Deep modification of turbulence model
Hi all,
I am currently working in porous media flow with free surface using a customized interFoam (OF2.1.0). So far the model has proven to be stable, but it runs for laminar turbulence model. Now I have to modify kEpsilon to add the closure terms needed. In order to do so I have to make kEpsilon to accept another field (porosity) at the time of creation, but that is kind of a secondary question for now. As a first step I am trying to eliminate the unwanted functions e.g. R(), as I will only be using the model for myInterFoam. I changed the name of the model to kEpsilonPor and it compiles flawlessly. Then I removed all the references to R() in kEpsilonPor.H and kEpsilonPor.C and it did not compile. To proceed I changed "files" and "options" from Make folder: files Code:
kEpsilonPor.C Code:
EXE_INC = \ Everything compiles well, getting rid of the mentioned references to R() in RASModel.C, RASModel.H and turbulenceModel.H. The problem is that when I run any case using the new turbulence model I keep getting: Code:
kEpsilonPorCoeffs Any hints on what could be happening and how to fix it? Thanks Pablo |
Hi everybody
In the createFields of my solver I create a pointer on an RASModel named turbulence (same as for example in the createFields of simpleFoam). My problem is that I would like to access the name of the turbulence model. I'm using OF2.1.x. In other versions this was possible with turbulence->typeModel() but this is no more available. Do you have any suggestions? Thanks in advance |
