Home > Forums > OpenFOAM Programming & Development
Automate execution of command line
Old   August 7, 2012, 08:16
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings to all!
@samiam1000: The first line shouldn't have quotes:
#!/bin/bash
There is a major flaw in your current script: "foamJob -p" will launch and run in the background automatically, leading the rest of the script to executed immediately after foamJob is executed. A quick fix would be to run with "foamJob -s -p".
By what I can understand, it's not foamJob that needs nohup, it's the call to this script that needs this! For example, if you call this script "runcase.sh", you'll need to:
  1. The script should be something like this:
    #!/bin/bash
    foamJob -s -p buoyantPimpleFoam
    reconstructPar
    cd ../1DegNew/
    mapFields -consistent ../1DegStartNew -sourceTime 100
    decomposePar
    buoyantPimpleDyMFoam_MS
    sed -i 's/1/2/' system/controlDict
    sed -i 's/2/3/' system/controlDict
    sed -i 's/3/4/' system/controlDict
    sed -i 's/4/5/' system/controlDict
    sed -i 's/5/6/' system/controlDict
  2. After you edit and save the script for the first time, make sure it is an executable script:
    chmod a+x runcase.sh
  3. Then for running the script:
    nohup ./runcase.sh
Last but not least, why aren't you following the examples shown in the tutorials? For example, see "incompressible/simpleFoam/turbineSiting/Allrun". The downside of this example is that it will only run in the machine where it is launched...
Best regards,
Bruno
___
I'll be at OFW11 in Portugal
Old   August 7, 2012, 08:21
Assistant Moderator
Bernhard Gschaider
Originally Posted by samiam1000 View Post
If I understood well, I can write a launch.sh file like this:
'#!/bin/bash'
nohup foamJob -p buoyantPimpleFoam;
reconstructPar;
cd ../1DegNew/;
mapFields -consistent ../1DegStartNew -sourceTime 100;
decomposePar;
buoyantPimpleDyMFoam_MS;
sed -i 's/1/2/' system/controlDict;
sed -i 's/2/3/' system/controlDict;
sed -i 's/3/4/' system/controlDict;
sed -i 's/4/5/' system/controlDict;
sed -i 's/5/6/' system/controlDict;
Is that correct?
Thanks a lot,
Samuele
No. I was answering the mpirun-issue. I don't use foamJob so I can't comment on your script
Thread Tools
Trackbacks are On
Execution termination vidhya CFX 2 April 6, 2011 07:40
Execution problems in dsmcFOAM turanc OpenFOAM Running, Solving & CFD 2 March 10, 2011 11:04
How to automate geometry, mesh and case setup using starccm+ jwillie2000 STAR-CCM+ 3 January 26, 2011 12:13
Measuring an Execution Time - f90 su Main CFD Forum 11 July 4, 2008 07:21
Background execution on UNIX systems law FLUENT 1 January 3, 2006 11:53
