November 7, 2012, 05:44 |
#181 | |
John Peng
Rep Power: 13 |
Hi, Niels,
Thanks for your information. I found that paper and also the equations to get the wave number. I guess wave number can be easily gotten by using setWaveParameters. However, from your wiki, you mentioned the input of stokesfifth wave type requires a stokesdrift scale, which is unknown before getting the wave number. So how can I do? just calculate the wave number by hand? Thanks, But the thing is that we Quote:
November 7, 2012, 09:05 |
#182 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi John,
Yes, you have to decide for a stokesDrift, since it is one equation with two unknowns. I believe the Fenton states that in the paper (or another one of his papers) that it the current field is unknown, then it does not make sense to go above 2nd order Stokes theory. However, if you are modelling a wave flume, you explicitly know that the stokes drift equals 0 (read: zero). Kind regards, Niels |
November 7, 2012, 13:23 |
#183 |
Sagun Tripathi
Rep Power: 13 |
Hello Niels,
I'm a beginner level user of waves2Foam and OpenFOAM in general. I was just trying to understand the file contents and structure of waveFoam by doing the waveFlume tutorial. However, whenever I try to run the waveFoam solver by typing in the command in the terminal window, I get the message - 'command not found'. Does this mean that waves2Foam is not properly installed? Please help. I'm using OpenFoam version 2.1.1 on Ubuntu 11.10. Regards, Sagun |
November 7, 2012, 17:43 |
#184 |
Rep Power: 37 |
Hi Sagun
I probably means that either (i) you have not loaded OpenFoam as such (and therefore also waves2Foam) or (ii) waves2Foam, and thus waveFoam, is not correctly installed. Kind regards, Niels |
November 7, 2012, 19:17 |
#185 |
Sagun Tripathi
Rep Power: 13 |
Hello Niels,
Thank you for your reply. As far as the installation is concerned, I followed the procedure which is mentioned on the wiki-page. I now have a waves2Foam folder in my home folder with all the relevant files in it. Does that mean it is properly installed? And I'm not sure if I understand properly what you meant by 'loading OpenFoam'. Could you be kind enough to write down the steps necessary to run a case? Regards, Sagun |
November 8, 2012, 01:36 |
#186 |
Rep Power: 37 |
Good morning,
With respect to loading OpenFoam, then there is a description here: http://www.openfoam.org/download/source.php in the section "Setting Environmental Variables". You are a bit unclear on what you have done for installing waves2Foam. Have you done anything besides getting the files from the SVN? I am asking, since you would also need to compile the library and the applications. This is done by executing the "Allwmake" script. You could also try to run the tutorials in the UserGuide coming with OpenFoam. These tutorials only rely on a correct installation of OpenFoam, and it is generally a good place to start. Kind regards, Niels |
November 8, 2012, 06:48 |
#187 |
Sagun Tripathi
Rep Power: 13 |
Hello Niels, good morning to you too.
I'm quite certain that I have installed OpenFoam correctly since I have had no problems in running the tutorials which came along with the installation. I was only concerned about whether I had installed waves2Foam properly or not. I did execute the wmake all command in the waves2Foam directory. However, as I mentioned earlier, the waves2Foam folder is located in my home directory instead of where the OpenFoam files are located (which is File System/opt/openfoam211). Is that the default location for the waves2Foam folder? Also, is there any check that I could do to make sure that waves2Foam is properly installed? Maybe then I can post the terminal output here for you to see. Thank you for your time. Regards, Sagun |
November 8, 2012, 08:58 |
#188 |
Rep Power: 37 |
Hi Sagun
Yes, please post the compilation information. I will be out of office for the next couple of days, but other users might be able to help you. Do you use the most recent svn repository, since the waveFoam solvers were not added for 2.1 until recently (details on the Wiki). If not, do a "svn update" and recompile. Kind regards, Niels |
November 8, 2012, 09:05 |
#189 |
Sagun Tripathi
Rep Power: 13 |
Hello Niels,
I updated the svn and recompiled. Here is the output: stripathi@iwpc178:~/waves2Foam$ svn up Restored 'tutorials/waveFoam/waveFlume/0/p_rgh.org' Restored 'tutorials/waveFoam/waveFlume/0/gamma.org' Restored 'tutorials/waveFoam/waveFlume/0/pd.org' Restored 'tutorials/waveFoam/waveFlume/0/U.org' Restored 'tutorials/waveFoam/waveFlume/0/alpha1.org' Restored 'tutorials/waveFoam/waveFlume/system/fvSchemes.21' Restored 'tutorials/waveFoam/waveFlume/system/fvSolution.21' Restored 'tutorials/waveFoam/waveFlume/constant/waveProperties.17' At revision 1980. stripathi@iwpc178:~/waves2Foam$ wmake all '/home/stripathi/OpenFOAM/stripathi-2.1.1/platforms/linuxGccDPOpt/lib/libwaves2Foam.so' is up to date. make[1]: Entering directory `/home/stripathi/waves2Foam/applications/solvers/solvers211/waveFoam' g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam211/src/transportModels -I/opt/openfoam211/src/transportModels/incompressible/lnInclude -I/opt/openfoam211/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam211/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam211/src/finiteVolume/lnInclude -DOFVERSION=210 -I./../../../../src/lnInclude -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linuxGccDPOpt/waveFoam.o -L/opt/openfoam211/platforms/linuxGccDPOpt/lib \ -ltwoPhaseInterfaceProperties -lincompressibleTransportModels -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -L/home/stripathi/OpenFOAM/stripathi-2.1.1/platforms/linuxGccDPOpt/lib -lwaves2Foam -lOpenFOAM -ldl -lm -o /home/stripathi/OpenFOAM/stripathi-2.1.1/platforms/linuxGccDPOpt/bin/waveFoam make[1]: Leaving directory `/home/stripathi/waves2Foam/applications/solvers/solvers211/waveFoam' make[1]: Entering directory `/home/stripathi/waves2Foam/applications/utilities/misc' make[2]: Entering directory `/home/stripathi/waves2Foam/applications/utilities/misc/matlab' make[3]: Entering directory `/home/stripathi/waves2Foam/applications/utilities/misc/matlab/postprocessing' make[3]: Nothing to be done for `application'. make[3]: Leaving directory `/home/stripathi/waves2Foam/applications/utilities/misc/matlab/postprocessing' make[3]: Entering directory `/home/stripathi/waves2Foam/applications/utilities/misc/matlab/preprocessing' make[3]: Nothing to be done for `application'. make[3]: Leaving directory `/home/stripathi/waves2Foam/applications/utilities/misc/matlab/preprocessing' make[2]: Leaving directory `/home/stripathi/waves2Foam/applications/utilities/misc/matlab' make[1]: Leaving directory `/home/stripathi/waves2Foam/applications/utilities/misc' make[1]: Entering directory `/home/stripathi/waves2Foam/applications/utilities/postProcessing' make[2]: Entering directory `/home/stripathi/waves2Foam/applications/utilities/postProcessing/surfaceElevation' g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam211/src/finiteVolume/lnInclude -I/opt/openfoam211/src/meshTools/lnInclude -I/opt/openfoam211/src/sampling/lnInclude -I/opt/openfoam211/src/lagrangian/basic/lnInclude -DOFVERSION=211 -I./../../../../src/lnInclude -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linuxGccDPOpt/surfaceElevation.o -L/opt/openfoam211/platforms/linuxGccDPOpt/lib \ -lfiniteVolume -lmeshTools -lsampling -lsurfMesh -ltriSurface -llagrangian -L/home/stripathi/OpenFOAM/stripathi-2.1.1/platforms/linuxGccDPOpt/lib -lwaves2Foam -lOpenFOAM -ldl -lm -o /home/stripathi/OpenFOAM/stripathi-2.1.1/platforms/linuxGccDPOpt/bin/surfaceElevation make[2]: Leaving directory `/home/stripathi/waves2Foam/applications/utilities/postProcessing/surfaceElevation' make[1]: Leaving directory `/home/stripathi/waves2Foam/applications/utilities/postProcessing' make[1]: Entering directory `/home/stripathi/waves2Foam/applications/utilities/preProcessing' make[2]: Entering directory `/home/stripathi/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' make[2]: Leaving directory `/home/stripathi/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' make[2]: Entering directory `/home/stripathi/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam211/src/finiteVolume/lnInclude -DOFVERSION=211 -I./../../../../src/lnInclude -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linuxGccDPOpt/relaxationZoneLayout.o -L/opt/openfoam211/platforms/linuxGccDPOpt/lib \ -lfiniteVolume -L/home/stripathi/OpenFOAM/stripathi-2.1.1/platforms/linuxGccDPOpt/lib -lwaves2Foam -lOpenFOAM -ldl -lm -o /home/stripathi/OpenFOAM/stripathi-2.1.1/platforms/linuxGccDPOpt/bin/relaxationZoneLayout make[2]: Leaving directory `/home/stripathi/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' make[2]: Entering directory `/home/stripathi/waves2Foam/applications/utilities/preProcessing/setWaveField' g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam211/src/finiteVolume/lnInclude -DOFVERSION=211 -I./../../../../src/lnInclude -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linuxGccDPOpt/setWaveField.o -L/opt/openfoam211/platforms/linuxGccDPOpt/lib \ -lfiniteVolume -L/home/stripathi/OpenFOAM/stripathi-2.1.1/platforms/linuxGccDPOpt/lib -lwaves2Foam -lOpenFOAM -ldl -lm -o /home/stripathi/OpenFOAM/stripathi-2.1.1/platforms/linuxGccDPOpt/bin/setWaveField make[2]: Leaving directory `/home/stripathi/waves2Foam/applications/utilities/preProcessing/setWaveField' make[2]: Entering directory `/home/stripathi/waves2Foam/applications/utilities/preProcessing/setWaveParameters' g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -DOFVERSION=211 -I/opt/openfoam211/src/finiteVolume/lnInclude -I./../../../../src/lnInclude -I./../../../../src/lnInclude -I/usr/local/include -I/include -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linuxGccDPOpt/setWaveParameters.o -L/opt/openfoam211/platforms/linuxGccDPOpt/lib \ -lfiniteVolume -lgsl -lgslcblas -L/home/stripathi/OpenFOAM/stripathi-2.1.1/platforms/linuxGccDPOpt/lib -lwaves2Foam -lOpenFOAM -ldl -lm -o /home/stripathi/OpenFOAM/stripathi-2.1.1/platforms/linuxGccDPOpt/bin/setWaveParameters make[2]: Leaving directory `/home/stripathi/waves2Foam/applications/utilities/preProcessing/setWaveParameters' make[1]: Leaving directory `/home/stripathi/waves2Foam/applications/utilities/preProcessing' Do you see anything out of the ordinary? Thanks and regards, Sagun |
November 8, 2012, 10:46 |
#190 |
Sagun Tripathi
Rep Power: 13 |
I am not sure what I was doing wrong before but somehow it is working now. Thanks for all the help. I was doing the 3Dwaves tutorial and I observed that you haven't specified the value of omega in the waveProperties file and the solver doesn't run without it. What should I do about it? Thanks, Sagun |
November 8, 2012, 11:08 |
#191 |
Kevin Smith
Rep Power: 17 |
I think you're supposed to see "___ is up to date" statements for each binary built. If the 'waveFoam' executable is not being built for some reason, try changing to the waveFoam directory and building from there; this might give you more information as to what is going wrong.
Kevin |
November 8, 2012, 11:18 |
#192 |
Sagun Tripathi
Rep Power: 13 |
Hello Kevin,
I'm not sure what I did but the 'waveFoam' executable eventually worked! Thanks anyways for the comment. Btw, have you done the 3Dwaves tutorial? The value of omega hasn't been specified in the waveProperties file which is required by the solver. I was wondering what should I do about it. Thanks, Sagun |
November 8, 2012, 12:24 |
#193 |
Kevin Smith
Rep Power: 17 |
Are you using the "Allrun" script?
Setting omega should have been done by the setWaveParameters utility. If not check the log files for errors. |
November 10, 2012, 14:52 |
#194 |
Sagun Tripathi
Rep Power: 13 |
Hello Kevin,
Sorry for the late reply. To answer your question, no, I'm not using the "Allrun" script. Actually, I don't even know what it is. I'm running these tutorial cases following the only procedure that I know of, i.e. blockMesh->checkMesh->waveFoam. This is the output that I am getting when I run the solver: Reading g Reading waveProperties Reading field p_rgh Reading field alpha1 --> FOAM FATAL IO ERROR: keyword omega is undefined in dictionary "/home/stripathi/waves2Foam/tutorials/waveFoam/3Dwaves/constant/waveProperties::inlet0Coeffs" file: /home/stripathi/waves2Foam/tutorials/waveFoam/3Dwaves/constant/waveProperties::inlet0Coeffs from line 31 to line 47. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 400. FOAM exiting Kindly advise. Thanks, Sagun |
November 10, 2012, 15:45 |
#195 |
Kevin Smith
Rep Power: 17 |
There should be a script called 'Allrun' in the case directory. Is that missing?
November 12, 2012, 06:53 |
#196 |
Sagun Tripathi
Rep Power: 13 |
No it isn't. Any idea what's wrong?
November 12, 2012, 10:21 |
#197 |
Kevin Smith
Rep Power: 17 |
Run the 'Allrun' script to run the tutorial, there are a few additional steps needed when using waves2Foam. In general the process is: blockMesh, setWaveParameters, setWaveField, waveFoam. Take a look through the Allrun script, that should hopefully clear up what you are doing wrong.
Also, many of the tutorials also do some additional preprocessing, which are not waves2foam specific, but are required to run the tutorial (copying version specific input files, creating internal face baffles). |
November 12, 2012, 11:39 |
#198 |
Sagun Tripathi
Rep Power: 13 |
Hello Kevin,
Thank you so much for your help. I wasn't following the correct procedure before but now the tutorial is up and running. On another note, I was wondering if you could offer me some advice. At the moment I am trying to simulate multi-phase laminar flow including the effect of waves over a rectangular column which is attached to the base of the tank in 2D ('x' and 'z' being the dimensions of interest). Eventually I hope to include the 'y' dimension too so that I can simulate the flow 'around' the object and not just 'over' it. I wanted to ask you if that's even possible with waves2Foam. From what I have been able to infer, previous research work in this field has been mostly focused on 2D simulations. Also, I am having difficulty in understand how to define the relaxation zones, especially their orientation and start and end points. It would be great if you could explain that to me too. Thanks, Sagun |
November 12, 2012, 12:28 |
#199 |
Kevin Smith
Rep Power: 17 |
Sagun,
Sure, glad to hear you have the case running. Yes, waves2Foam does 3D cases just fine. The 3Dwaves tutorial case you asked about originally may have some things in common with the 3D case you want to run. If you haven't found it already, the waves2foam documentation is here - http://openfoamwiki.net/index.php/Contrib/waves2Foam . You can think of the relaxation zones as planes that are defined at the free surface near the inlet and outlet of the domain. The relaxation is applied explicitly in these zones. The orientation is the direction the waves are propagating along. If you want to visually check the zones, use the relaxationZoneLayout utility. Check out the wiki for more info. Kevin |
November 12, 2012, 12:35 |
#200 |
Rep Power: 37 |
Hi Sagun,
Kevin has given the whole story, however, I saw on another thread that you want to look at a submerged monopile. This can easily be done, and I can tell that some of my colleagues are doing it on a regular basis both under regular and irregular, co-directional incident waves. I believe you can find an example in the following references: Bredmose, H. and Jacobsen, N. G. (2010). Breaking Wave Impacts on Offshore Wind Turbine Foundations: Focused Wave Groups and CFD. Proceedings of the 29th ASME International Conference on Ocean, Offshore and Arctic Engineering, Shanghai, China, 3, 397-404 Paulsen, B. T., Bredmose, H. and Bingham, H. B. (2012). Accurate computation of wave loads on a bottom fixed circular cylinder. International Workshop on Water Waves and Floating Bodies, Copenhagen, Denmark (http://www.iwwwfb.org) Kind regards, Niels |
Display Modes | |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
Re-Project topics | protocol | STAR-CCM+ | 0 | March 22, 2016 06:25 |
Waves2Foam Related Topics | seoseonguk | OpenFOAM Running, Solving & CFD | 0 | March 1, 2016 23:18 |
Waves2Foam Related Topics | seoseonguk | OpenFOAM Running, Solving & CFD | 0 | March 1, 2016 23:14 |
Error: "Cannot find file points" related to changing parallelized code to serial? | Suyf | OpenFOAM Running, Solving & CFD | 0 | February 12, 2015 05:31 |
