Home > Forums > OpenFOAM Programming & Development
libOpenSMOKE
Like Tree128Likes
Old   December 19, 2012, 19:27
Tobi's Avatar
Tobias Holzmann
Tobi will become famous soon enoughTobi will become famous soon enough
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
first thanks to zubs (Bernhard). He told me that there is a error while compiling the simple solver. I did a definition two times. I updated the solver and now everything is working.
second.
I had a meeting with my advicer but there is no way to get the thesis completely or parts of it. The only way it should be possible is to make a paper but therefor I have no time
But if you have questions, you can ask me or email me!
Keep SMOKING
Tobi is offline   Reply With Quote
Old   December 24, 2012, 06:12
Bobi
babakflame is on a distinguished road
Dear Tobi
Hi
I have a question about the adiabatic mode. Do we need to use the adiabatic mode for modeling a combustion chamber and if yes, Why?
babakflame is offline   Reply With Quote
Old   December 24, 2012, 07:30
Tobi's Avatar
Tobias Holzmann
If you use the adiabatic mode you have no head lose. You can test your chamber with the adiabatic mode and then using the non-adiabatic mode (radiation model turned off) to compare the differences.
Old   January 6, 2013, 17:02
Default flamelt
  #104
Ali Lohrasbi Nichkoohi
nichkoohi is on a distinguished road
DEAR TOBI
I SAW YOUR opensmoke code , i think it is same as the code that developed on rostok university by hanns kroger. there is an application for les -flamelet that called FGM. do you see it?if ya, what is your idea about it?
nichkoohi is offline   Reply With Quote
Old   January 7, 2013, 06:50
Tobi's Avatar
Tobias Holzmann
Originally Posted by nichkoohi View Post
DEAR TOBI
do you have a link to the code?
Then I ll have a look at it.
Tobi
Old   January 7, 2013, 08:00
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Hi Tobi and Ali,
I was curious and did a little searching on this... I think it's this one: http://openfoamwiki.net/index.php/Si...e_contribution
Best regards,
Bruno
Old   January 8, 2013, 06:53
Default flamelet
  #107
dear tobi
thanks
because the server is changed, the new link of the source code of LTTRostockExtensions is here
http://www.kroegeronline.net/exchang...Extensions.tgz.
Old   January 8, 2013, 07:39
Tobi's Avatar
Tobias Holzmann
I had a look at the downloadlink and untared the folder.
Unfortunatelly there are so many folders that its not possible to tell you if its the same like Alberto `s Libs.
I read something about beta-pdf but the whole stuff includes more than the flamelet-LES model (I think).
Sorry.
Old   January 8, 2013, 11:46
Default flamelet
  #109
hi tobi
thank u for your attention. sir do u see firefoam solver on O.F 2.0.0 i think it is a solver for diffusion flame with unsteady flamelet aspect that use both LES and RANS for turbulence modeling. am i right?
Old   January 9, 2013, 06:02
Bobi
Dear All guys
Hi
I think firefoam was first built by infinitelyfast chemistry , However it was evolved by adding unsteadyflamelet to it. Although the aim was calculating soot-radiation interaction, It is capable of calculating transient flames using LES method.
Old   January 9, 2013, 06:55
Tobi's Avatar
Tobias Holzmann
Hi Ali,
you asked me if the firefoam is based on flamelet.
I told you that it is not based on it but I am not sure.
In my study I had no combustion and I am not a combustion expert.
I am only good in the flamelet-solver of alberto cuoci.
So forget the things I told you yesterday.
Tobi
Old   January 10, 2013, 01:36
Default flamelet
  #112
dear babak
sir as regarded to notation of tobi, i think the firefoam cannot calculate the all species mass fraction, as u know the flamelet model include a table that consider all reactive species but i think fireFoam consider only product and reactant mass fraction. however, assume firefoam can based on flame let, do u describe how it calculate the table?
i wait u.
Old   January 21, 2013, 04:26
Bobi
Dear Tobi
Hi
I have started converting your flamelet code into LES. I have studied ur code piece by piece. I think that first of all I should change the main solver from SimpleC to Pimple with some modifications obligatory for flamelet calculations. Some fine modifications also needed for create fields file. But the primary question for me is in the csi.H file. The equations of mixture fraction and it's variance. My own belief is that this file (although it seems at first sight wrong) does not need any modifications cause the turbulent coefficients in these equations do not depend on the turbulence method. I mean for instance in the line:
Cd*rho*turbulnce->epsilon () / (turbulence->k() + k_small)*csiv2
the mentioned coefficients should be written the same for both turbulence methods. I mean that they do not depend on RANS so in LES they stay immutable.
Am I right buddy? Would u plz speculate about my suggestions.
Regards
Bobi
Old   January 21, 2013, 05:24
Tobi's Avatar
Tobias Holzmann
Originally Posted by babakflame View Post
Dear Tobi
Hi
the mentioned coefficients should be written the same for both method.
Regards
Bobi
Hi Bobi,
I can not give you an anwer about that question.
Old   January 23, 2013, 08:44
Default Good news
  #115
Tobi's Avatar
Tobias Holzmann
Hey all,
it seems that Alberto and his team are working on a new homepage:
http://creckmodeling.chem.polimi.it
So I think we all have the new libOpenSmoke in a few days/weeks
Tobi
Old   January 23, 2013, 13:37
Bobi
Hi Tobi
Oh, Thanks god. I hope we will have the new version with LES method.
Old   January 25, 2013, 06:15
Bobi
Dear Tobi
Hi
In the RAS-flamelet code we have a parameter in the results that is so called:
Planck mean absorption coefficient (as)
I think it relates to radiation heat transfer, However I do not know further about it. Would u plz give me a hint or maybe allude to references.
Regards
Bobi
Old   January 25, 2013, 06:44
Tobi's Avatar
Tobias Holzmann
Hi Bobi,
you are right.
That coefficient is for the radiation model and is calculated in the flamelet pre-processing.
For references:
http://www.sandia.gov/TNF/radiation.html
Tobi
Old   January 26, 2013, 12:14
Bobi
Dear Tobi
I have downloaded the C1C16 High temperature mechanism from Creckmodeling site. When I tried to pre-process the Chemkin format, I got this error message:
** Reading thermodynamic database...
terminate called after throwing an instance of 'std:ut_of_range'
what(): basic_string::substr
./Run.sh: line 1: 6817 Aborted ../../../exe/OpenSMOKE_CHEMKINInterpreter.sh --kinetics "PolimiC1C6HT_1212.kin" --thermo "termo_1212.tdc" --transport "tran_1212.tra" --output "PolimiC1C6HT"
Would u plz help we that what is the problem?
I think it's because of the .kin file name ( I used one of the file name's existed in the opensmoke code and it solved) , however Iam still confused.
I have another important question tobi.
What if we want to have a mixture of two fuels instead of one fuel, For instance if we have both propane & n-butane, which of them should be mentioned as fuel in Data.inp file?
Old   February 4, 2013, 03:53
Bobi
Dear Tobi
Hi
Would u plz hint me that in the Sandia CH4H2N2 2D case, How does the values for k & epsilon be calculated for the inlet air and fuel? (Forexample the following lines
inletfuel
type turbulentIntensityKineticEnergyInlet;
intensity 0.2;
U U;
phi phi;
value uniform 239.65;
For instance, If I change the fuel from CH4 to C3H8 without any changes in velocity magnitude, Does these values change?
Regards
Bobi
Thread Tools
Trackbacks are On
