Stahlmann
Thanks Mark,
maybe its not that complicated/bad as it sounds. The only reason of using an IOdictionary is that I did not know a better structure for storing several List<vectorField> object entries within one file (including header).
It does not really matter where this dictionary is saved, but I just want to keep the structure clear. Therefore a subfolder with several dictionaries in it. This came to my mind because the folder structure created by the sample tool (folder "surfaces" with subfolders) is similar and I want to create something like that.
Arne
Thread Tools
Trackbacks are On
Creating new user defined material Vidya FLUENT 4 August 26, 2013 09:26
User Defined function for scalar gradient caculation with Star ccm+ V4 coolio CD-adapco 3 December 21, 2011 18:13
user defined sourcen term xck1986 CFX 1 July 8, 2010 08:35
user defined turbulence model manuutin STAR-CD 5 October 14, 2009 05:29
Usage of user defined functions Gowrish FLUENT 1 October 26, 2005 07:44
