May 9, 2012, 06:03 |
Patch order in 'boundary'
Attesz
Rep Power: 17 |
Hi all,
is it a problem if I modify the order of patches in the constant/polyMesh/boundary file? If I run checkMesh or renumberMesh afterwards, I'm getting errors... Thank you |
May 10, 2012, 05:47 |
#2 | |
Mark Olesen
Rep Power: 40 |
Although each patch has both startFace and nFaces, there are undoubtedly many sections of code that only use the startFace from the first patch and index through by using the nFaces from each patch. |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
2nd order boundary conditions for 2nd order discretization? | quarkz | Main CFD Forum | 30 | December 26, 2011 07:12 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
