Home > Forums > OpenFOAM Running, Solving & CFD
Waves2Foam Related Topics
Like Tree90Likes
Old   October 9, 2013, 12:57
Arthur Loginow
Maralady is on a distinguished road
Mr.Ngj would you mind if I send you a PM?
Maralady is offline   Reply With Quote
Old   October 10, 2013, 08:11
katakgoreng is on a distinguished road
Ni Niels,
I'm trying to simulate wave breaking/vertical jetting due to focusing waves event (very high steepness). So far, I have managed to go to steepness, Akc of 0.2 and 0.3 without breaking. However, as I reach Akc 0.4, the simulation stop with error code as follows :
MULES: Solving for alpha1
Phase-1 volume fraction = 0.699903  Min(alpha1) = -3.7219e-19  Max(alpha1) = 1.36268
DILUPBiCG:  Solving for Ux, Initial residual = 0.00387945, Final residual = 1.89691e-10, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.00468833, Final residual = 6.7893e-10, No Iterations 3
GAMG:  Solving for p_rgh, Initial residual = 0.0247348, Final residual = 8.56019e-08, No Iterations 8
GAMG:  Solving for p_rgh, Initial residual = 8.55912e-08, Final residual = 8.55912e-08, No Iterations 0
time step continuity errors : sum local = 1.15524e-09, global = -6.6881e-10, cumulative = -5.17334e-07
GAMG:  Solving for p_rgh, Initial residual = 0.000950645, Final residual = 6.40902e-08, No Iterations 6
GAMG:  Solving for p_rgh, Initial residual = 6.38803e-08, Final residual = 6.38803e-08, No Iterations 0
time step continuity errors : sum local = 8.65e-10, global = 3.06962e-11, cumulative = -5.17304e-07
GAMG:  Solving for p_rgh, Initial residual = 4.12761e-05, Final residual = 5.01357e-08, No Iterations 3
GAMG:  Solving for p_rgh, Initial residual = 5.01163e-08, Final residual = 7.33679e-09, No Iterations 2
time step continuity errors : sum local = 9.93841e-11, global = -1.08676e-11, cumulative = -5.17315e-07
ExecutionTime = 11862.1 s  ClockTime = 11913 s
Courant Number mean: 0.00701962 max: 0.307835
Interface Courant Number mean: 9.04814e-05 max: 0.21481
deltaT = 0.00117681
Time = 22.3717
Phase-1 volume fraction = 0.6999  Min(alpha1) = -1.76375e-19  Max(alpha1) = 1.36617
DILUPBiCG:  Solving for Ux, Initial residual = 0.00313601, Final residual = 1.90061e-10, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.00375741, Final residual = 1.75008e-10, No Iterations 4
[0] #0  Foam::error::printStack(Foam::Ostream&) in "/home/ehk112/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1  Foam::sigFpe::sigHandler(int) in "/home/ehk112/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2   in "/lib64/libc.so.6"
[0] #3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/home/ehk112/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/ehk112/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/ehk112/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/home/ehk112/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[0] #7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/ehk112/OpenFOAM/ehk112-2.2.x/platforms/linux64GccDPOpt/bin/waveFoam"
[0] #8
[0]  in "/home/ehk112/OpenFOAM/ehk112-2.2.x/platforms/linux64GccDPOpt/bin/waveFoam"
[0] #9  __libc_start_main in "/lib64/libc.so.6"
[0] #10
[cx1-5-15-2:16953] *** Process received signal ***
[cx1-5-15-2:16953] Signal: Floating point exception (8)
[cx1-5-15-2:16953] Signal code:  (-6)
[cx1-5-15-2:16953] Failing at address: 0x7a2b300004239
[cx1-5-15-2:16953] [ 0] /lib64/libc.so.6(+0x32920) [0x2ac14c5af920]
[cx1-5-15-2:16953] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x2ac14c5af8a5]
[cx1-5-15-2:16953] [ 2] /lib64/libc.so.6(+0x32920) [0x2ac14c5af920]
[cx1-5-15-2:16953] [ 3] /home/ehk112/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xba) [0x2ac14b66be7a]
[cx1-5-15-2:16953] [ 4] /home/ehk112/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_RNS1_IS8_EESD_h+0x1186) [0x2ac14b66ecc6]
[cx1-5-15-2:16953] [ 5] /home/ehk112/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x3a8) [0x2ac14b670308]
[cx1-5-15-2:16953] [ 6] /home/ehk112/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x118) [0x2ac1495bf168]
[cx1-5-15-2:16953] [ 7] waveFoam(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x11c) [0x459c9c]
[cx1-5-15-2:16953] [ 8] waveFoam() [0x48694e]
[cx1-5-15-2:16953] [ 9] /lib64/libc.so.6(__libc_start_main+0xfd) [0x2ac14c59bcdd]
[cx1-5-15-2:16953] [10] waveFoam() [0x4334d5]
[cx1-5-15-2:16953] *** End of error message ***
I'm not sure what the problem is.
Is the error due to problem with the probe? At breaking point, alpha1 would have multiple values causing the interpolation operation for the probe to crash.
Or is it due to the simulation has reach minimum time step?
# UPDATE :
A closer inspection for the alpha1 value from the log reveals the following.
1. For wave with steepness, Akc = 0.2, the alpha1 has a limit of 1 and 0 for every time step as follows:
2. For wave with steepness, Akc = 0.3, the alpha1 does not sustain the limit of 1 and 0 between 22 to 27 s. The simulation however managed to get stable and revert alpha1 to the limit of 1 and 0.
3. For wave reaching the breaking limit Akc=0.4, alpha1 shoot up higher than 1 and the simulation blows up
(blue and red line correspond to minimum and maximum value of alpha1 respectively)
Any idea on tackling this problem with unboundedness of alpha1 is highly appreciated.
Kind regards,
katakgoreng
katakgoreng is offline   Reply With Quote
Old   October 10, 2013, 14:21
Arthur Loginow
Hello, I am trying to install waveFoam, so far I have some doubts:
1. Which is the best OF version to work with waveFoam?
2. I did the step 3 from the waves2Foam wiki (This is copy the interFoam source code and modify it)
3. Now I have to proceed with the step number 8 (Is this correct or should I do this step before the step number 3?)
4.At this point I am not sure what to do when it says:
-Obtain the source code via SVN as described above
-Execute the Allwmake script in the folder waves2Foam
What really means by source code?
Old   October 11, 2013, 14:48
Arthur Loginow
I made the changes to both the interFoam and the interDyMFoam files and when I try to finish the installation with the wmake command I get the following error:
could not open file relaxationZone.H for source file waveDyMFoam.C
could not open file readWaveProperties.H for source file waveDyMFoam.C
SOURCE=waveDyMFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I.. -I/opt/openfoam221/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam221/src/transportModels -I/opt/openfoam221/src/transportModels/incompressible/lnInclude -I/opt/openfoam221/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam221/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam221/src/finiteVolume/lnInclude -I/opt/openfoam221/src/dynamicMesh/lnInclude -I/opt/openfoam221/src/dynamicFvMesh/lnInclude -I./../../../../../src/lnInclude -I/opt/openfoam221/src/meshTools/lnInclude -I/opt/openfoam221/src/fvOptions/lnInclude -I/opt/openfoam221/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam221/src/OpenFOAM/lnInclude -I/opt/openfoam221/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/waveDyMFoam.o
waveDyMFoam.C:44:28: fatal error: relaxationZone.H: No such file or directory
compilation terminated.
make: *** [Make/linux64GccDPOpt/waveDyMFoam.o] Error 1
Any help?
Old   October 12, 2013, 04:44
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Arthur,
You say above that you are unsure on how to use SVN and obtain the source code. I suppose that you are experiencing problems with compiling waveDymFoam simply because you have not obtained the source code from the svn-repository.
This is done by executing the command stated on the wiki, which starts with something like:
svn co
After this step, you have to compile the source code as also described on the wiki by executing the Allwmake script as in
./Allwmake
You do not need to make your own waveFoam solver for OF221, since it already comes along with waves2Foam, but if you need to use the moving meshes in OpenFoam, you need to create your own waveDymFoam solver. In that regard please note the NB-statement, which tells you that you should not do exactly as given on the wiki, as the described is partly outdated. Use the existing solvers to see, which modifications are required.
Kind regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   October 12, 2013, 13:39
Arthur Loginow
Neil thanks for your reply, when I run the ./Allwmake command I get the following error:
ENVIRONMENTAL VARIABLES
WAVES_XVERSION=0
WM_PROJECT_VERSION_NUMBER=221
WAVES_SOL=/home/arthur/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam/applications/solvers/solvers221
WAVES_POST=/home/arthur/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam/applications/utilities/postProcessing
WAVES_UTIL=/home/arthur/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam/applications/utilities
EXTBRANCH=0
WAVES_APPBIN=/home/arthur/OpenFOAM/arthur-2.2.1/platforms/linux64GccDPOpt/bin
WAVES_TUT=/home/arthur/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam/tutorials
WAVES_GSL_INCLUDE=/usr/include
WAVES_GSL_LIB=/usr/lib64
WAVES_PRE=/home/arthur/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam/applications/utilities/preProcessing
WAVES_SRC=/home/arthur/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam/src
WAVES_DIR=/home/arthur/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam
WAVES_LIBBIN=/home/arthur/OpenFOAM/arthur-2.2.1/platforms/linux64GccDPOpt/lib
FATAL ERROR.
The directory path /home/arthur/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam does not exist.
Correct the path in bin/bashrc
Please note that once bin/bashrc is created, bin/bashrc.org is only an
inactive file. The latter is also the only of the two files, which is
updated through the SVN-repository.
EXITING
I tried the same creating the
Directory but still getting another error, what I am doing wrong?
Old   October 12, 2013, 15:08
ngj
Note that the error message does not advice you to create the given directory, but to adjust bin/bashrc, such that it is pointing to the location, where you have placed waves2Foam.
Kind regards
Niels
Old   October 12, 2013, 18:33
Arthur Loginow
I was able to compile the application but now when I try to run the solver (waveFoam) at the tutorial (periodicSolitary) I get the following error:
arthur@ubuntu:~/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam/tutorials/waveFoam/periodicSolitary$ waveFoam
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.1-57f3c3617a2d
Exec : waveFoam
Date : Oct 12 2013
Time : 18:31:03
Host : "ubuntu"
PID : 10165
Case : /home/arthur/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam/tutorials/waveFoam/periodicSolitary
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/arthur/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam/tutorials/waveFoam/periodicSolitary/system/fvSchemes at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 87.
FOAM exiting
Any suggestion?
Old   October 13, 2013, 06:42
ngj
Hi Arthur,
Execute the Allrun script. This will take care of cross-version compatibility of the tutorial cases.
Kind regards
Niels
Old   October 13, 2013, 16:55
Arthur Loginow
Neils, thanks for your reply, I did what you said, I was able to generate the mesh without any problem, however I get this error when I try to run the solver:
Cannot find patchField entry for cyclic cyclic1_half0
Is your field uptodate with split cyclics?
Run foamUpgradeCyclics to convert mesh and fields to split cyclics.
file: /home/arthur/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam/tutorials/waveFoam/periodicSolitary/0/p_rgh.boundaryField from line 25 to line 47.
From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&)
in file /opt/openfoam221/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 181.
FOAM exiting
By this I understand that I have to specify the cyclic at the cyclic boundary, is this correct?
Old   October 14, 2013, 00:41
ngj
Good morning,
I had forgotten that the definition of the cyclic patches has changed. Please search the forum to identify how to convert the old (pre OF2.0) format to the present formulation. There are plenty of threads on that topic - or simply read through the release notes on openfoam.org.
Kind regards,
Niels
Old   October 14, 2013, 23:55
Arthur Loginow
Hello Niels, thanks for your reply, I have been looking the tutorials folders and found that at the 0 folder for the waveFlume all the files are .org, now I understand from the interFoam tutorial that I only need 1 .org file and that one is the alpha1 file, so my question is: It is the same with this case? Should all the files be regular files and should I have only 1 .org file (the alpha1.org file)
When I try to use setFields I get the following error:
cannot open file
file: /home/arthur/OpenFOAM/arthur-2.2.1/applications/utilities/waves2Foam/tutorials/waveFoam/waveFlume/system/setFieldsDict at line 0.
FOAM exiting
However I can create the mesh and even check the mesh without having any warning
Any suggestion??
Old   October 15, 2013, 00:25
Arthur Loginow
Just find out at this forum what I was doing wrong, the general process is:
blockMesh, setWaveParameters, setWaveField, waveFoam
My bad, I guess I will read the whole forum and re-read the wiki again before ask any other question
But as 1 last thing Mr.Niels, I want to simulate 2D waves in different geometries with NO floating bodies on the water, what tutorials would you recommend me? (So far I think that relaxationZone and waveFlume are enough to work on my project but not quite sure) thanks for your time and THANKS for doing such a nice work with this application
Old   October 16, 2013, 00:46
Peter
peter_w is on a distinguished road
Originally Posted by ngj View Post
Hi Sri,
In your specific case it should read
export WAVES_DIR=$HOME/Desktop/waves2Foam
Kind regards
Niels
Hi mate,
Where do you type that export... line? in the terminal? Or as a line in the bashrc file? Or as a line in the Allwmake file?
Thanks in advance,
Peter
peter_w is offline   Reply With Quote
Old   October 17, 2013, 15:37
Arthur Loginow
Neils I need to change the wavesProerties file, and I was wondering if I change the depth of the water at this file, do I have to modify the geometry? Because I am not sure if those 2 are truly linked, hope you understand my question
greetings
Old   October 22, 2013, 12:19
Default modelling waves crashing into a fixed structure
  #596
Imogen Wright
mojface is on a distinguished road
I'd like to model open ocean waves in shallow water crashing into and passing a fixed wall for a personal project. I come from a computer science/physics background but am very new to CFD.
Could anyone point me to a tutorial that would help with this? I've been playing with the 3Dwaves tutorial but I can't seem to draw a solid wall - however I set up the mesh and initial conditions the waves seem to go straight though my wall.
What am I missing?
mojface is offline   Reply With Quote
Old   October 22, 2013, 13:15
ngj
Good evening,
I will try to catch up after some time offline:
@Peter: You should modify the file waves2Foam/bin/bashrc.
@Arthur: Please read the posts by Katakgoreng above, as he recently asked the exact same question.
@Imogen: I suppose that you are using OpenFoam-2.2? The 3Dwaves tutorial is not fully functioning under more recent versions, because the faceSet-utility was replaced by topoSet. This means that it is not possible to create the inner wall without modifying the tutorial.
At least the part with faceSet needs to be modified. See the Allrun script for details on the execution.
Kind regards,
Niels
Old   October 22, 2013, 17:51
Imogen Wright
Dear Niels,
Thank you so much for your prompt reply, and thank you for maintaining this incredibly useful tool!
I've managed to convert the faceSet piece of the 3DWaves example to a working topoSet. However, when I run createBaffles I now get the following error:
incorrect first token, expected <label> or '(' or '{', found on line 0 the word 'internalWall'
file: IStringStream.sourceFile at line 0.
    From function operator>>(Istream&, FixedList<T, Size>&)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/FixedListIO.C at line 71.
FOAM exiting
My topoSetDict looks like:
actions
    name    f0;
    type    faceSet;
    action  new;
    source  boxToFace;
    sourceInfo
      box (74.9 -6 59.9) (75.1 3 90.1);
    name    f0;
    type    faceSet;
    action  add;
    source  boxToFace;
    sourceInfo
      box (74.9 -6 59.9) (100.1 3 60.1);
    name    f0;
    type    faceSet;
    action  add;
    source  patchToFace;
    sourceInfo
      name internalWall;
    name    zoneSet;
    type    faceZoneSet;
    action  new;
    source  setToFaceZone;
    sourceInfo
      faceSet f0;
Any ideas?
Cheers,
Imogen
Old   October 23, 2013, 17:52
Arthur Loginow
It is Tsoft the period? How can I define the wave Period?
Old   October 23, 2013, 21:57
Gregoire Junqua
gregjunqua is on a distinguished road
Hi
Nope it's should be set with the wave period depending your experiment but it's not the period
From the wiki : http://openfoamwiki.net/index.php/Contrib/waves2Foam
"Tsoft should be given a value of 0.0; Tsoft is typically set to the wave period as default and is not required by most of the wave theories. "
It is the same file waveProperties
Just after you would found
// Water depth at the boundary and in the relaxation zone depth 0.400000; // Period - needed by setWaveParameters -> yields omega period 2.0; // Cyclic wave frequency omega 3.141593;
gregjunqua is offline   Reply With Quote
Thread Tools
Trackbacks are On
Other Topics at OpenFOAM Workshop Milan 2008 hjasak OpenFOAM 2 October 26, 2013 04:33
Sections / Topics in CFD Wiki Roberthealy1 CFD-Wiki 6 August 23, 2007 17:58
CFD Related Educational Programmes Jonas Larsson Main CFD Forum 3 February 9, 2007 11:11
project topics vivekanand CFX 0 October 27, 2004 05:17
Advanced Topics in Aerodynamics Antonio Filippone Main CFD Forum 0 August 28, 1999 12:16
