January 20, 2010, 06:50 |
greyMeanAbsorptionEmission
magnus
Rep Power: 17 |
I have added the radiation module into reactingFoam and it seems to work fine. My question now is how to use "greyMeanAbsorptionEmission" so that I can have absorption and emmission coefficients as a function of , say, CO2 massfraction. As I understand the calculated species massfraction will be used since i am solving for CO2. Therfore I can give polynomial coefficients in a greyMeanAbsorptionEmissionCoeffs sub dictionary. There seems also to be an option of defining the coefficients in a lookuptable . I do so far not have intentions of using this table but it seems that it must exist in order to use the class. The table should be located under constant/ and if it does not exist the solver exits with a fatal error I have studied the source for the class but I run into trouble with the interpolationLookUpTable and cannot figure out what format the input file should be. I think it should be of class dictionary, and it has to contain the keywords fields, output and value. But everything I try just fails Anyone has an idea about this?? |
January 21, 2010, 03:19 |
magnus
Rep Power: 17 |
By the way I am using 1.6.x .
Any suggestions or hints would be highly welcomed. Did anyone use this model before? |
January 26, 2010, 08:27 |
magnus
Rep Power: 17 |
Hi again,
I managed to find a working format, which looks like this: fields 1 ( { N 1; max 1.0; min 0.0; name apa; } ) ; output 1 ( { name apa; } ) ; values 2 ( (0 0.0) (1 0.0) ) ; I am still very confused of what this does. But I am solving for the species of interest so I hope it does not influence anyhow. I also had to create a volScalarField called "ft" for it to work and "ft" needs to be registered with the other species and appearently solved for as well. well I just put it to zero in the entire field. I now managed to get the absorptioncoefficient as a function of CO2. But I do not know if I can trust the results since I have the feeling that i have misunderstood something important here. Could anyone shed some lights on this? |
September 11, 2010, 20:26 |
Sina
Rep Power: 15 |
Hi Magnus,
I have encountered the same problem right now. I was wondering if you so far has fixed the problem, and give some info of how to define the SpeciesTable dictionary. By the way, I've also sent you a private message with more details. Thanks Sina |
September 15, 2010, 16:47 |
Paulo Bufacchi
Rep Power: 15 |
Guys,
Please take a look at fireFoam. It uses exactly what you are looking for, although there is no white paper explaining the code. Regards, Paulo |
May 2, 2012, 08:49 |
Rep Power: 14 |
Can anyone explain the code for 'SpeciesTable' in case of grey mean absorption model used ?
greymeanabsorption, interpolationlookup, radiation, table |
