Home > Forums > OpenFOAM Running, Solving & CFD
Waves2Foam Related Topics
Like Tree123Likes
Old   September 3, 2013, 15:07
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good evening Ellie,
Have you successfully compiled the libraries, which come with waves2Foam. The error suggest that the libraries was not compiled successfully.
Also, the linking and include directories tells me that you are using an old version of waves2Foam. Please be aware that more recent versions carry bug fixes and new functionalities.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   September 3, 2013, 17:58
Ellie is on a distinguished road
Originally Posted by ngj View Post
Good evening Ellie,
Kind regards,
Niels
Hi Niels,
Thanks so much for your quick reply! Could you lease provide the link for the more recent versions? Since now I am having a hard time finding the website again. Thanks
Ellie
Ellie is offline   Reply With Quote
Old   September 3, 2013, 21:52
Good evening Ellie,
Kind regards,
Niels
You mentioned in other thread that we should not need to copy, e.g. relaxationZone.H to the solvers/solver220/waveFoam directory. As we need to change the Make/Option file as
-DOFVERSION=220 \
-I./../../../../src/lnInclude
But it doesn't work. And then I manually copied all the required .H files so that it can 'wmake'. My first reply is the error as a result of that.
And sorry that I am new to OpenFoam. But how to compile the libraries? Where is it?
Thanks.
Best,
Ellie
Old   September 4, 2013, 00:52
Default Update my question!
  #544
Hi Niels,
I've tried the newest version of 'waves2Foam.tar.gz' I could find, and run './Allmake'. No error is showed. Thanks for your tips.
I am running the 3DWaves case in the tutorials and met a few errors.
the 'blockMesh' is good.
it presents some errors when running 'interFoam' and it seems that it's not compiling. Is it the exact solver for this case?
keyword PIMPLE is undefined in dictionary "/home/gfx/OpenFOAM/gfx-2.2.0/applications/solvers/waves2Foam/tutorials/waveFoam/3Dwaves/system/fvSolution"
and I follow someone's suggestion to change the keyword 'PISO' into 'PIMPLE'. I also need to remove the '.org' in the U and p_rgh file name. But another error appears:
--> FOAM FATAL IO ERROR:
Unknown patchField type waveVelocity for patch type patch
I do not know what to do next now! Sincerely hope you can help to see how to run that case! Thanks.
Ellie
Old   September 4, 2013, 12:27
Default wavefoam problem with 3D mesh
  #545
Luis Miguel
luigi21 is on a distinguished road
I have a big problem when I try to compile wavefoam with a 3D mesh generated in GMSH, the mesh consist of a flume with irregular geometry, the following lines are the error that I get always:
HP-Compaq-dc5800-Microtower:~/OpenFoam/irregularwaveFlume7$ #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 Uninterpreted:
#3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
at ??:?
at ??:?
at ??:?
at ??:?
#8 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
at ??:?
I've checked the mesh and the boundary conditions but everything seems ok, When I'm running the waveFoam utility the courant number goes out of the permisible range.
If somebody knows what the problem is.... I'd appreciate it so much....
luigi21 is offline   Reply With Quote
Old   September 9, 2013, 14:43
katakgoreng is on a distinguished road
Hi Niels,
I have tested wave2foam for regular waves and so far the results is quite accurate (provided that I have enough mesh in the viscinity of the free surface).
I'm interested to try the irregular waves function (JONSWAP).
I have specify the JONSWAP spectrum in "waveProperties.input" as follows:
waveType : irregular;
spectrum : JONSWAP;
N : 151;
Tsoft : 3;
writeSpectrum : false;
Hs : 0.046;
Tp : 1.2;
gamma : 2.5;
depth : 0.7;
direction : ( 1 0 0 );
There is no information for the focusing time and location so I assume that the focused wave occur at xf = 0 and tf = 0, where (xf is the focusing location and tf is the focusing time). Is there any way that I could change the focusing location and time to a specified values?
Kind regards,
katakgoreng
lxwd likes this.
katakgoreng is offline   Reply With Quote
Old   September 9, 2013, 15:05
ngj
Good evening Katakgoreng,
I am glad to hear that you are so far happy with the results. The irregular wave is exactly an irregular wave train, so the phasing is set to a random value, i.e. there is not any focusing time/location as an option. To achieve this, it will require some implementation.
Kind regards,
Niels
katakgoreng likes this.
Old   September 9, 2013, 15:48
Kind regards,
Niels
Hi Niels,
Thank you for your clarification. I noticed when I run "setWaveParameters", in "waveProperties", sets of values (from the JONSWAP spectrum) are generated:
(a) amplitude
(b) frequency
(c) phaselag
(d) waveNumber
amplitude, frequency and wavenumber are typical values corresponding to the JONSWAP spectrum.
Would you mind clarifying what "phaselag" is?
Is this what you mean by random phasing?
Is "phaselag" equal to "phi" as in regular wave theory?
Kind regards,
katakgoreng
Old   September 9, 2013, 16:29
ngj
Yes, phaselag is the same as phi in the regular wave theories. Sorry for the inconsistency in naming. Also, phaselag is the random variable.
Kind regards,
Niels
Old   September 10, 2013, 09:29
Kind regards,
Niels
Hi Niels,
So I guess, I could calculate the phaselag for every waves so that they coincide at the focusing time and location that I want. Will try it. Thanks Niels.
Kind regards,
katakgoreng
# UPDATE
I managed to get the waves to focused based on focusing time and location that I prescribed. I do this by calculating the phase-lag of each individual waves so that they coincide at the prescribed values.
So the formula that I used for calculating phase-lag is as follows:
phi = k * xf - omega * tf
where
phi = individual phase-lag
k = individual waves number
omega = individual waves angular frequency given by 2*pi*f
f = individual waves frequency
xf = focusing location
tf = focusing time
I replace the calculated phase-lag from "setWaveParameter" with the new phase-lag.
The result shows excellent agreement with linear random wave theory.
BTW, this is TopHat spectrum (same amplitude for each individual waves, again I replace the value generated from "setWaveParameter")
The focusing location, xf = 8 m from inlet whilst focusing time, tf = 32 s.
Maximum amplitude error is 1.5%.
The trough before and after the focused event is slightly under-predicted whilst the focused location drifted just abit due to either non-linear effect or inadequate mesh resolution in the vertical and horizontal direction.
The legend supposed to be "waves2Foam"..sorry about that..
# UPDATE 2
Focused waves for JONSWAP spectrum at xf = 8m and tf = 32s.
The mesh used is the same as in TopHat spectrum. It is pretty evidence that the mesh is under-resolved as the short waves riding on longer waves is not being resolved properly, resulting in decreasing in maximum focused amplitude. Using denser mesh could result in much better result.
Old   September 14, 2013, 04:58
ngj
Hi Katakgoreng,
Thanks for the updates. I would say that the results do look pretty nice, and I am happy to see the predictive capabilities validated.
Just out of curiosity, have you constructed the wave components inside or outside setWaveParameters? If still outside, then I do have some ideas on how to make it all work with as little work as possible. Essentially, if you post the code, which you use for creating the phases, i.e. required information from the user and the exact computation of the phases, then I could probably put it into waves2Foam during this weekend.
Please, also add the waveProperties- and waveProperties.input-files for JONSWAP, such that I can compare the created files.
Kind regards
Niels
EDIT: Sorry, after carefully reading your post from above, I can see that the equations are already there. I will make sure that it get integrated in the setWaveProperties.
Old   September 15, 2013, 03:50
ngj
Good morning,
This morning I have added the option of focusing an incident irregular wave train in a given time and a given location as inspired by Katakgoreng. For the control, please see
http://openfoamwiki.net/index.php/Co...ar_wave_theory
If you are using standard random phasing of the incident irregular waves, then you do not have to do anything, but a slight increase in control is added through a manual choice of seeding for the random number generator.
Kind regards
Niels
Old   September 16, 2013, 06:08
Hi Niels,
Sorry for not replying your previous post abit earlier. I haven't been online on the weekend.
The latest addition is pretty neat. No need to calculate the phaselag outside "setWaveParameters".
I have updated svn and recompile wave2Foam.
I have the following in "waveProperties.input"
phaseMethod focusingPhase;
focusTime 32;
focusPoint (8 0 0);
I have the following bug (not quite sure if its on my computer only) :
Bug 1:
When I run "setWaveParameters", I got
keyword equidistantFrequencyAxis is undefined in dictionary ...
I then add "equidistantFrequencyAxis" into the "waveProperties.input" and set the value to 1. The error then goes away. Is this new additional control that you add for irregular wave theory as I can't seem to find it ever mentioned in
Bug 2:
I have the following in "waveProperties.input".
outletCoeffs
waveType potentialCurrent;
U ( 0 0 0 );
Tsoft 2;
relaxationZone
relaxationScheme Spatial;
relaxationShape Rectangular;
beachType Empty;
relaxType OUTLET;
startX (15 0.0 -1);
endX (20 0.0 1);
orientation (1.0 0.0 0.0);
When I run "setWaveParameters", the "outletCoeffs" is not written in "waveProperties" file.
Do you experience similar problem or is it just on my system?
Kind regards,
katakgoreng
# UPDATE :
Thanks Niels for pointing things out.
Bug 1 : Not a bug, additional control added by Niels.
Bug 2 : Not a bug, using file provided by Niels, the code run just fine. It could be that I made some typo error in the input file.
Old   September 16, 2013, 11:59
ngj
With respect to "bug 1", then it is not a bug, but a new feature for increased control of the irregular wave spectrum. I have also added the option of user-defined frequency cut-offs. The description has now been updated on the wiki.
With respect to "bug 2", then I do not experience those type of problems. I made a quick test on the attached waveProperties.input file. This test, however, made me realise that not all the new information on phasing, etc, is carried along in the writing process. This does not have any consequence for the results, as they are purely pre-processing parameters, but they would be nice to have for future reference. This will be added in a future revision.
Kind regards,
Niels
P.S. I was not allowed to upload files called *.input, so merely rename.
katakgoreng and zhan like this.
Old   September 16, 2013, 17:16
Pietro Danilo Tomaselli
kobelak is on a distinguished road
Hi guys,
first of all, thanks to Niels for this useful toolbox!
I am working on breaking waves. I would like to use waves2Foam coupled with LES turbulence model; I don't know if someone did/is doing/is going to do something similar.
For the moment, I'm using a RASModel in order to obtain the same results of section 3.3 of Niels' journal publication (Validation case for breaking waves - Wave Generation toolbox ... ; International Journal for Num. Methods in Fluids , 2011).
I haven't found any tutorial with a turbulence model different from laminar, so I would like to receive some suggestions/hints about the case set-up, such as:
- type of RAS turbulence model that I should use (k-omega I guess)
- boundary/initial conditions of k, epsilon or omega, nut...
- changes on fvSolution and fvSchemes files (I need to consider the new terms of the equations of the turbulence model);
- dimensions of the computational domain (length of the swash zone in particular) and mesh size.
I searched through this thread and I found that just Kumar (pag. 19) tried to do the same. Anyone else?
Thanks in advance
Danilo
mo_na likes this.
kobelak is offline   Reply With Quote
Old   September 17, 2013, 06:14
Kind regards,
Niels
Hi Niels,
Thanks. Both are not bugs. Using the file that you provided, I managed to get the waveProperties just fine.
Currently, I'm running quite an extensive simulation. I'm interested in the post-processing result given by waves2Foam such as the free surface elevation. If I stop the simulation, how can I continue from the latestTime and concatenated the result into "surfaceElevation.dat" file?
Kind regards,
katakgoreng
Old   September 17, 2013, 12:40
ngj
Merely use the post-processing utility postProcessWaves2Foam. As you can see in the below link, the concatenation of data files is supported.
http://openfoamwiki.net/index.php/Co...ng_of_Raw_Data
The Wiki is not fully accurate on the functionalities in postProcessWaves2Foam, but the most important things are described and the rest should easily be understood from the source code.
Kind regards
Niels
Old   September 18, 2013, 15:45
Default Update waves2Foam failed
  #558
David Long
keepfit is on a distinguished road
I just update the latest waves2Foam, but it failed: (on 32-bit Ubuntu 12.04)
/usr/bin/ld: error: --add-needed is not supported but is required for libOpenFOAM.so in /home/dao/OpenFOAM/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/lib/libfiniteVolume.so
collect2: ld returned 1 exit status
make: *** [/home/DAO/OpenFOAM/dao-2.1.1/platforms/linuxGccDPOpt/lib/libwaves2FoamSampling.so] Error 1
When I compiled the old version the same error remains, it's really weird. Did I miss something else?
Anyway I installed the latest version successfully on the laptop (64-bit Ubuntu 13.04). Is this new version only for 64-bit system?
Best,
David
keepfit is offline   Reply With Quote
Old   September 18, 2013, 17:13
ngj
Hi David,
The error message suggests that the problem lies with OpenFoam itself, since the error is related to libOpenFoam.so. I have never tried compiling waves2Foam on a 32 bit machine, but I have not deliberately put any restrictions into the code.
Kind regards,
Niels
Old   September 18, 2013, 17:34
David Long
Hi David,
Kind regards,
Niels
I will try reinstall the OF 2.1.1 again and see what happens.
Best
Edit: problem caused by Gnu gold ( binutils-gold package ). Uninstall it and use the the old Gnu ld, everything goes fine.
David
Thread Tools
Trackbacks are On
Other Topics at OpenFOAM Workshop Milan 2008 hjasak OpenFOAM 2 October 26, 2013 04:33
Sections / Topics in CFD Wiki Roberthealy1 CFD-Wiki 6 August 23, 2007 17:58
CFD Related Educational Programmes Jonas Larsson Main CFD Forum 3 February 9, 2007 11:11
project topics vivekanand CFX 0 October 27, 2004 05:17
Advanced Topics in Aerodynamics Antonio Filippone Main CFD Forum 0 August 28, 1999 12:16
