-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Unknown patchTypefield "turbulentIntensityKineticEnergyInlet" (http://www.cfd-online.com/Forums/openfoam-programming-development/99273-unknown-patchtypefield-turbulentintensitykineticenergyinlet.html)
mabinty March 30, 2012 05:37
dear all,
i created a utility for post processing where i manipulate variables of the RAS turbulence model (in OF-1.7.1). when i apply it to a case using the "turbulentIntensityKineticEnergyInlet" BC for k, the utility crashes at the line
const volSymmTensorField RS = RASModel->R();
with the error message:
HTML Code:
--> FOAM FATAL ERROR:
Unknown patchTypefield type turbulentIntensityKineticEnergyInlet
Valid patchField types are :
30
advective
calculated
compressible::kqRWallFunction
cyclic
directMapped
directionMixed
empty
fixedGradient
fixedInternalValue
fixedMeanValue
fixedValue
freestream
inletOutlet
mixed
oscillatingFixedValue
outletInlet
outletMappedUniformInlet
partialSlip
processor
sliced
slip
symmetryPlane
timeVaryingMappedFixedValue
timeVaryingUniformFixedValue
timeVaryingUniformInletOutlet
turbulentInlet
uniformFixedValue
waveTransmissive
wedge
zeroGradient
    From function fvPatchField<Type>::New(const word&, const fvPatch&, const DimensionedField<Type, volMesh>&)
    in file /home/opencfd/OpenFOAM/OpenFOAM-1.7.x/src/finiteVolume/lnInclude/newFvPatchField.C at line 53.
FOAM exiting
i had a look at the definition of R (src/turbulenceModels/compressible/RAS/kEpsilon/kEpsilon.C):
tmp<volSymmTensorField> kEpsilon::R() const
    return tmp<volSymmTensorField>
        new volSymmTensorField
            IOobject
                "R",
                runTime_.timeName(),
                mesh_,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            ((2.0/3.0)*I)*k_ - (mut_/rho_)*dev(twoSymm(fvc::grad(U_))),
            k_.boundaryField().types()
i assume (cause i don t really know what the last line in the IOobject definition means), that through the line "k_.boundaryField().types()" R checks k BCs and cannot find "turbulentIntensityKineticEnergyInlet". i cannot really understand this behaviour as "turbulentIntensityKineticEnergyInlet" is part of the finiteVolume lib, which i included in the option file of my utility and is also present in the option file of the turbulence model lib.
does anybody know what i m doing wrong here?
thanks in adcance!
beste regards,
aram
