April 30, 2012, 10:44 |
Problem about boundary layer flow.
Dear all,
Recently, I am simulating the Blasius boundary flow, I use the icoFoam algorithm, but the result of u/u0 is a little higher than 1 at certain height, I tried several grid and boundary conditions, but always get the result. Does somebody know what's wrong with me? thank you velocity field: boundaryField { symmetry { type symmetryPlane; } plate { type zeroGradient; value uniform 0; } out { type fixedValue; value uniform 0; } in { type zeroGradient; value uniform 0; } frontAndBack { type empty; } } pressure field internalField uniform (1 0 0); boundaryField { in { type fixedValue; value uniform (1 0 0); } out { type zeroGradient; } plate { type fixedValue; value uniform (0 0 0); } symmetry { type symmetryPlane; } frontAndBack { type empty; } } Wei |
Help: Fluid Flow Over a Horizontal Flat Plate by Boundary Layer Eq. | egemen | Main CFD Forum | 0 | May 20, 2011 04:57 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
Flat plate boundary layer problem | student | Main CFD Forum | 3 | May 21, 2007 13:10 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
Boundary Conditions | Jan Ramboer | Main CFD Forum | 11 | August 16, 1999 08:59 |
