July 10, 2011, 22:49 |
free surface around a ship hull
Rep Power: 14 |
Hello all,
I am trying to model the elevation/trough of free surface around a ship hull. Being new to OF, I am starting with a simple mesh (inlet, oulet, floor+sides+hull walls, and free surface) in a simple case (icoFoam, using only p and U). Here are my boundary, p, and U files and then my current problem when I start the simulation. p: FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { wall { type buoyantPressure; } outflow { type freestreamPressure; } inflow { type freestreamPressure; } symmetry { type zeroGradient; } } --------- U: FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { wall { type fixedValue; value uniform (0 0 0); } outflow { type zeroGradient; } inflow { type fixedValue; value uniform (0 0 1); } symmetry { type zeroGradient; } } ---------------------------------------- Now, here is what I get when I type "icoFoam" in a terminal: Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.1 Courant Number mean: 0.000506547 max: 0.315347 DILUPBiCG: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 3.31525e-08, No Iterations 2 --> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 41.8405 Specified mass inflow : 0 Specified mass outflow : 185.25 Adjustable mass outflow : 0 From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p in file cfdTools/general/adjustPhi/adjustPhi.C at line 116. FOAM exiting ------- ------ "symmetry" corresponding to the free surface. I tried to run potentialFoam but I get "--> FOAM FATAL IO ERROR: keyword potentialFlow is undefined in dictionary ..[...]... FOAM Exiting". Please let me know if you have any suggestion about this issue, thank you very much, Stephy |
July 10, 2011, 22:50 |
Rep Power: 14 |
my boundary file:
FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 4 ( wall { type wall; nFaces 11332; startFace 229789; } outflow { type patch; nFaces 446; startFace 241121; } inflow { type patch; nFaces 452; startFace 241567; } symmetry { type patch; nFaces 6692; startFace 242019; } ) // ************************************************** *********************** // |
July 12, 2011, 23:28 |
Rep Power: 14 |
Anybody ? I'm still stuck on it....
thank you :-) ! |
July 13, 2011, 04:26 |
Pablo
Rep Power: 17 |
there is examples at this forum (wigley hull), and talking about freesurfaces try with interFoam.
July 13, 2011, 22:44 |
Rep Power: 14 |
Pablo,
thank you for your advice, I have already tried the wigley hull tutorial and read the topics dedicated to this on the forum (very complicated, people talk more about turbulence and forces issues, which is not yet my problem), but as I would want to understand what I am doing I try not to copy this case without understanding. Anyway, I wasn't even able to adapt the wigley hull to my mesh, which is basically the same, but the boundaries, as defined previously, are a bit different (the walls are actual walls). Do you have any idea of how I could adapt the wigley hull to my mesh and boundaries ? I guess I would have to change not only "p" and "U" but all those files dedicated to turbulence coefficients and others... |
October 10, 2011, 06:00 |
#6 | |
Johannes N Theron
Rep Power: 16 |
Edit Allrun and comment out last few lines so that you only run blockmesh and snappyHexMesh. Modify the settings in constant/polymesh/bleckmesh and snappyhexmesh until you are able to generate a nice grid. This will actually take quite some time in my experience as a co-newbie. Only then should you start to play with boundary conditions etc. Jan www.kanoefabrik.com |
April 10, 2012, 06:47 |
#7 | |
hs
Rep Power: 14 |
Hi Jan
I am exactly dong what you said in your post. I have put my own ".stl" file and run "blockMesh", "snappyHexMesh", "LTSInterFoam", and "paraFoam". there is some Foam warning but no error. In paraView, I have played but nothing changed I mean colour is all through same until time and fames are finished. can you give me some guides, please? hs// Quote:
April 14, 2012, 06:49 |
#8 | |
Johannes N Theron
Rep Power: 16 |
hs
Did you change the name of the stl file to your filename inside snappyHexMeshDict? Jan Quote:
April 15, 2012, 03:54 |
#9 |
hs
Rep Power: 14 |
thank you for your reply.
Yes, I changed to my own file name in snappyHexMeshDict. When I ran snappyHexMesh I got Foam waring as; >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>> (1) Morph iteration 0 ----------------- Calculating patchDisplacement as distance to nearest surface point ... Wanted displacement : average:0.0160589 min:1.71113e-06 max:0.0546716 Calculated surface displacement in = 0.33 s --> FOAM Warning : Displacement (0.000203702 0.00140685 0.0031613) at mesh point 3484 coord (-21.4617 -2.48765 -0.395662) points through the surrounding patch faces Smoothing displacement ... Iteration 0 Iteration 10 Iteration 20 Displacement smoothed in = 3.98 s (2) Did not succesfully snap mesh. Giving up. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>> I also have got this warning and error after "paraFoam"; >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> > $ paraFoam created temporary 'Hull70.OpenFOAM' --> FOAM Warning : From function polyMesh::readUpdateState polyMesh::readUpdate() in file meshes/polyMesh/polyMeshIO.C at line 204 Number of patches has changed. This may have unexpected consequences. Proceed with care. --> FOAM FATAL IO ERROR: size 5760 is not equal to the given value of 287774 file: /home/administrator/OpenFOAM/administrator-2.1.0/run/tutorials/multiphase/LTSInterFoam/Hull70/100/nut from line 18 to line 5803. From function Field<Type>::Field(const word& keyword, const dictionary&, const label) in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Field.C at line 236. FOAM exiting >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> would you like to have look the log, please? I can send the log to your email. thanks. hs// |
April 16, 2012, 01:56 |
shm
#10 | |
Johannes N Theron
Rep Power: 16 |
hs
There can be many reasons for not being able to snap. Start by making sure your refinement regions are set correctly (surround your geometry with a refined region), and that your refinement levels are high enough; if too coarse, it won't be able to snap. Jan Quote:
April 16, 2012, 20:02 |
#11 |
hs
Rep Power: 14 |
hi Jan
thank you for your comments. hs// |
April 19, 2012, 07:37 |
#12 | |
Rep Power: 18 |
Hi hs//
to your second problem Quote:
http://www.cfd-online.com/Forums/ope...celllevel.html regards Colin |
April 24, 2012, 01:12 |
#13 |
hs
Rep Power: 14 |
thanks Collin
hs |
UDF Defining VOF Free Surface at Outlet | Alex | Fluent UDF and Scheme Programming | 13 | August 8, 2012 16:50 |
Free surface problem: hull mesh questions | albertofast | OpenFOAM | 2 | December 15, 2010 19:50 |
free surface display | novice | Siemens | 5 | August 4, 2004 01:07 |
viscous free surface flow past a ship hull | lololo | Main CFD Forum | 0 | June 12, 2002 23:02 |
Modeling Free Surface Flows | Elliot Schwartz | Main CFD Forum | 5 | August 25, 1998 21:03 |
