GAMG Number of iterations depends strongly on number of parallel processors |
April 3, 2012, 10:54 |
Stefan Sicklinger
Rep Power: 15 |
At the moment I'm performing some parallel efficiency tests on a sandybridge cluster. i noticed that the number of needed GAMG iteration depends heavily on the number of parallel processors. This shouldn't be the case (as far as i know). Do you have any idea? I'm using openFoam 2.1.x with ICC. thanks in advance |
April 12, 2012, 03:11 |
Christian Lucas
Rep Power: 17 |
i'm not 100% sure, but the effect should be related to preconditioning. In a parallel run, the preconditioning is performed for each domain independently. Best Regards, Christian |
April 12, 2012, 03:23 |
#3 | |
Arjun
Rep Power: 34 |
Efficiency of multigrid goes down as number of partitions increase. It is known fact. (Not all smoothers do this though, some smoothers could really create multigrid independent of processors). In case of GAMG, I do not know whether the fall in efficiency you observed is more than it should. But efficiency of multigrid does fall down. |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
ForcesCoeffs | ronaldo | OpenFOAM | 4 | September 14, 2009 07:11 |
